Go Back   NASIOC > NASIOC Technical > Engine Management & Tuning > Other Engine Management
Old 08-02-2006, 03:22 PM   #1
Crazyhippy
Member#: 104881
1970 stg7 Porsche914
Default Link Issues.... Low boost, and lack of RPM
Running a Possum Link on a 03 USDM WRX.
Doesn't rev beyond 4000rpm (ish) and doesn't build boost beyond 8psi (ish).
Details HERE!!
Questions:
1. Does the Link need the VSS hooked up?
2. Does the Link have a "limp" mode?
3. What's wrong w/ this thing?
Gratsi
BJH
Crazyhippy is offline   Reply With Quote
Old 12-08-2006, 12:22 AM   #2
fc3swrx
Member#: 21009
2008 Sti
Blue w/ Gold BBS wheels
Default I read your post, I've been running link for 3 years
what actually happens when you reach the rpm's when it stops? does it sputter? jump? what?
To be completely honest it just sounds like it isn't tuned. meaning that at around 5 - 8 psi he link really starts to add a lot more fuel based on the map and it will just fall on it's face if not programed correctly, also make sure you have proper MAP sensor plumbed, make sure no leaks on intake manifold (leaks for small hoses that is) check hose on fuel pressure regulator.
Also, you do need the Air inlet sensor and the MAF, they are used. and depending on the settings in the link it may not run right depending on the enrichment they dictate.
Details HERE!!
Questions:
Gratsi
BJH
fc3swrx is offline   Reply With Quote
Old 12-18-2006, 07:40 PM   #3
Crazyhippy
Member#: 104881
Per Neil @ LINK USA, i dont need the MAF. My issue ended up being a crank position sensor wired backwards. Also had the computer set up rather rich (safe). John @ Outback Motors figured out my Crank Pos. issue, and tuned it. Runs 1 Million times better now.
Never updated this thread because there were no responces.
BJH
Hesitation @ high RPM, low boost, and Fuel Cut K.Linchpin Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 4 09-17-2006 09:07 PM
2.5rst link really cold start or lack of 25rstautoxr Engine Management & Tuning 7 01-13-2004 08:46 PM
low boost and low vac. QfactorRS Normally Aspirated with bolt-on Forced Induction Powertrain 7 07-25-2003 01:30 PM
VERY strange sound, and Lack of solenoid with TXS Stage IV BlueDemon Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 3 12-17-2002 12:48 PM
What's a good cure for body roll and lack of quick responce... SILVERWRXWAGON Brakes, Steering & Suspension 13 10-18-2001 06:43 PM
