Old 08-03-2006, 07:52 PM   #1
verc
Member#: 41754
03 wrx
gt35r, 2.5L, meth
Default If you have Helix cams/valvetrain, read/reply in this thread
*edit*
I'll clarify on the exact nature of the problem:
- slight hesitation around 2500-3000 rpm
- periodically pulls timing. eventually goes into limp mode
- cyclical problem: car is fine for a week, then for week 2 pulls timing, goes into limp mode, week 3 car is fine again
*edit*
I know of two bugeyes w/ the Helix valvetrain experiencing wierd periodic power loss problems, going into limp mode. There is suspicion that they are wiping due to manufacturing issues w/ the lobes. However I've seen people using the cams and haven't heard issues.
Anyhow, post here if you have the Helix product. What car do you have, have you experienced problems, and do you have the whole valvetrain or just the cams?
Thanks,
Ambert
verc is offline   Reply With Quote
Old 08-04-2006, 09:16 AM   #2
mokujin22
Member#: 112450
2002 Silver Bug-eye
30 mpg 2000 Neon...Hi!
Well, I'm having Gruppe-S put the 264 valvetrain into my 2.0L heads for a 2.5 hybrid. Hopefully, will get the assembled SB in the next couple of weeks.
What do you mean by "wiping?"
Tony
mokujin22 is offline   Reply With Quote
Old 08-04-2006, 09:55 AM   #3
Drink
Member#: 102682
... ripper's
sister.
Are there alot of people just dropping the 264s in without doing the springs, retainers, etc?
Drink is offline   Reply With Quote
Old 08-04-2006, 10:49 AM   #4
wrxfactor
Member#: 49978
2002 WRX w/ JDM STi
6spd, EJ255, VF39 & EWG
Tony
Tony,
Check the build date on your WRX, I've been reading on here that the early 02s had smaller ports in teh heads than later WRXs, even the later 02s and 03s. If your heads are already off and this is the case, you might as well port them. You don't wanna have that bad boy assembled and then see that the valvetrain is doing its job but the port sizes are screwing you.
Chris
wrxfactor is offline   Reply With Quote
Old 08-04-2006, 03:36 PM   #5
WhiteWoRX1
Member#: 92601
01 Z06
I have the cams and valvetrain installed, but have yet to put the motor in the car and fire it up. The only problem I have had so far is that the cams did not "drop in" as advertised. The thrust journals on all 4 cams were too wide and were binding in the head. I had to have them machined to fit.
I called Geoff at Gruppe-s to ask about this and he told me that he had only heard of one other customer that reported clearance issues with the cams. I talked to a couple of guys on here before buying the cams and they had yet to have any problems.
WhiteWoRX1 is offline   Reply With Quote
Old 08-04-2006, 06:03 PM   #6
testes1010
Member#: 47145
2012 Gas Saver
same here, subscribed....
testes1010 is offline   Reply With Quote
Old 08-04-2006, 07:26 PM   #7
verc
Member#: 41754
03 wrx
gt35r, 2.5L, meth
Tony
Wiping is when the lobes degrade. Upgraded cams have bigger lobes for more lift, and if the metal is of inferior quality they may alter shap and change the intake/exhaust duration of the cams. Bad times.
Old 08-04-2006, 07:28 PM   #8
verc
Member#: 41754
03 wrx
gt35r, 2.5L, meth
Originally Posted by wrxfactor
Tony,
Chris
Interestingly I have a late model '03 and my car came w/ shimless buckets
Old 08-04-2006, 07:30 PM   #9
verc
Member#: 41754
03 wrx
gt35r, 2.5L, meth
Old 08-04-2006, 07:32 PM   #10
verc
Member#: 41754
03 wrx
gt35r, 2.5L, meth
This is what I'm wondering, it appears so. Which is why I'm asking since me and the other guy w/ problems both have the complete valvetrain.
it shouldn't matter though - 264 cams should drop in w/o need for a valvetrain upgrade methinks.
Old 08-04-2006, 07:53 PM   #11
WhiteWoRX1
Member#: 92601
01 Z06
Damn, sounds like a pain in the ass. Can you send them back and have them warrantied? It would SUCK to have to pull the motor, tear it down, and then wait god knows how long before you get an answer or a new set though. Hope everything works out.
I should have my car up by the end of the month, so I'll report if I have any issues.
BTW how many miles did you get before these problems started???
Old 08-04-2006, 08:09 PM   #12
Drink
Member#: 102682
... ripper's
sister.
That is what I thought & hoped. I have a new 257 for my hybrid setup and was considering some 264s myself. Verc, I'm curious about your hybrid? What turbo, head gasket, compression are you running?
Matt
Old 08-06-2006, 01:48 AM   #13
verc
Member#: 41754
03 wrx
gt35r, 2.5L, meth
Matt
I'm running cometic .040 gaskets and APR headstuds. Compression would be up a bit, not sure exactly.
Turbo is a wrapped vf30.
Old 08-06-2006, 01:51 AM   #14
verc
Member#: 41754
03 wrx
gt35r, 2.5L, meth
These problems started immediately after tuning (took a while to confirm this was not due to the tune). I broke in the motor for 1k using only partial throttle so I wouldn't have known if anything was happening then.
Old 08-06-2006, 03:46 AM   #15
bugeyes
Member#: 64494
2001 V7 sti
It has been shown on dyno's here in Aus that even with standard cams the power drops off at high rpm's due to valve float. Add extra boost and you have boost pressure wanting to push the valves open which further effectively reduces valve spring seat pressure and drops to top end off even earlier.
From what I have seen upgrade the springs, its too hard to replace them later.
I honestly beleive stores tell you the cams drop straight in in order to keep the overall cost down and make the cams look more attractive to buy, but the truth is a different story.....
bugeyes is offline   Reply With Quote
Old 08-07-2006, 02:26 PM   #16
mokujin22
Member#: 112450
2002 Silver Bug-eye
Tony,
Chris
damn, got my car in Spring of 2001. one of the first batch at the dealership. i would be shocked if my heads didn't fit that description. they're out in California right now with Gruppe-S. i had pulled everything apart myself, but didn't trust myself to get the valve lash right on my shimmed buckets. imo, everything (except the heads and the tranny) is just nuts and bolts. enough time and elbow grease can get anything done.
i think that i'll give Geoff a call.
Tony
Old 02-11-2007, 09:06 PM   #17
readymix
Member#: 59839
2004 WRX
Platinum Silver
I'm also having this problem it seems. Both the intake and exhaust cam on my left side head are having binding issues thus far. I'm going to talk to my machinist tomorrow about machining the cams so they will fit.
readymix is offline   Reply With Quote
If you have a "shocker" sticker on your car this thread is for you Leggy_09 Off-Topic 62 08-25-2009 04:15 PM
Protege Menace will be first reply in this thread. mexicanpizza Off-Topic 9 02-09-2007 01:23 AM
If You have Cwest Grille [Please Read variablegear Interior & Exterior Modification 6 10-20-2002 05:20 PM
wanna start a r/c club? if you have ANY intrest please read ^jynx^ New England Impreza Club Forum -- NESIC 14 03-04-2002 01:52 PM
wanna start a r/c club? if you have ANY intrest please read ^jynx^ Tri-State Area Forum 5 02-25-2002 12:35 PM
