Old 08-04-2006, 02:27 AM   #1
X4 SRT
Member#: 40636
2001 2.5 RS Coupe
Unhappy Cobb CAI broken
So I was changing my oil today, and what do I find when I pop the hood...my cobb cai is broken. The black plastic cylinder that houses the filter cracked at the top where you connect it to the piping, and fell completely off. It was just sitting there in my engine bay not doing it's job. So, I went to the store grabbed some duct tape, and taped it back up untill I can replace it. Kinda sucks...
Anyone know why it might have cracked? Has this happened to anyone else. I've had the intake for almost three years now, and I'm in vegas...so...maybe the heat had something to do with it...who knows...
X4 SRT is offline   Reply With Quote
Old 08-04-2006, 02:52 AM   #2
EBWRC#1
Member#: 86843
Io Sono
a 500 Driver !
Does it work fine for you? my brother is thinking in buying one but he doesn't know if it really gives you gains!
EBWRC#1 is offline   Reply With Quote
Old 08-04-2006, 08:16 PM   #3
Tim Sanderson
Member#: 6486
00 Impreza 2.5 RS
Blue Ridge Pearl
FInd out what sort of plastic it is and buy some glue for it. You can find glues at www.tapplastics.com The weldon product line has glue to make anything stick to anything else. IT usually goes on like water and dries quickly. I'm sure it would be cheaper than replacing the part that cracked.
Tim Sanderson is offline   Reply With Quote
Old 08-04-2006, 09:04 PM   #4
Rally_wgn
Member#: 62629
1996 OBS in Green
2.5 N/A w/ full exhaust
Im thinking about having an aluminum shroud fabbed up. The plastic one cracks way to easy. I figure some aluminum tubing and a little welding work and some set screws would do the trick. I will probably put some sort of heat shielding wrap on it and the intake, the buggers get hot quick and that cant by good for the air density inside the intake.
Rally_wgn is offline   Reply With Quote
Old 08-04-2006, 09:07 PM   #5
parker/slc/gc8fan
Member#: 46241
- RIP
SDF-1
It makes 7 hp to the wheels. afaik
parker/slc/gc8fan is offline   Reply With Quote
Old 08-04-2006, 09:26 PM   #6
EJ1
Member#: 61296
My black plastic piece broke too. I taped in and put it back in there.
EJ1 is offline   Reply With Quote
FS: 00-04 Cobb CAI, or WTT: Cobb for Stock dRu888 1993 - 2001 Impreza Specific Parts 0 09-08-2007 09:26 PM
Broken Cobb CAI into Ram Air! DrBoy01 Normally Aspirated Powertrain 13 08-04-2005 06:19 PM
WTT: Cobb CAI for ur Ganzflow CAI ommmjido Bay Area Impreza Club Forum -- BAIC 0 11-05-2004 03:55 AM
smell related to CAI broken hose, and question TSDScooby Normally Aspirated Powertrain 2 03-05-2002 11:07 PM
Cobb CAI, Borla headers, Brullen cat-back, Unorthodox UD pulley, Cobb Spicy cams. yamarocket630 Car Part Reviews 2 12-21-2001 02:58 PM
