Old 08-05-2006, 08:02 PM   #1
sekretskwirl
Member#: 112520
Default head bolt torque specs and pattern??
...putting fresh heads on my 2.5 swap today-saturday- and need the torque specs and special patterns they call for. thanks DANIELLE
sekretskwirl is offline   Reply With Quote
Old 08-06-2006, 05:42 AM   #2
Poweredbysnail
Member#: 74753
2003 Wrx 2.5Lw/gt30r
Team Snail
Are you going to use the Stock bolts or are you going to use head studs like ARP's. Because there is a difference in the way you do them both.
Stock one you: "This is strait from the Subaru Manual"
1. Apply a coat of engine oil to washers and bolt threads.
2. Tighten all bolts to 22ft-lb in alphabetical sequence, and then tighten all bolts to 51ft-lb in alphabetical sequence.
3. Back off all bolts by 180 degrees first; back them off by 180 degrees again.
4. Tighten the bolts (A) and (B) to 25ft-lb.
5. Tighten the bolts (C), (D), (E) and (F) to 11ft-lb
6. Tighten all bolts by 80 degrees to 90 degrees in alphabetical sequence.
7. Further tighten all bolts by 80 degrees to 90 degrees in alphabetical sequence.
Caution: Ensure the total "re-tightening angle" [in the two previous steps] do not exceed 180 degrees.
This is how I did my ARP Head Studs:
1. I put thread sealer on the threads that thread into the block.
2. Thread the studs in hand tight then give them a 1/4 of a turn with an alien key.
3. Put the head on and put oil on the threads and the washers.
4. Starting at 20ft-lb torque the nuts on the head stud down in the alphabetical sequence set by Subaru then go up in torque by 20 each time until you get to 80ft-lb in the alphabetical sequence
5. Let the head sit overnight come back in the morning and retorque the nuts at 80ft-lb.
That all you have to do for the Head Studs
The alphabetical sequence.
Poweredbysnail is offline   Reply With Quote
Old 08-06-2006, 01:07 PM   #3
sekretskwirl
Member#: 112520
Default ARP of course,
thanks for the response-can't find it on the disc we have...a new problem now thoughne stud would not seat all the way and now....it's stuck in the block-wont' come out or back off for nothin'! To get it out is gonna rip up the threads for sure-shop says the factory never properly 'chased' the threads to begin with in the one hole..... The block is basically ruined..there is no way were goin' to put a heli-coil in 'fresh' STI BLOCK...back to dealer is goes, thanks Danielle
Old 10-21-2007, 12:33 PM   #4
subajay
Member#: 89688
1996 audi a4
white pearl
subscribed
subajay is offline   Reply With Quote
Old 10-21-2007, 09:35 PM   #5
LiquidForce
Member#: 12811
2002 2.5l Wrx
517whp/516wtq (Stage pi)
the specs for the stock bolts are for an 02 WRX. The newer service manuals have different specs.
I would use these directions instead.
http://65.6.129.58/public/2005FSM.pdf
Edit. I didn't realize how old this post was. I guess by now the heads are on
LiquidForce is offline   Reply With Quote
Old 12-10-2013, 08:15 PM   #6
hellriderkc
Member#: 373967
2006 Legacy
white
thanks,info invaluable.i can see the end in sight.
hellriderkc is offline   Reply With Quote
Old 12-10-2013, 08:39 PM   #7
25rsti
Member#: 166324
Holy bump.
Old 03-02-2014, 10:54 PM   #8
RoyaleFoz
Member#: 369858
Midnight Black Pearl-O8V
El bumpo
RoyaleFoz is offline   Reply With Quote
Old 03-02-2014, 11:37 PM   #9
Paul
Member#: 56203
00 RSTI Coupe
Twin Scroll 2.5XTR EJ207
^ why would you bump this thread? Another person already did for no good reason and you saw fit to do it again?
head bolt torque specs pilfflip Legacy Forum 10 01-27-2016 08:38 PM
Rod and crankcase bolts torque specs ?? Sammidavis Built Motor Discussion 7 10-22-2008 05:22 PM
Head bolt torque and sequence on EJ25? Andrew Bacon Normally Aspirated Powertrain 0 02-24-2004 09:03 PM
Head Bolts & Cams Bolts Torque Specs Imprezd Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 3 03-20-2003 07:30 AM
Bolt torque spec, coilovers ????? Branwell Brakes, Steering & Suspension 5 10-19-2001 05:53 PM
