Old 08-03-2006, 11:09 PM   #1
Palmermc
Member#: 121471
Default Stromung mid on stock exhaust?
I've got a 99 rs. I'm in dire need for a new intermediate pipe. I currently have a apexi can welded on the stock axleback which the previous owner put on there. everything else is stock. Its been fine so far, but the intermediate pipe is rusted through and I cant invest in a full catback as of yet. So i'm wondering if I were to buy just a stromung intermediate pipe if it will bolt up between the cat and stock axleback flanges. Will the supplied/oem gaskets work? Does anyone know if the stromung pipe comes with that round gasket that goes between the cat?
Thanks,
Mark
Palmermc is offline   Reply With Quote
Old 08-04-2006, 10:54 PM   #2
MannyMohawk#5
Member#: 98807
1999 RSTi
RHD BF5 & BJ6
As long as it is designed for your model year, it should bolt up. Don't know about the midpipe, but my Stromung down pipe came with some cheesy gaskets.
MannyMohawk#5 is offline   Reply With Quote
Old 08-05-2006, 10:04 AM   #3
piker28
Member#: 22664
yes the stromung will bolt right on for you
stock gaskets should work, but you will want to buy new ones to replace the old
piker28 is offline   Reply With Quote
3" piping on stock exhaust?? warui111 Factory 2.5L Turbo Powertrain 2 01-02-2006 07:06 PM
Springs on stock exhaust 0260B4U Factory 2.0L Turbo Powertrain 1 11-01-2003 01:07 PM
Kartboy Hangers on stock exhaust? rchaves Brakes, Steering & Suspension 2 03-24-2003 10:43 AM
Wastegate dump on stock exhaust??? Force[FED] Factory 2.0L Turbo Powertrain 6 10-19-2001 05:05 PM
Message Board Statistics All times are GMT -4. The time now is 10:22 AM.
