Old 08-02-2006, 04:48 PM   #1
JamiePasson
Member#: 33909
Default valve tap on a 2.2
I have a '95 legacy 2.2 in it. It has developed a valve tap. This has been a problem intermittently over the past 2 years. It came and went. However, it has been around for over 3 months now and is starting to get annoying. I think it is from the rear drivers side cylinder. Does anyone know of a history of bad lifters on these? Or any other chronic problem that would cause this?
thanks,
Jamie
JamiePasson is offline   Reply With Quote
Old 08-02-2006, 05:04 PM   #2
SubeTek
Member#: 1714
1999 RS-T COUPE
If anything, it's the hydraulic lash adjusters in the rockers. They are very easy to replace, although sometimes small pieces of silicone can become logded in the oil port for the rockers & cause the same noise.
SubeTek is offline   Reply With Quote
Old 08-02-2006, 05:32 PM   #3
JamiePasson
Member#: 33909
I don't think that it is silicone. The engine has never had any work that required any silicone. I thought about the lash adjusters as well because it seems to be the rear drivers side cylinder only. If the oil port was blocked, it should be both cylinders. Next question: Are the heads on a 2.2 like the 1.8? I have done extensive work on 1.8's over the years. The two piece heads make cam and lifter removal in the car easy. Do you have to pull the head to get the cam out to change the lash adjusters on the 2.2?
Thanks,
Jamie
Old 08-02-2006, 07:25 PM   #4
Matt Monson
Member#: 832
99 2.5RS, '85 911
'73 914 and 2012 BRZ
You don't even have to remove the timing belt. It's assembled just like the Ej18 heads. I have had great success just bleeding the HLA's and very rarely have had to actually replace one...
Old 08-02-2006, 08:48 PM   #5
Plays_With_toys
Member#: 82556
1996 Legacy L wagon
Plays_With_toys is offline   Reply With Quote
Old 08-02-2006, 11:13 PM   #6
SubeTek
Member#: 1714
1999 RS-T COUPE
Often times it's silicone from the block halves or oil pump during factory assembly. Just make sure to check the oil galleys under the rocker mounts @ the rocker shafts.
Old 08-03-2006, 01:28 AM   #7
ROC pit-bull
Member#: 67814
1995 legacy L
white
i had this problem then i switched from 93oct, back to 87. problem gone now.
ROC pit-bull is offline   Reply With Quote
Old 08-03-2006, 02:03 AM   #8
tonzo
Member#: 94903
1996 Impreza Wagon!
Satin Black
Subaru Stars
are there any solid adjusters that are available to replace the hydraulic ones in the 2.2 heads?
tonzo is offline   Reply With Quote
Old 08-03-2006, 10:05 AM   #9
SubeTek
Member#: 1714
1999 RS-T COUPE
Some of the later models 96 & up had roller tip rockers w/manual adjusters (no hydraulic lash adjusters)
Old 08-03-2006, 10:27 AM   #10
JamiePasson
Member#: 33909
Thanks! I will give it a whirl. The way it sounds is, it is acutally easier than the 1.8. The 1.8, you would have to take the cam belt sprocket off at the minimum. The only thing that is a bit confusing, is the 12 mm socket with the big and small nipple deal. I am sure, once it is in my hands, I can visualize it much better. Thanks again!
Jamie
Old 08-03-2006, 01:07 PM   #11
Plays_With_toys
Member#: 82556
1996 Legacy L wagon
The HLA is a small cylinder, with a nipple thing on it. Place the nipple on the ground and the cylinder will be up in the air. A 12mm socket fits over it nicely. Then, the small box part of the socket (where you would attach it to a ratchet) is perfect to fill with a small reservoir of oil. Hope this helps.
Old 08-03-2006, 01:16 PM   #12
JamiePasson
Member#: 33909
I am very familiar with the lash adjuster. pretty much the same as a hydraulic lifter except with a tip instead of a pocket for the pushrod. I just couldn't visualize how the socket was used. thanks for the description! We Got it now. I will be tackling this Saturday afternoon.
Thanks again,
Jamie
2.2.valve tap... JamiePasson Normally Aspirated Powertrain 9 02-26-2013 01:35 PM
valve adjustment on 2.5 Series 2 Outback Thomas Allen Service & Maintenance 3 09-06-2011 03:16 PM
2.0 valve covers on 2.5 heads? upjeeper Factory 2.5L Turbo Powertrain (EJ Series Factory 2.5L Turbo) 1 10-02-2007 08:33 PM
2.2 valve tap JamiePasson Service & Maintenance 0 08-02-2006 04:53 PM
2.2 ECU on 2.5 motor.. IAC valve problem Murray Engine Management & Tuning 6 12-31-2002 12:01 AM
