Old 04-16-2001, 07:51 AM   #1
XROLLER
Member#: 1273
98 Impreza
RBP
Post A/C smells horrible?
Was doing some cruising around yesterday got alittle warm out so i turn my air on and it stank like i don't know what. What could be causing this?
XROLLER is offline   Reply With Quote
Old 04-16-2001, 08:00 AM   #2
Mike Smith
Member#: 744
00 BRP RS Coupe
02 Forester, 00 S-10,
Post
Couple of possibilities:
1. Dead rodent in A/C compressor (or general vicinity).
2. Stagnant water from A/C condenser is growing something.
Mike Smith is offline   Reply With Quote
Old 04-16-2001, 08:02 AM   #3
XROLLER
Member#: 1273
98 Impreza
RBP
Post
A/c compressor how the hell does something get in there? Solution?
Old 04-16-2001, 08:18 AM   #4
Langit
Member#: 4661
Platinum Metallic
Thumbs up
try spraying a bottle of lysol on the AC vents...
Langit is offline   Reply With Quote
Old 04-16-2001, 08:22 AM   #5
Norb
Member#: 4856
2002 WRX Wagon MT
Post
What causes it is that you probably left your recirculate lever on the on position. It makes the system a closed loop and causes bacteria and mold to grow in your condensers. Only way to get rid of it is get your condensers cleaned. And remember not to leave your recriculate button on.
Norb is offline   Reply With Quote
Old 04-16-2001, 08:42 AM   #6
XROLLER
Member#: 1273
98 Impreza
RBP
Post
So the recircluate should be to the left or the right?
Old 04-16-2001, 09:07 AM   #7
MrHorspwer
Member#: 4063
Post
Just a note... the evaporator is inside the car, condensor is outside in front of the radiator. It's probibly some bacteria growning on the evaperator... I know GM makes a disinfectent for this problem, you'd have to drop by a GM dealer to get it. There may be some commercially availiable product that is similar. One other thought... have you been through a whole lotta mud anytime soon? I've seen vehicles, mainy trucks, that just stink like a swap from getting mud in the evaperator case.
MrHorspwer is offline   Reply With Quote
Old 04-16-2001, 09:11 AM   #8
XROLLER
Member#: 1273
98 Impreza
RBP
Post
Never been off road with it, or at least i would of noticed this problem a long time ago, what if you spray down the radiator opening real good will that help? What's the name of the disenfectant? Could dead leaf's cause the problem?
Old 04-16-2001, 09:56 AM   #9
bryanw
Member#: 807
2002 WRX Wagon
Post
It should be pulling air from the outside. Mold can grow in there and smell pretty bad.
Was this the first time you've turned on the A/C this year? If it's been sitting over winter, then it takes a while to clean itself out.
bryanw is offline   Reply With Quote
Old 04-16-2001, 10:52 AM   #10
Avenger
Member#: 1234
Post
You can buy those spray for the A/C system at a auto part store. They only seems to work for a while and then you would smeel it again. Give it a try anyways.
Avenger is offline   Reply With Quote
Old 04-16-2001, 11:00 AM   #11
OldWRXr
Member#: 4650
Exclamation
The air conditioner should be run at least once a month. This should avoid those smelly conditions. In the winter press the "air" button in when defrosing the windshield.
OldWRXr is offline   Reply With Quote
Old 04-16-2001, 11:21 AM   #12
2WDrift
Member#: 5132
95 BMW 330ti
black
Post
This can happen in any car. Mold is all around and just needs the wet conditions to grow. It has nothing to do with recirculate (recirc would keep OUT the mold), but instead that the fan is shut down with the evaporator wet (that water drip which is how the a/c works), so overnight it starts molding up, like wet towels in the hamper.
Turn the fan on fresh/high, then spray Lysol into the windshield intake for 10 seconds. From now on always click off the a/c compressor 30 seconds before shutting the car off but leave the fan on. The airflow will warm up and dry off the evap, wallah no more mold. Don't bother if it's a quickie stop but do it if you're going to sit for a few hours. Now you have something to do waiting for turbo cooldown. Or just do it that last turn before home.
Gary
[This message has been edited by 2WDrift (edited April 16, 2001).]
2WDrift is offline   Reply With Quote
Old 04-16-2001, 11:25 AM   #13
XROLLER
Member#: 1273
98 Impreza
RBP
Post
Thanks for the info, i'll go home tonight and try them.......i'll keep you informed.
Old 04-16-2001, 11:35 AM   #14
nizz
Member#: 188
2004 Forester XT
24k gold on white
Post
Somewhere, I read that everyone is supposed to turn on their AC during the off season for 5 minutes a month or week to cycle the freon. I totally forgot to do that this winter. Hope my AC doesn't stink when I use it.
nizz
nizz is offline   Reply With Quote
Old 04-16-2001, 11:38 AM   #15
XROLLER
Member#: 1273
98 Impreza
RBP
Post
Yeah the a$$ smell is definatly something i'm going to have fixed, summer is coming up pretty soon and can't have a subaru with bad breath!
Old 04-16-2001, 11:48 AM   #16
2WDrift
Member#: 5132
95 BMW 330ti
black
Post
Once a month a/c cycling in winter keeps the compressor seals lubricated w/ oil so the freon doesn't leak out. But I'd think you would have had a foggy occasion to use the a/c on defrost, since it dehumidifies the wet air. I guess that's why some cars turn the a/c on automatically with defrost.
Old 04-17-2001, 12:18 AM   #17
edkwon
Member#: 453
2014 Audi S4 B8
Porsche Cayman GTS
Cool
To avoid the unsightly A/C condensation funk/mildew smell, i usually like to run the air without the A/C condenser on, pull in some outside air and dry that system out so moisture doesn't just pool and sit there. This really helps. Like someone said, its also good to run the A/C occasionally during the winter so any consdensation in the system doesn't stagnate, especially when you run mold-growin heat in the airways
edkwon is offline   Reply With Quote
Old 04-17-2001, 12:22 AM   #18
SRI Performance
Vendor
Member#: 2448
1997 subaru
green and yellow
Post
vanilla smells nice
chris
SRI Performance is offline   Reply With Quote
Old 04-17-2001, 12:53 AM   #19
UCI_Scott
Member#: 5088
Post
Most likely mold.
Now that it has a foothold you need to suck some disinfectant through the system.
To keep it out in the future, always run your system without the a/c compressor for the final couple of minutes. Maybe even some warmer air through it. When the system is turned off on a hot day, the cold hoses cause whatever moisture is in the air to condense inside the hoses. If there are any spores or germs or molds from the air in the system when water starts to condense, they are likely to grow, then smell.
I'm not sure, but I think Subaru's optional air filter helps prevent these airborn contaminants from entering the system.
--scott
UCI_Scott is offline   Reply With Quote
fuel smell in oil acssa Built Motor Discussion 3 06-01-2010 04:14 PM
Horrible Smell - Like Burning Gaskets/New Exhaust Cobrakai Factory 2.5L Turbo Powertrain (EJ Series Factory 2.5L Turbo) 11 01-19-2009 10:47 PM
horrible gasoline smell appearing and dissapearing? sp99ling Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 5 02-14-2008 10:41 PM
Horrible Gas Mileage/Raw gas smell in cabin ScoobySnacker Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 9 12-18-2007 07:14 PM
Mung beans - do they really smell horrible? edkwon Off-Topic 5 11-27-2006 07:15 PM
