Welcome to the North American Subaru Impreza Owners Club Sunday August 28, 2016
Old 01-16-2007, 04:12 PM   #26
modaddict
Member#: 95840
sold to a good bud
awaiting next car
Originally Posted by bboy View Post
I have a picture of the drilling modification. I'll post it later today. If it works its becuase oil is being diverted down the extra hole in conjunction with the centrifugal force that is on it, instead of against it. Seems like it might help, but I think it's really hard to say. I'd rather see a non-cross-drilled crank where the oil is picked up from a central oiling bore that runs the length of the crank, or something like that.
bboy,
bumping an old thread for pics of the drilling modification....
modaddict is offline   Reply With Quote
Old 01-17-2007, 01:00 AM   #27
Homemade WRX
Member#: 33782
96 bastard child
search FIRST, then PM!!!
well for the oil pump, I should have one in about a week. It will shortly there after be disassembled with pics to follow.
Old 01-17-2007, 01:01 AM   #28
modaddict
Member#: 95840
sold to a good bud
awaiting next car
Does it have the "12" stamped on it? any part numbers?
Old 08-05-2007, 10:55 PM   #29
WJM
Guest
Member#:
My head is spinning.
I give up, I'll just buy the Spec C crank and oil pump....DONE.
Old 08-06-2007, 12:22 AM   #30
Homemade WRX
Member#: 33782
96 bastard child
ordered it from jap parts on here...got it right as I was leaving town for interviews in the Tampa area, so no time to mic it yet. I will be tearing down and working it over when I get home. So expect an update next wed or thurs.
Old 09-25-2007, 06:24 PM   #31
engineerx
Member#: 42614
0405 WRX STi/S2000
AspenWhite/Silverstone
I'm curious to see what oil pressure you are seeing with the 12mm.
stock crank or extra cross-drilled variety?
engineerx is offline   Reply With Quote
Old 09-25-2007, 09:05 PM   #32
Homemade WRX
Member#: 33782
96 bastard child
still waiting on a few bits to come in before the motor goes in the car...
I'm really wondering whether to use 1 or 2 shims...I'll probably just run 2 and see what the pressure is.
Better safe than sorry.
Old 09-26-2007, 06:22 AM   #33
saintluciascooby
Member#: 109527
1997 GC8 [email protected]
blue
I use two shims idle psi (hot engine0 75-80psi anything above idle (950rpm) the pressure is >120psi this is on an ej22t with oil squirters.
Jon
saintluciascooby is offline   Reply With Quote
Old 09-26-2007, 06:33 AM   #34
Optical NZ
Member#: 120463
quick question, how did you fill up the rear side of the oil relief?
Optical NZ is offline   Reply With Quote
What is the paint code for the middle of the oem 3 part rear lip (02/03) kogs Interior & Exterior Modification 0 04-10-2010 06:08 PM
So whos checked out the oiling system for sohc head VTsuby Normally Aspirated Powertrain 1 10-24-2009 12:03 AM
Oil Consumption at High RPM spoolinsuby Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 2 10-13-2005 06:16 AM
Modified EJ20/25 cranks for high rpm.... bugeyes Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 7 09-11-2005 07:27 PM
Oil weight for high performance cars Jon Bogert Normally Aspirated Powertrain 22 02-26-2001 12:36 AM
