Old 10-24-2001, 11:22 AM   #1
nicd
Member#: 3214
Exclamation Pre-turbo cat failure = blown turbo
Did we have any one else with this problem which seems to be due to faulty welds in the pre-turbo cat. I have heard of one similar experience in Australia at least of reported incident. But At this point I was wondering if we should be concerned?
nicd is offline   Reply With Quote
Old 10-24-2001, 11:23 AM   #2
nhluhr
John Wayne Toilet Paper
Member#: 7327
2008 Mazdaspeed3
2006 Wrangler Sport
time for that catless uppipe from Shiv, Ultimate, vividracing, or somebody else!
nhluhr is offline   Reply With Quote
Old 10-24-2001, 11:57 AM   #3
Jaxx
Member#: 177
The 93 W/EJ20K
Series 10 FRS
as i recall... the other incident was due to high boost levels using a mbc-->which lead to high EGT--> which melted the cat-->cat pieces flew in to turbo---->turbo go boom
Old 10-24-2001, 12:31 PM   #4
WRXThis
Member#: 3960
My precat turbo went bad and fried my turbo, head, and valve shims. Hmm...faulty welds, that would explain it.
Needless to say my precat is being replaced with a Brullen up pipe as soon as it arrives.
WRXThis is offline   Reply With Quote
Old 10-24-2001, 12:46 PM   #5
gtguy
Member#: 2184
2005 Legacy GT wagon
Platinum Silver Metallic
Put this one with the "broken transmissions" stuff. If there were that kind of stuff going on, we would sure as heck have heard about it, given that we hear about every little paint chip that someone gets. It can be used as justification for a new up-pipe however, if that's what you're thinking about.
Kevin
gtguy is offline   Reply With Quote
Old 10-24-2001, 01:08 PM   #6
nicd
Member#: 3214
Exclamation One here in MTL
Not to start a frenzy but I just talked to a dealer in Montreal that has confirmed an incident like this just this week.
Old 10-24-2001, 01:13 PM   #7
djerickd
Member#: 3782
02 WRX WFC#040
Clean on 19's
Leonardo had a faulty precat also,
Dealer fix: Shiv up-pipe
SWEET!
djerickd is offline   Reply With Quote
Old 10-24-2001, 01:32 PM   #8
HndaTch627
Member#: 6551
'01 GC8 Dinged STM
'09 Concours 14 ABS Black
I am curious how a pre turbo cat would take out a cylinder head, a valve and and valve shims??
Elighten me
Old 10-24-2001, 01:51 PM   #9
Kevin
Member#: 1082
2015 Q50S
Dull
Talking
I'm just curious as to where this 'precat turbo' is, I can only find one turbo on my car.
Kevin is offline   Reply With Quote
Old 10-24-2001, 02:49 PM   #10
nicd
Member#: 3214
Have a Nice Day? Yes yes I have to correct myself
Pre-turbo cat would that be correct?
Pre-turbo
Old 10-24-2001, 03:14 PM   #11
Conduit
Member#: 6162
MBP, 1st WRX Ever in FL.
We will see more of these. Running an just a BC will make your car run nice and rich...which clogs the cat, and will eventually make it break up. Please don't drive much with a BC and no uppipe, or you will feel it too! I'm already worrying about my expensive 3" high-flow cat.
Conduit is offline   Reply With Quote
Old 10-24-2001, 03:18 PM   #12
TypeC
Member#: 9794
02 2.5LWRX-Retired
335i w/twins
rich? I thought the bc would lean things out. Are you saying the MAF will compensate (to a point) by ading fuel?
-C
TypeC is offline   Reply With Quote
Old 10-24-2001, 04:04 PM   #13
Conduit
Member#: 6162
The ECU essentially dumps fuel when it sees that boost pressure is exceeding factory parameters. It goes open-loop and runs very very rich. Sometimes as bad as 9.8:1, hence the poor gas mileage, etc. This is why a/f and timing really should be controlled if you are going to use a BC.
Old 10-24-2001, 04:18 PM   #14
HndaTch627
Member#: 6551
'01 GC8 Dinged STM
and also once your pass the 12.0:1 A/F ratio you make LESS power then you did in the beginning, not ot mention the fact that the ecu is going to continue to pull timing away until the point that it can regulate the boost again.
jeremy
WTB:Legacy GT style blown turbo titsataki Private 'Wanted' Classifieds 4 06-03-2010 10:41 AM
pre-turbo cat paranoia? cougar Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 13 12-18-2002 09:18 AM
Whoa Whoa Whoa! pre-turbo CAT? phasedlife Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 20 04-25-2002 10:38 AM
eliminating the pre-turbo cat harrydog Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 3 06-03-2001 06:53 PM
