Welcome to the North American Subaru Impreza Owners Club Thursday July 2, 2015
Old 08-31-2006, 01:05 PM   #51
Sharky NRK
Member#: 29549
2003 WRX
I know I just got around to doing my solenoid install and my boost and fuel maps are all screwy, I just happened to have that log (3rd gear I think) from this morning and wanted to compare - but I will get a better 5th gear log and make a better comparison
Sharky NRK is offline   Reply With Quote
Old 08-31-2006, 01:59 PM   #52
Sharky NRK
Member#: 29549
2003 WRX
2648 4.7 3 99 30 0 11.9 34.4 12.9 23 0.6 97.5 2.4 11.94
3090 14.5 3.5 98 80 0 10.1 24.9 26.5 14 1.9 WGS. 2.9 10.08
3324 19.4 3.7 95 100 0 9.9 25.1 33.6 13 0.8 83.8 3 9.91
ok so there are snips from a too big to post 5th gear log at lunch
3.0v at 2648 at 4.7 lbs
3.5v at 3090 at 14.5 lbs
3.7v at 3324 at 19.4 lbs (where I chickened out because it was overboosting way past my 17 psi desired level - really need to do some more work with the GMBS)
PNP VF39
stock tmic
Old 08-31-2006, 02:10 PM   #53
cdvma
Member#: 21980
2002 PSM WRX (Sold)
2009 BMW X5
Cool. Yea a bit more volts and psi than the 29. One thing I forgot to do is record the air intake temperature on my first run. Its about high 80s down south I'm guessing?
cdvma is offline   Reply With Quote
Old 08-31-2006, 02:12 PM   #54
Sharky NRK
Member#: 29549
2003 WRX
yeah I didn't record them either, but I will snag an IAT reading on my way home for comparison purposes
I still know I can get some better spool and power out of her as my maps still have alot of tweaking they need
Old 08-31-2006, 02:13 PM   #55
Sharky NRK
Member#: 29549
2003 WRX
it is at LEAST 80 degrees outside for sure though
Old 10-07-2006, 08:15 PM   #56
BIGSKYWRX
Member#: 7958
09 GH B+
wouldn't have a 3rd gear pull by chance- looking into a vf23
TIA
Old 10-08-2006, 12:31 PM   #57
ride5000
Member#: 32792
2003 GGA MBP
12.9 / 105+
i could log you one...
ride5000 is online now   Reply With Quote
Old 10-09-2006, 07:10 PM   #58
BIGSKYWRX
Member#: 7958
09 GH B+
If you could that would be great I've got several 3rd gear pulls from oe turbo from ~ 2200-> redline, would be nice to see the 23 for a comparo. The more I look into the 23 the more it looks like it might be the "right one"
Old 10-09-2006, 10:40 PM   #59
Sharky NRK
Member#: 29549
2003 WRX
post up your stocker logs as well bigsky, just for comparison
Old 10-09-2006, 10:59 PM   #60
BIGSKYWRX
Member#: 7958
09 GH B+
Not in the same format, but the first is stock 11.5 psi @ 3000 rpms, the 2nd is uppipe/downpipe/muffler 13.5 psi @ 3000 rpms, the last is current 15.4 psi at 3000 rpms uppipe/downpipe/muffler/ecutek
Old 10-10-2006, 02:43 AM   #61
bObby
Member#: 66959
VF Engineer'd e46
M3 500hp club
but here are some dynosheets from the past to now.
this is from a year ago. tuned at Godspeed in Detriot, MI 265whp/250trq on a Dynapak dyno
this year. late spring. I had Tim from PDX Tuning tune my car.
Pump 93. 19-20psi 289whp/266trq on a Mustang dyno!
and now for Cam2 Race fuel. 24-25psi making 303whp/300trq.
this map is a lot of fun to use lol.
my mods are...
vf23 turbo
565cc sti pinks
APS DR625 FMIC
no brand uppipe
Buschur Racing turboback
MBC
walbro 255 fp
Perrin turbo inlet pipe
Turbo XS short ram intake
Turbo XS UTEC
and I think thats about it for the motor.
hopefully this will help let you know what your car can make with the vf23 turbo
bObby is offline   Reply With Quote
Old 10-10-2006, 03:19 PM   #62
ride5000
Member#: 32792
2003 GGA MBP
12.9 / 105+
as promised, a 3rd gear pull. first the data:
Code:
RPM	MAP	TPS	IGN	MAFV	WGDC	AFR	LOAD	MRP
1964	3.773	1.18	16	1.46	0	17.8	0.34	-10.927
1996	3.918	1.96	24	1.5	0	17.23	0.34	-10.782
1970	3.918	3.53	29	1.6	0	15.62	0.41	-10.782
1995	5.369	9.02	16	1.88	0	15.39	0.66	-9.331
1964	8.706	21.96	25	2.46	11.76	14.59	1.38	-5.994
2038	14.075	42.75	23	2.44	29.41	14.81	1.81	-0.625
2077	14.655	68.63	23	2.42	49.41	14.36	1.88	-0.045
2046	15.09	88.63	23	2.46	79.22	14.81	1.91	0.39
2084	15.235	100	23	2.46	95.69	14.13	1.94	0.535
2123	15.525	100	23	2.5	99.61	12.86	1.97	0.825
2213	15.816	100	23	2.52	99.61	13.09	1.97	1.116
2231	15.961	100	23	2.5	99.61	12.98	2	1.261
2249	16.251	100	23	2.56	99.61	13.09	2.03	1.551
2284	16.396	100	23	2.6	99.61	12.98	2.06	1.696
2370	16.686	100	23	2.58	99.61	12.63	2.09	1.986
2412	16.831	100	23	2.64	99.61	12.75	2.09	2.131
2430	17.122	100	23	2.66	99.61	12.98	2.13	2.422
2477	17.267	100	24	2.64	99.61	12.86	2.16	2.567
2547	17.557	100	24	2.72	99.61	13.21	2.22	2.857
2589	17.702	100	24	2.74	99.61	13.09	2.28	3.002
2597	17.992	100	23	2.74	99.61	13.09	2.28	3.292
2667	18.282	100	24	2.78	99.61	12.98	2.31	3.582
2703	18.427	100	24	2.78	99.61	12.86	2.34	3.727
2775	18.718	100	24	2.82	99.61	12.86	2.41	4.018
2814	19.008	100	23	2.9	99.61	12.86	2.47	4.308
2889	19.298	100	23	2.88	99.61	12.75	2.56	4.598
2931	19.588	100	23	3	99.61	12.75	2.63	4.888
2956	19.878	100	23	2.98	99.61	12.63	2.69	5.178
3027	20.459	100	23	3.08	99.61	12.29	2.75	5.759
3091	20.749	100	22	3.12	99.61	12.29	2.84	6.049
3161	21.475	100	22	3.14	99.61	12.17	2.94	6.775
3217	21.91	100	22	3.2	99.61	12.17	3.06	7.21
3299	22.78	100	22	3.28	99.61	12.06	3.22	8.08
3350	23.361	100	21	3.3	99.61	11.94	3.38	8.661
3442	24.522	100	20	3.4	99.61	11.71	3.53	9.822
3518	25.537	100	20	3.52	99.61	11.71	3.75	10.837
3588	26.843	100	19	3.58	99.61	11.25	4.03	12.143
3680	29.02	100	18	3.74	99.61	11.25	4.41	14.32
3755	30.906	100	17	3.8	99.61	11.25	4.84	16.206
3870	34.388	100	14	3.96	99.61	11.25	5.31	19.688
3974	36.565	100	12	4.04	99.61	11.25	5.47	21.865
4050	37	100	12	4.04	99.61	11.25	5.38	22.3
4153	37	100	13	4.02	99.61	11.25	5.28	22.3
4565	6.239	0	16	1.94	0	25.27	0.34	-8.461
4259	6.094	0	16	2.06	0	23.77	0.47	-8.606
and a little chart:
Old 10-10-2006, 03:32 PM   #63
BIGSKYWRX
Member#: 7958
09 GH B+
thanks- looks like about 3300+ it really comes on like a gang buster!
Old 12-16-2006, 01:51 AM   #64
WRXRallyBlue
Member#: 48831
2002 Protuned Wagon
Bugeyes Forever
3.10v ~99hp
3.30v ~122hp
How do you make this conversion?
WRXRallyBlue is offline   Reply With Quote
Old 12-16-2006, 07:51 AM   #65
ride5000
Member#: 32792
2003 GGA MBP
12.9 / 105+
convert mafv to air mass
assume 1lb/min = 10hp
it is a very rough rule of thumb.
Old 12-16-2006, 11:55 AM   #66
WRXRallyBlue
Member#: 48831
2002 Protuned Wagon
Bugeyes Forever
Thanks. And how do I convert maf v to air mass?
Old 01-01-2007, 08:42 AM   #67
ride5000
Member#: 32792
2003 GGA MBP
12.9 / 105+
recent 4th gear log:
http://forums.nasioc.com/forums/show...7#post16499327
CN: 1 bar at 3075rpms
Old 01-01-2007, 02:48 PM   #68
Strng1dah
Member#: 7053
13.1@104
Default vf39 for fun...
1 bar @ 2900
20psi @ 3432
3.0mafv @ 2534/7.2psi
3.5mafv @ 2970/16.6psi
4.0mafv @ 3522/19.8psi
vf39
txs tmic
APS Turbo Inlet
STi uppipe
Cobb DP
STi injectors
Code:
TSMP	RPM	PSIG	MAF	TPS	LOD	KN	SNB	SIG	IDC%	IGN	FMVL	BMV	MMV	WBO2
0	1969	0.2	2.5	100	10	0	16.1	34.2	9.5	22.9	-1.4	500	2.2	16.74
0.21	1976	0.6	2.4	100	10	0	15	32.4	10.1	30.3	-1.4	500	2.3	15.51
0.41	1984	0.8	2.5	99	10	0	14.8	32.1	10.8	30	-1.4	500	2.3	14.86
0.61	2005	1.5	2.5	100	10	0	13.6	31.9	11.1	29.3	-1.4	500	2.3	14.24
0.8	2028	1.9	2.5	100	20	0	14	31.5	11.3	28.8	-1.4	500	2.3	14
1	2042	2.1	2.5	100	20	0	13.6	31.1	11.8	28.5	-1.4	500	2.3	13.91
1.2	2049	2.3	2.6	100	20	0	13.3	30.7	11.8	28.2	-1.4	500	2.3	13.86
1.4	2063	2.7	2.6	100	20	0	13.1	30.4	12.1	27.5	-1.4	500	2.3	13.76
1.6	2091	2.9	2.6	100	20	0	13.3	29.8	12.1	27.1	-1.4	500	2.4	13.6
1.8	2114	3.1	2.6	100	20	0	12.9	29.6	13	26.7	-1.4	500	2.4	13.49
2	2113	3.3	2.6	100	20	0	12.7	29.8	13.1	26.4	-1.4	500	2.4	13.43
2.2	2131	3.5	2.6	100	20	0	12.9	29.8	12.8	26	-1.4	500	2.4	13.44
2.4	2146	3.5	2.6	100	20	0	12.8	30.4	14	25.9	-1.4	500	2.4	13.4
2.6	2166	3.7	2.7	100	20	0	12.7	29.8	13.5	25.5	-1.4	500	2.4	13.4
2.8	2187	3.9	2.6	100	30	0	12.7	29.8	12.9	25.2	-1.6	500	2.4	13.48
3	2210	3.9	2.7	100	30	0	13.1	30.7	13	25.1	-1.6	500	2.5	13.67
3.2	2226	4.1	2.7	100	30	0	13.3	30.4	13.5	24.6	-1.6	500	2.5	13.81
3.41	2249	4.3	2.7	100	30	0	13.1	30.3	13.4	24.5	-1.6	500	2.5	13.78
3.61	2260	4.3	2.7	100	30	0	13.4	30.6	13.8	24	-1.6	500	2.5	13.78
3.8	2267	4.5	2.7	100	30	0	13.3	30.5	13.9	23.9	-1.6	500	2.4	13.76
4	2276	4.5	2.8	100	30	0	13.4	30.4	14.4	23.6	-1.6	500	2.5	13.74
4.21	2291	4.7	2.7	100	30	0	13.1	29.8	14.6	23.1	-1.6	500	2.5	13.71
4.41	2311	4.7	2.8	100	30	0	13.4	30.4	14.4	23.1	-1.6	500	2.5	13.73
4.61	2330	4.9	2.7	100	30	0	13.2	30.4	14.6	22.6	-1.6	500	2.5	13.78
4.81	2349	5.1	2.8	100	30	0	13.4	30.5	15	22.1	-1.5	500	2.5	13.83
5.01	2369	5.3	2.8	100	30	0	13.2	29.8	15.2	22	-1.5	500	2.5	13.84
5.21	2385	5.3	2.8	100	30	0	13.1	29.8	15.5	21.5	-1.5	500	2.5	13.79
5.41	2401	5.5	2.8	100	30	0	13.4	29.8	15.6	21.2	-1.5	500	2.5	13.82
5.61	2418	5.7	2.8	100	30	0	13.1	29.8	15.9	20.7	-1.5	500	2.6	13.84
5.81	2413	5.9	2.8	100	40	0	13.1	30.4	15.8	20.2	-0.7	500	2.6	13.83
6.01	2434	5.9	2.9	100	40	0	12.5	29.6	16.3	20.1	-0.7	500	2.6	13.62
6.21	2449	6.2	2.9	100	40	0	12.8	29.1	17	19.9	-0.7	500	2.6	13.37
6.41	2471	6.4	2.9	100	40	0	12.5	29.2	17.2	19.6	-1.1	500	2.6	13.33
6.61	2492	6.4	2.9	100	40	0	12.2	29.1	17	19.6	-1.1	500	2.6	13.3
6.8	2498	6.6	2.9	100	40	0	12.8	28.5	17.3	19.4	-1	500	2.6	13.35
7.01	2493	6.8	2.9	100	40	0	12.3	28	18.2	19.2	-1	500	2.7	13.32
7.21	2511	7	2.9	100	40	0	12.1	28.1	17.7	19.1	-1	500	2.7	13.21
7.4	2534	7.2	3	100	40	0	12.1	27.7	17.8	18.8	-0.9	500	2.7	13.19
7.6	2567	7.2	2.9	100	40	0	12.3	26.7	18.5	18.6	-0.9	500	2.7	13.22
7.81	2592	7.4	2.9	100	40	0	12.7	25.2	19.3	18.3	-1	500	2.6	13.27
8	2606	7.8	3	100	40	0	12.3	25.3	18.6	17.9	-0.9	500	2.7	13.26
8.2	2630	8	3	100	50	0	12.4	24.9	19.4	17.4	0.7	500	2.8	13.19
8.4	2662	8.2	3	100	50	0	rich	22.8	21.1	16.8	0.9	500	2.8	12.91
8.6	2671	8.4	3	100	50	0	rich	21.9	21.1	16.7	0.9	500	2.9	12.63
8.8	2667	8.8	3	100	50	0	rich	21.3	21.6	15.8	1	500	2.9	12.58
9	2666	9.2	3.1	100	50	0	rich	20.7	22.7	15.6	1	500	2.9	12.54
9.2	2699	9.4	3.1	100	50	0	rich	18.9	23.4	14.9	1.1	500	2.9	12.42
9.4	2737	10	3.2	100	60	0	rich	16.8	24.7	14.1	1.2	500	2.9	12.28
9.6	2765	10.4	3.1	100	60	0	rich	15.8	25.3	14.1	1.4	500	3	12.15
9.8	2782	10.8	3.2	100	60	0	rich	15	25.7	14.1	1.4	500	2.9	12.07
10	2775	11.5	3.2	100	60	0	rich	15	26.6	14.1	1.4	500	3	12.02
10.2	2806	11.9	3.3	100	60	0	rich	14.6	28.4	14.1	1.5	500	3	11.82
10.41	2833	12.5	3.3	100	70	0	rich	17.7	29.6	14.2	1.4	500	3.1	11.62
10.61	2865	13.1	3.3	100	70	0	rich	17.3	30.3	14.2	1.4	500	3.1	11.62
10.8	2874	13.7	3.3	100	70	0	rich	16.7	31.8	14.1	1.3	500	3.2	11.62
11	2888	14.3	3.3	100	80	0	rich	16.3	32.6	14.1	1.6	500	3.1	11.56
11.21	2921	15.3	3.4	100	80	0	rich	16	33.8	14.2	1.6	500	3.2	11.47
11.41	2943	15.9	3.4	100	80	0	rich	14.2	35.7	14.1	1.3	500	3.2	11.37
11.61	2970	16.6	3.5	100	90	0	rich	13.8	36.6	14.1	1.4	185	3.2	11.32
11.81	3008	17.2	3.6	100	90	0	rich	14	37.2	14.1	1.4	185	3.2	11.29
12.01	3031	17.4	3.5	100	90	0	rich	13.4	37.3	13.9	1.4	185	3.3	11.2
12.21	3031	18	3.5	100	100	0	rich	13.4	37.2	13.9	1.4	185	3.3	11.13
12.41	3067	17.8	3.7	100	100	0	rich	13.5	40.2	13.6	1.4	185	3.3	11.12
12.61	3096	18.4	3.6	100	100	0	rich	13.3	41.3	13.8	1.4	185	3.3	11.04
12.81	3127	18.6	3.5	100	100	0	rich	13.3	42.1	13.6	1.4	185	3.3	11
13	3176	18.8	3.6	100	100	0	rich	13.1	42.9	13.4	1.4	185	3.3	11
13.21	3212	18.8	3.6	99	100	0	rich	13.4	41.1	13.2	1.4	185	3.5	10.9
13.41	3217	19.2	3.8	100	100	0	rich	13	43.1	13.3	0.9	185	3.3	10.8
13.6	3239	19.4	3.7	100	100	0	rich	13	47.7	13.2	1.3	185	3.5	10.74
13.81	3273	19.4	3.7	100	100	0	rich	12.7	43.2	13.1	1.4	185	3.6	10.66
14	3305	19.6	3.8	100	100	0	rich	11.6	50.5	13.2	1.3	185	3.6	10.6
14.2	3347	19.4	3.8	99	100	0	rich	12.5	45.7	13.2	1.2	185	3.6	10.57
14.4	3376	19.8	3.7	100	100	0	rich	12.3	52.2	13.2	1.2	185	3.4	10.56
14.6	3401	19.6	3.9	100	100	0	rich	12.3	48.1	13.2	1.1	185	3.6	10.57
14.8	3425	19.6	3.8	100	100	0	rich	13.4	45.6	13.2	1.1	185	3.6	10.55
15	3432	20	3.7	100	100	0	rich	11.4	51.3	13.2	0.9	185	3.5	10.49
15.2	3453	20.2	3.8	100	100	0	rich	11.3	57.3	13.2	0.8	185	3.6	10.5
15.4	3507	19.6	3.8	99	100	0	rich	11.6	49.1	13.2	0.8	185	3.7	10.53
15.6	3522	19.8	4	99	100	0	rich	11.7	50.6	13.2	0.8	185	3.5	10.56
15.8	3568	19.8	3.8	99	100	0	rich	11.7	48.2	13.2	0.8	185	3.6	10.58
16	3621	20	3.9	99	100	0	rich	11.2	50.5	13.2	0.7	185	3.7	10.51
16.2	3657	20	4	99	100	0	rich	11.7	50.5	13.1	0.7	185	3.7	10.49
16.4	3693	19.8	3.9	100	100	0	rich	12.4	49.7	13.2	0.7	185	3.6	10.5
16.61	3689	19.8	3.8	99	100	0	rich	12.4	52.8	13.2	0.6	185	3.6	10.51
16.8	3712	19.8	4	99	100	0	rich	11.8	52.5	13.2	0.7	185	3.7	10.56
17	3750	19.6	3.8	59	100	0	rich	12.5	58.9	13.2	0.4	185	3.6	10.43
Strng1dah is offline   Reply With Quote
Old 10-17-2007, 07:06 AM   #69
ride5000
Member#: 32792
2003 GGA MBP
12.9 / 105+
pull from yesterday morning. 3x 4.7mafv in a row!
http://forums.nasioc.com/forums/show...7#post19725437
Old 10-17-2007, 10:00 AM   #70
Rasmusson14
Member#: 77658
2004 ej207, ppg dogs
3" green, ITS ALL 4 SALE!
Posts like this ^^^^ get me all giddy! My vf23 was put on just a few days ago and will be getting tuned Nov. 10th. Thats an impressive pull ken! You will have a very strong setup when you get that ADI hooked up.
Rasmusson14 is offline   Reply With Quote
Old 10-17-2007, 11:49 AM   #71
TheMadScientist
Member#: 23717
2005 Big red
The thing is the only reason his setup is so strong.
HE TUNED IT HIMSELF. If you goto a "tuner" you will not see the same results.
TheMadScientist is offline   Reply With Quote
Old 10-17-2007, 12:00 PM   #72
ride5000
Member#: 32792
2003 GGA MBP
12.9 / 105+
good point. not only did i tune it myself, but i've BEEN tuning it myself for the last 4 years, and i'm still not done yet.
most tuners won't tune a customer's car to 25-26psig on a vf23, running the injectors static in the process, and bumping the rev limiter to 8200!
i really can't say i blame them, either--there are so many things that can go wrong when you're pushing multiple envelopes.
still, no matter what, the vf23 is a great little turbo... (thanks mark, you rock!)
Old 10-17-2007, 12:33 PM   #73
Rasmusson14
Member#: 77658
Trust me....I very aware that no tuner will make those sort of results. I was just commenting on the fact of just that, his tuning abilities and my admiration of his "outside the box" thinking. I'm looking forward to personally using the VF23 for the characteristics that ken has proven it capable of.
Kudos!
Old 10-18-2007, 09:58 AM   #74
TheMadScientist
Member#: 23717
2005 Big red
Kudos!
I wasn't being a smart ass. I was just stating that "most" normal people (Ken is not normal) will never see that performance out of a VF23.
Ken I am still amazed that that little turbo is still going strong. I think you are the third owner. Like everyone said "You will frag the compressor wheel at those PR's" LOL
Old 10-18-2007, 12:21 PM   #75
TheShad0w
Member#: 91925
2005 Saabaru 92-x
AWDTuning.com
Yeah pretty crazy - I'm especially amazed with a tmic.
TheShad0w is offline   Reply With Quote
Spooling Characteristics of the "20gs" tearitdown9 Factory 2.5L Turbo Powertrain (EJ Series Factory 2.5L Turbo) 119 11-24-2007 01:19 PM
TD05 16/18/20 Spool Characteristics wagonmasta Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 49 12-21-2006 06:36 AM
18G Spool Characteristics... Assassin4457 Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 117 10-13-2006 11:08 PM
info on turbo spool characteristics eatus ravenous Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 2 06-07-2006 09:46 PM
To those who upgraded their TMIC:Earlier turbo spool? Different spool characteristic? garie Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 6 12-07-2005 01:57 AM
