Old 08-04-2006, 07:24 PM   #1
gnarwhale
Member#: 95976
2005 Impreza 2.5RS
Default Intake heat shield
quick question, i have a secretweapon intake from WeaponR and im wondering how to make a heat shield for it. I know it probably wont do anything, but should i make the shield all the way around the intake, or would that block the airflow still coming from the grill area of the car?
btw, the air filter sits right where the stock airbox used to be..so would the snorkle still bring air in?
thanks
gnarwhale is offline   Reply With Quote
Old 08-05-2006, 12:57 PM   #2
mranlet
Member#: 66304
98 RWD BG Outback
...with R200 and ITBs ;)
Snorkle will still bring in air if there is something for it to feed from.
I have an HKS DD 200mm filter where my Legacy's stock box was and I did the following:
-Completely remove airbox
-Bend a sheet of aluminum or plastic to bolt where the airbox bolted, blocking off the hot air blown at the filter from the radiator
-Cut a huge hole in the front of the snorkle, allowing it to scoop air upwards while driving
I only gained about 1whp (got a dyno at work), but response was noticbly sharper. Sucking in cold air is better than sucking in hot air. Do it.
mranlet is offline   Reply With Quote
Looking For used Subaru SPT intake Heat shield just the heat shield For 06 WRX Cobb2006WRXJR Private 'Wanted' Classifieds 0 11-13-2009 12:35 PM
Will the SPT intake heat shield work with APS intake? AFBeefcake Factory 2.0L Turbo Powertrain 1 04-23-2009 09:12 AM
FS:(AZ) SPT Short Ram Intake W/ Intake Heat shield satan's sled Engine/Power/Exhaust 14 12-05-2008 09:33 PM
SPT Short Ram Intake w/ Intake Heat Shield satan's sled SWIC Private Classifieds 4 12-01-2008 12:27 PM
SPT intake/heat shield and AEM V2 intake Subarudude2 Engine/Power/Exhaust 18 03-31-2008 11:59 PM
Message Board Statistics All times are GMT -4. The time now is 12:11 AM.
