Canada Region Club
Go Back   NASIOC > NASIOC Regional Areas > Canada Region Forum > Western Canada
Old 08-04-2006, 12:05 PM   #1
Blew.by.u
Member#: 111513
06 STi APS SR56
CGM RocketRally Tuned
Question Ask the experts, volume 14
Its time to add a few extra Gauges or pods to the vehicle and I am in need of major guidance!
I see that there are really 3 styles of pods available…pillar mounted like what 06wrx has, the steering column type that is offered by the dealerships and the classic Triple meter pod where the clock is/was.
The main gauges that I will be looking for would be oil temp and boost mostly…Pricing seems to be ALL over the map! I’m confused, I have no starting point, I need help!
I do know what I don’t want…the pod must NOT squeak or rattle , must not look cheap and must blend into the existing dash with same color of lights etc…
What are you guys using? Suggestions, comments, pointers would be great…
Thank you
Matt
Blew.by.u is offline   Reply With Quote
Old 08-04-2006, 02:04 PM   #2
Jitenshakun
Member#: 61586
2005 STi
WI and all the goodies
If you want the perfect match then see if you can find Omori gauges. They make the STi cluster so the face and lighting are identical. However, they quit selling to NA and are mighty pricey. The next top pick for matching are the DEFI gauges (amber colour) but that rrquires the Defi link system and will cost $$$.
The "budget" option are Autometer and the red rubber bit on the bulb. You won't match your stock cluster, but the light colour will be close, they're accurate and cheap.
My suggestion for the 3rd gauge is an EGT as spikes in EGT are a poor man's way of knowing if you're running lean. As well, if something bad happens your EGT will usually spike well before your oil temp.
If you're not married to the idea of analogue gauges you could get a DTEC and custom up a mounting like Wombat.
-J
Jitenshakun is offline   Reply With Quote
Old 08-04-2006, 02:08 PM   #3
SubiePilot
Member#: 85245
V7 STi wanna be
Have a look at www.daddysscp.com They have guages that are a excellent match for the STi and don't cost a bundle. I have Auto meter and they are the budget option if you want cheap guages that look cheap autometer is the way to go. I have never been happy with my setup. One day I might change it.
And Jitenshakun 2006 STi???? You just messing with us.
SubiePilot is offline   Reply With Quote
Old 08-04-2006, 02:22 PM   #4
Wheelhop
Member#: 44263
04 WRX sedan
I wouldn't suggest the column type if you hate squeaks.
Wheelhop is offline   Reply With Quote
Old 08-04-2006, 02:45 PM   #5
Chp_Stix
Member#: 95195
1974 Rat Rod Bug
back and white
also if you only wanted to go with two guages autometer makes a 2 guages version on the pillar pod and you can get it painted.... ^^^ my pillar doesnt squeek so i dont know what your trying to say there cuz mine makes no noise.
Personally i had the clock set up and didnt like the fact that I had no clock any more.
Another option for color match is the mad dad guages they do a decent job of color match at a decent price and they do the black out like your stock guages.
DEFI have a matching start up sweep like your stock guages too but they cost the money.
I still havent found guages I like but I will keep looking mind you i personally dont care if they match my dash becasue I want a blue dash anyways.
Kris
Chp_Stix is offline   Reply With Quote
Old 08-04-2006, 02:46 PM   #6
Chp_Stix
Member#: 95195
1974 Rat Rod Bug
back and white
also you can paint the a-pillar pods to match I have the paint codes kicking around somewhere
Old 08-04-2006, 02:52 PM   #7
Jitenshakun
Member#: 61586
2005 STi
exact match to the pillar color:
SEM (paint brand) 15183 (color code) Warm Grey (color description)
exact match to the dash?
SEM (paint brand) MED SMOKE (paint color) 39163 (item number)
Old 08-04-2006, 02:58 PM   #8
02WHITEDUB
Member#: 96793
02 ProTuned TD04
Now with more clunks!
The 2 surrounding the instrument cluster is the closest to stock-looking.
I made some adjustments to mine to make it look factory:
Light sanding of entire surface
Filled in the 2 little holes with bondo + sanded smooth
Primed with flexible plastic paint
Painted with flexible black paint
People think it's OEM as the fit is PERFECT and it doesn't squeak or rattle.
02WHITEDUB is online now   Reply With Quote
ask the experts newsteve Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 1 04-24-2007 09:19 PM
Ask the experts, volume 15 Blew.by.u Western Canada 20 12-06-2006 07:04 PM
Asking the experts...Modifications Help mpadovano Factory 2.5L Turbo Powertrain (EJ Series Factory 2.5L Turbo) 2 11-01-2005 02:54 AM
Question about buying a Subaru, figured id ask the experts at NASIOC. stillnmax General Community 7 11-15-2004 10:20 AM
What is the instrument called that measures the cubic volume of an item? Gravel-Fun Off-Topic 14 07-18-2003 05:39 PM
