Old 08-01-2006, 01:55 PM   #1
redgrocerygetter
Member#: 42044
1998 Legacy GT
Default conversion question about an engine.
can I use say the heads out of a 98 legacy gt (DOHC) and mate it to the block from a 2000 legacy (SOHC)? I need a engine block and the problem with my old one is the crank won't move. The reason I'm looking for just a block is I can't semm to get the old block apart. Just wondering if this might be a simple solution to the problem of should I just keep looking for one closer to my engine model year? Thanks for any info.
Aaron
redgrocerygetter is offline   Reply With Quote
Old 08-01-2006, 02:12 PM   #2
Matt Monson
Member#: 832
99 2.5RS, '85 911
'73 914 and 2012 BRZ
That's a perfectly acceptable solution. A number of guys have done it to gain some performance as it bumps the compression ratio a little bit. Do it...
Old 08-01-2006, 10:34 PM   #3
redgrocerygetter
Member#: 42044
1998 Legacy GT
bump. No one else have any input?
Old 08-01-2006, 11:12 PM   #4
Russell Rogers
Member#: 27261
I'm Ron Burgundy?
Got it in my car. I love it..
Russell Rogers is offline   Reply With Quote
Old 08-04-2006, 11:26 PM   #5
redgrocerygetter
Member#: 42044
1998 Legacy GT
sweet sounds like a winner then. How much of a gain did you guys get when you switched the two? I'm planning on keep'n it NA but I what to do some internals to boost the power output. Thanks for the info.
Aaron
Old 08-05-2006, 02:50 AM   #6
Growit
Member#: 97764
96 Outback
Forest Green
If you want to "do some internals to boost the power output". The most cost effective change is sending off your cams to Delta for a regrind. It will run you about $300 with shipping. It is almost a no brainer since the cams will be out for the block swap anyway.
With a phase1 head gasket your CR is going to be about 10.6:1 (stock phase1 is 9.5:1). Using a phase2 head gasket your C/R is going to be about 11.2:1. Using the Phase2 head gasket will put your cam timing slightly out of phase with one another.
So changing out your pistons will only net you a little bit more if anything at all. If your concerned about your quench you will have to change your pistons and get some longer custom rods made. To get pistons and rods your looking at about $1600 for parts, not worth it to me to get to 11.2:1 w/ proper quench.
The rest are standard bolt ons.
I have a stock MY05 short block w/ MY96 heads, delta cams and a gready emanage to tweek timing and A/F levels. To let the engine breath a little more I went with an AMSOIL Ea Air Filter. The KandN breaths a little better but doesn't filter as well.
I make regular long hauls in the Outback so I haven't gone with a CAI and Exhaust because of the noise level.
Now if someone knows of a quiet performance exhaust system, please let me know...
Hope this is the kind of information that you are looking for.
Growit is offline   Reply With Quote
Old 08-06-2006, 05:17 AM   #7
redgrocerygetter
Member#: 42044
1998 Legacy GT
yes that was helpfull. What does quench mean? Never heard that phrase before. Thanks.
Old 08-31-2006, 02:08 PM   #8
redgrocerygetter
Member#: 42044
1998 Legacy GT
really what does Quench mean?
Old 08-31-2006, 02:24 PM   #9
Matt Monson
Member#: 832
99 2.5RS, '85 911
http://www.theoldone.com/archive/quench-area.htm
God, it's literally been years since a google search brought up a "The Old One" article. Back in the day he was a Honda tuning guru...
Tricky Question about an HID conversion. Samurai_jim Electrical & Lighting 3 12-08-2008 10:57 AM
2 questions about an STI 6 speed into an '02 wagon Cyclops Brakes, Steering & Suspension 17 04-04-2008 04:03 PM
Thinking about an engine buildup...need suggestions wcbjr Texas Impreza Club Forum -- TXIC 54 04-04-2003 03:15 PM
Question about crazy engine swap... 5 Door Man General Forum Archive 11 02-20-2001 10:55 AM
