Old 08-05-2006, 07:06 PM   #1
breathinez
Member#: 79859
2002 384 whp
332.5 lbs
Default Need help .. How do you know your new turbo is getting oil?
I just did a vf22 pnp cc swap on my 02 wrx. I was wondering how do I know the turbo is getting enough oil? It seems to be running good. Not getting on it mayeb just to 4500 rpms or so. Just want to make sure I'm not going to fry it.
breathinez is offline   Reply With Quote
Old 08-05-2006, 09:07 PM   #2
dibblejr
Member#: 94070
05 LGT
Oil pressure guage, as long as you got everything hooked up you should be fine. You could also disconnect one of the Banjo bolts enough to have a small leak and turn the car over, oil should leak around the seal.
Glad you got your install done. VF22 is real nice turbo.
dibblejr is offline   Reply With Quote
Old 08-06-2006, 03:47 PM   #3
breathinez
Member#: 79859
2002 384 whp
332.5 lbs
Yeah it went over pretty well. A few hicups here and there. All the smoke burning off fromall the residue scared me a little.
How do you know your stock struts are shot? Rexer06 Brakes, Steering & Suspension 6 03-02-2008 09:57 AM
How do you know when the Turbo is shot. eatwrx Engine Management & Tuning 5 10-06-2004 12:35 AM
how do you know your FMIC is working great? slin02 Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 8 11-29-2003 10:33 AM
How do you know when EGT gauge is going bad? Jsunn Interior & Exterior Modification 1 07-16-2003 09:21 AM
how do you know your gears are going out on you? vile Transmission (AT/MT) & Driveline 1 03-21-2003 05:18 PM
