Old 10-24-2001, 03:22 PM   #1
AaronB
Worst Mod Ever
Member#: 369
12 Vagon
Question Spark Plugs & Low Compression Engines?
I am going to be replacing my spark plugs (NGK's one heat range colder) soon and was wondering what affect the low compression build I went through would have on proper plug selection.
I am running low compression pistons 8.5:1 on my MY00. Should I run colder plugs as I did on the 10.0:1 stock build?
I haven't seen any posts or articles on low compression builds and spark plug selection. It may not even be a factor, but I thought I would ask.
If anyone has any info on this I would be happy to listen.
Thanks,
Aaron
http://www.AzScooby.com
http://www.ScoobyMods.com
AaronB is offline   Reply With Quote
Old 10-25-2001, 01:58 AM   #2
HndaTch627
Member#: 6551
'01 GC8 Dinged STM
'09 Concours 14 ABS Black
i would stay with one heat range colder. This will give you a pretty decent balance because you are not going to have the high combustion temperatures when off boost. Depending on how many PSI you plan on pushing you may still need to go 1 more heat range cooler.
jeremy
white tip spark plugs and low compression illegal2.2 Legacy Forum 1 08-13-2008 07:57 AM
Spark Plug & Compression 05 STI @ 65K (Pics) adeliciouspizza Factory 2.5L Turbo Powertrain (EJ Series Factory 2.5L Turbo) 10 06-25-2008 12:25 PM
Help! Spark Plug Popped out of engine! esbee Normally Aspirated Powertrain 27 08-12-2006 11:26 PM
Spark Plugs on 14k mile engine Jyik40 Normally Aspirated Powertrain 8 11-16-2004 07:03 PM
Ignitions, spark plugs & plug wires? scubaracer Normally Aspirated Powertrain 8 03-19-2002 04:17 AM
