Old 08-01-2006, 01:02 AM   #1
PolarisSnT
Member#: 85905
2004 WRX
Default Tapping the boost trigger
I have a Coolingmist stage 1 kit and I have a question about the boost trigger. I have to connect it to a vacuum line and I was thinking about usin the BOV vac. line. Question is, my boost gauge is tapped off that so will adding the trigger affect anything?
PolarisSnT is offline   Reply With Quote
Old 08-10-2006, 01:23 PM   #2
benw
Member#: 103320
1998 swapped
Forester L
Bump, I'd like to know also.
benw is offline   Reply With Quote
Old 08-10-2006, 01:42 PM   #3
hippy
Member#: 36528
2002 Impreza Wrx
Old 08-10-2006, 02:02 PM   #4
PolarisSnT
Member#: 85905
2004 WRX
Yea I searched but guess I used the wrong words. As you know I already had it running so I figured it out anyway.
preferred place to tap a relay's trigger coil to the highbeam circuit? nhluhr Electrical & Lighting 2 02-09-2005 05:59 PM
Is this ok place to tap for boost pressure reading Fubaru Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 18 01-06-2002 10:53 PM
Proper Hose to tap for Boost Guage TempestX Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 6 11-03-2001 11:45 PM
Tap for boost gauge before or after IC Neil Wallerstein Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 5 07-29-2001 02:15 PM
