Old 08-05-2006, 05:31 PM   #1
Kostamojen
Member#: 2272
2016 Commodore SS
Heron White
Question MAF "Replacement" Adapter...
Because of the kind of intake im using on my car (its a MAF designed intake but I have the 2000 MAP 2.5) I'm looking to find a MAF replacement section so I dont have to use the restrictive stock MAF that I dont actually need since its not pluged into anything...
So I'm curious if anyone knows if any shops sell them, or if anyone could make one.
I found this picture online which gives you a better idea of what i'm talking about:
I couldnt find any info about that one since the website that used to host that pic is defunct now or something.
Anyway, the measurements of it are 4 3/4" long, and the pipe is 80mm OD. A regular MAF adapter is only 3" in diameter and significantly shorter, so it doesnt really work...
Old 08-14-2006, 03:03 AM   #2
Kostamojen
Member#: 2272
2016 Commodore SS
Heron White
Update: I emailed the guy who had this picture on his website... Said he still has that adapter, so I'm buying it from him Pretty cool.
Old 08-14-2006, 03:05 AM   #3
reddevil
Member#: 64673
1990 Legacy wagon
goes 12.387 @ 116.5
The JECS maf is a marked improvement over the metal maf. But..... it still can be maxed out. I am hitting 4.5 volts at 10 psi and since I will be back at 13-14 psi by Tuesday, and expect to get to possibly 16 psi soon, I know I need a little more range in the MAF.
So......
If you look at the JECS maf, the opening at both ends is 3". But the intake side suddenly restricts to 2.5". I plan to bore this section out on a milling machine.
The catch is that the area that is restricted, is also smaller on the exterior, meaning that if you were to bore this out to the same diameter as the rest of the tube, you would cut All the plastic and the MAF would be rendered useless.
So I will be filling in the sections with epoxy first, and the plastic ribs will hold the end section to the main section. Then I will be able to bore away!!!!!
Old 08-14-2006, 03:06 AM   #4
reddevil
Member#: 64673
1990 Legacy wagon
goes 12.387 @ 116.5
Also, if you are going blow through, you need to fill the area around the MAF sensor insert with silicone to prevent pressure from reaching the electrical area of the MAF, since it will just eventually blow out.....
Old 08-14-2006, 04:56 PM   #5
Plays_With_toys
Member#: 82556
1996 Legacy L wagon
Are you plugging your intake tube into the stock airbox? If not I'd just put the filter on, snug it down and call it a day. If you are attaching to the stock air box, maybe you could just go to the junkyard, pull that MAF section, remove the sensor (maybe even turn it upside down to hide it a bit more). Probably a cheaper and easier to find solution.
Plays_With_toys is offline   Reply With Quote
Old 08-14-2006, 05:30 PM   #6
Kostamojen
Member#: 2272
2016 Commodore SS
Heron White
Thats exactly what I already have It took a bit of work to remove the sensor, and I had to epoxy the hole closed, but it still has a rather nasty restriction.
Ill post pictures when I get the adapter. Its from a 300zx kit of some kind btw.
P.S. I know its not really worth any horsepower or anything, but I figure i'd try it out. I have a couple of other stock intake setups and a cone filter w/ maf to fidle with too, so ill have some fun next weekend trying stuff out
Old 08-14-2006, 10:22 PM   #7
semaj
I'm sorry for apologizing
Moderatour
Member#: 113533
2006 Pathfinder
Off Road
I have a MAF adaptor from KartBoy coming shortly, that I no longer have a use for...anyone else need one?
semaj is offline   Reply With Quote
Old 08-14-2006, 11:08 PM   #8
Kostamojen
Member#: 2272
2016 Commodore SS
Heron White
Post it up in the for sale forums, or contact kartboy hes a nice guy and might be willing to help with a refund.
Oh and... No hijacking my thread
Old 08-14-2006, 11:12 PM   #9
FalconRS
Member#: 92913
2005 2.5RS Wagon
Crystal Grey Metallic
The question remains, why not just get a non-MAF intake right from the start?
FalconRS is offline   Reply With Quote
Old 08-14-2006, 11:14 PM   #10
Kostamojen
Member#: 2272
2016 Commodore SS
Heron White
Because...
I'm using a old 1.8/2.2 intake which is basically a CAI but its stock and wont get me in trouble if my hood gets poped during the current CA modified car crackdown craze.
fs: socal - hks type I bov, oem 07 bcs, 2 to 3 inch coupler, big maf sensor adapter Blackout713 Engine/Power/Exhaust 22 05-17-2010 12:06 AM
FS: Apexi Air Intake Kit w/ R60 MAF and Adapter for EJ20 confidentxfear 1993 - 2001 Impreza Specific Parts 8 10-25-2008 03:06 PM
MAF Filter adapter SubyNVA Normally Aspirated Powertrain 14 01-22-2007 10:42 PM
WTB: MAF sensor adapter WRCase TXIC Private Classifieds 0 04-16-2006 01:51 PM
Where to buy MAF filter adapter? supaflyTS Vancouver Impreza Club Forum -- VIC 2 06-07-2005 10:20 PM
