Old 08-02-2006, 04:28 PM   #1
sixkiller
Member#: 117091
2001 Impreza RS
Default TPS Adjustment problem
This is on a '02 2.5L Impreza.
The TPS was pulled off and when put back on doesn't adjust even close to the .45 - .55 v spec in the manual - my meter's reading 4.5 vdc.
The manual doesn't say dc but I'm assuming that's what I'm looking for.
That's with the key on and throttle closed.
I'm pretty sure I'm on the correct ECM wires Light green and red - connector B136 or "c" - measuring across pins 15 and 17.
I double checked and made sure the sensor flange is on the right way so it moves if you open the throttle.
Any advice would be great.
Thanks.
sixkiller is offline   Reply With Quote
Old 08-02-2006, 04:44 PM   #2
LetItSnow
Member#: 38222
'10 &'12 Foresters
another Miata convert
TPS is B136, pins as follows:
15 - Power (5V)
16 - Ground (0V)
17 - Signal (0.2V-1.0V closed, 4.2V-4.7V open)
If you're reading from 15 to 17:
5-((0.2+1.0)/2)=4.6V on the average
I'd say you're dead on.
LetItSnow is offline   Reply With Quote
Old 08-02-2006, 07:03 PM   #3
sixkiller
Member#: 117091
2001 Impreza RS
Appreciate that explanation. Since I set it for 4.5 and it worked and drives well and now I know why.
Course now I have a constant cel which I'm thinking the out of spec voltage caused.
Thanks again.
Old 08-02-2006, 08:57 PM   #4
SCOOBY2.5RS
Member#: 66234
3G WRX-WRB
Scooby-X Monster
What is a TPS?
Wow, what a nebie question! lol
SCOOBY2.5RS is offline   Reply With Quote
Old 08-02-2006, 09:13 PM   #5
sixkiller
Member#: 117091
2001 Impreza RS
It's a throttle position sensor. And as my stepson found out, if it's way out of adjustment the poor car is quite confused...
Old 08-02-2006, 09:27 PM   #6
SilverScooby04
Member#: 75025
Ummm... yeaaaaahh.. We're putting the new cover sheet on the TPS Reports before they go out, did you get that memo?
SilverScooby04 is offline   Reply With Quote
TPS Adjustment OneOBS Normally Aspirated Powertrain 33 01-12-2006 03:48 PM
TPS Adjustment on 00+ gumby647 Normally Aspirated Powertrain 7 12-10-2001 09:58 PM
TPS adjustment for 2-3 shift glenstiles SVX Forum Archive 8 01-11-2001 08:50 AM
TPS adjustment rsquire North West Impreza Club Forum -- NWIC 5 03-09-2000 05:42 PM
TPS adjustment Akiata Legacy Forum 0 10-02-1999 10:23 PM
