Old 08-03-2006, 09:41 PM   #1
snowman225
Member#: 95362
Default help needed urgent, cannot hold boost
just got my car tune with ecutek, sad to said my boost can't hold.
it was ok till 5K+ rpm then e boost start to drop(4-5psi) and when reaching 7krpm the boost start to pickup again...
i'm using ecutek to control the avcr solenoid for e boost
turbo used- vf30 with hks actuator..
anyone any idea? thanks...
snowman225 is offline   Reply With Quote
Old 08-04-2006, 03:05 PM   #2
Ben-EcuTeK
Member#: 57867
1999 Volvo
You can always conatct me directly with more information.
what did your tuner said?
Ben-EcuTeK is offline   Reply With Quote
Old 08-17-2006, 08:19 PM   #3
snowman225
Member#: 95362
he suspect there's a leak on the up pipe or e turbo/hks actuator is "faulty" ,,,
Old 08-18-2006, 08:38 AM   #4
Ben-EcuTeK
Member#: 57867
1999 Volvo
Actuator can be easily tested with Pressure/vaccum pump, I do not know at what pressure the actuator should open though...
As for the up-pipe, difficult to see properly arround the flanges but with small mirror should shoud see exhaust deposits somewhere if there is a leak arround the flanges.
Old 08-22-2006, 12:24 AM   #5
snowman225
Member#: 95362
hm.. ok will try it out... thanks
gt30r .82 cannot hold boost my_sti_1 Factory 2.5L Turbo Powertrain (EJ Series Factory 2.5L Turbo) 17 01-10-2006 06:04 PM
Urgent! help needed Urgent! iamrazor Legacy Forum 20 01-02-2006 03:43 PM
Help Needed Urgently Crash477 Brakes, Steering & Suspension 27 10-15-2004 01:06 PM
Help! Need pics of factory boost solenoid lines cm1wrx Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 6 05-28-2004 04:57 PM
itc help needed. urgent inpreza kid Normally Aspirated Powertrain 3 10-01-2001 10:07 AM
