Old 08-04-2006, 02:56 PM   #1
redhead09
Member#: 121256
Default 04 sti messed up speedometer
my bro got an 04 sti, didn't have time to wash it by hand and it was dirty so he went through the carwash he picked the wash that also had underspray and the speedometer didn't work till the next day,he thought it had something to do with the underspray but then yesterday he went and got one withouth underspray and it it still isn't working. has this happened to any of you or have any idea wat is wrong?
redhead09 is offline   Reply With Quote
Old 08-04-2006, 03:36 PM   #2
joecerv
Member#: 110459
2006 Impreza 2.5i
Steel gray metallic
I am trying to read between the lines here.
Did the speedometer work when he got the car ?
Did not work after car wash and then worked again and then did not work ?
The speedometer cable could have come out.
Now, I am assuming worst case scenario here.
The previous owner took the cable out to keep the miles low.
Before selling car, puts cable back, not well I may say.
After taken ownership of car, cable comes out.
joecerv is offline   Reply With Quote
Old 08-10-2006, 04:49 PM   #3
redhead09
Member#: 121256
It worked when he got it, then about 2 weeks after he got it is wen he first took it to the car wash, right after the carwash it didn't work until the next day, but then after he got another carwash it finnally started working again but took about 3 days.
Old 08-10-2006, 05:14 PM   #4
Mulder
Trust no one
Member#: 11170
02 WRX
15 WRX/05 GTO
There is no speedometer cable. There is a vehicle speed sensor located on the transmission, the connector for it could be unplugged or loose or the wiring might be damaged. The sensor itself may also have failed.
Did the check engine light come on? It should if the speed signal from the sensor was interrupted.
There could also be a problem with the speedometer head in the dash, but that shouldn't be affected by external parts getting wet.
Old 08-10-2006, 05:42 PM   #5
overdose
Member#: 46399
0000 Knows nothing,
about nothing.
my speedo has "tweaked out" once or twice, figure the speedo head though since no cel... but 60k bumper to bumper so if it craps out soa will be buying a new one
overdose is offline   Reply With Quote
Old 08-10-2006, 06:00 PM   #6
joecerv
Member#: 110459
2006 Impreza 2.5i
Steel gray metallic
My apoligies for using the wrong term (speedometer cable).
The sensor Mulder wrote about can be seen from the passenger side down toward the transmission.
It could be loose.
Old 08-10-2006, 06:03 PM   #7
RexyGirl
Member#: 63616
1996 Volvo 850 Turbo
with mods :)
I don't know of a Subaru 60K bumper to bumper warranty, except the SAS warranty, but whether or not that would be covered depends on the plan you have. (It's still not a "bumper to bumper" warranty, technically)
RexyGirl is offline   Reply With Quote
Old 08-10-2006, 06:47 PM   #8
overdose
Member#: 46399
0000 Knows nothing,
about nothing.
subaru gold til 60k
Old 08-10-2006, 09:16 PM   #9
RexyGirl
Member#: 63616
with mods :)
subaru gold til 60k
Then, yes, it would be covered....as long as there wasn't an outside influence that cause it to go bad...
Your wear items still expire at 3/36, therefore making it not a bumper to bumper warranty (although you might already know that)
Old 08-11-2006, 01:36 AM   #10
redhead09
Member#: 121256
The Subaru dealership he bought it from told him they would fix a dent in the door but since he is only 19 they kinda have been saying we will call u but they nvr do so he had my dad call, so the told my dad they will fix the dent and have a look at the speedo also and get that fixed.
fs: 04 STI and up Utec sky_1982 Engine/Power/Exhaust 2 04-14-2007 06:02 PM
MY 2007 STI MESSED up nothingclub Factory 2.5L Turbo Powertrain (EJ Series Factory 2.5L Turbo) 14 03-29-2007 02:29 AM
04 STi Warranty up in 700miles. What turbo now? eviltwin Factory 2.5L Turbo Powertrain (EJ Series Factory 2.5L Turbo) 21 09-02-2006 04:11 PM
kids + block of wood + new STi = messed up new car SMOCKRAT Southern California Impreza Club Forum -- SCIC 42 11-05-2004 11:13 PM
messed up speedometer SpoolUp Electrical & Lighting 3 02-14-2004 09:53 PM
