Old 08-06-2006, 02:46 PM   #1
desert pirate
Member#: 70033
use thesearchbutton
orotherswillcry
Default 100% stock vs. upgraded turbo dyno graphs
I would like to look at dyno graphs of stock subarus 2L, 2.5L whatever vs. thier upgraded turbo setup on the same graph so I can compare low end torque. So If you have a graph with a stock and modified turbo plotted together I would like to see it.
Thanks
desert pirate is offline   Reply With Quote
Old 08-06-2006, 04:14 PM   #2
verc
Member#: 41754
03 wrx
gt35r, 2.5L, meth
o_O
Desert pirate
use thesearchbutton
orotherswillcry
verc is offline   Reply With Quote
Old 08-06-2006, 04:47 PM   #3
theicewall
Member#: 70532
2004 WRX
In support of desert pirate, i have never seen a graph of bone stock vs a turbo upgrade. Most often its stage II td04 vs upgrade to vf34/16g, etc. Mostly because not a lot of people post their bone stock dyno numbers. He could have specified which turbo he has and which engine he is running and that would certainly have been better. People are to quick to be cold and give an antagonistic response on this site.
theicewall is offline   Reply With Quote
Old 08-06-2006, 04:50 PM   #4
NewSTI
Member#: 104420
05 GarageTuningSTI
BLK/Gold [email protected]
Thanks
I have never see any turbo on STI makes "GOOD" tq under 3000 rpm, i remeber there was a guy with 20g with about 200wtq at 3000rpm..however, my stage 2 made 370 flywheel tq at 3000 rpm and stock turbo.
I am not sure if i'm correct, but boost lvl is where u get tq from, so low end tq needs to = early boost , which means smaller turbo is easier to do so...or high compression..
this is stock turbo with stage 2 after ecutek
NewSTI is offline   Reply With Quote
Old 08-06-2006, 05:03 PM   #5
theicewall
Member#: 70532
2004 WRX
You just posted a crawford performance dyno graph though, which are almost always way too high because they use a wacked out correction value.
This is a factory 2004 wrx with only an uppipe worth about 10hp and earlier spool. The only one I could find on the site close to stock.
Old 08-06-2006, 05:33 PM   #6
NewSTI
Member#: 104420
05 GarageTuningSTI
i knew someone would come up and say crawford reads higher, but really not about the number, it's more about the curve....even if it only make 300 at flywheel, it's still more power than 2.0 i believe
Old 08-06-2006, 06:36 PM   #7
desert pirate
Member#: 70033
use thesearchbutton
orotherswillcry
Verc, I deffinately have used the search and have been sifting through MANY charts!
theicewall, yes it is true not many stock vs. upgraded turbo charts are posted but I know some are out there and would like to see them if some one has them hiding. I think at this point it is irrelevent what I am running, I am trying to gather data to make a better informed decision about what I would like to run. Thank you for your kindness.
Newsti, I think torque is more determined by airflow, say just for example turbo x makes 15psi(which equates to 300cfm) by 3000rpm and turbo y makes 12psi(which equates to 320cfm) by 3000rpm, well turbo y would make more torque.
If I had the data from one dyno on what a wrx or sti puts down stock, and then data of wrxs or stis with an assortment of larger turbos, I could call the stock turbos X, larger turbos that while made maybe less boost but more torque Y, and then turbos so large X torque was not made untill after say 3000rpm Z. This is the relationship I am after, I also have posts in 2.0 and 2.5L power but have not gotten anywhere. I am interested in finding the lose of low end torque point for both 2l and 2.5l turbo wise.
Old 08-06-2006, 06:59 PM   #8
Unabomber
👌 Big Ron 👌
Member#: 18062
on car parts so PM
me b4 j00 buy
May or may not help, but here are two results with pretty much identical "Stage 2" mods and a Deadbolt P&P stock WRX turbo:
Me with Cobb Stage 2:
Me with Ecutek custom tune:
Full mod list can be found in my Manifesto. Both plots are dynojet dynos.
Old 08-07-2006, 01:26 AM   #9
NewSTI
Member#: 104420
05 GarageTuningSTI
here we go, this might help
this is the dyno from crawford which they did on ESX STI, stock VS cp35 kit from crawford.
Old 08-07-2006, 01:50 AM   #10
desert pirate
Member#: 70033
use thesearchbutton
orotherswillcry
Thanks, I was able to find a TON of graphs on I-Speed and compare them, It was exactly what I was wanting, their comparison stuff was very usefull, many thanks to them I hope their data base keeps growing!
Dyno graph comparison - stock SOHC vs. stock DOHC Patrick Olsen Normally Aspirated Powertrain 41 07-09-2013 07:10 PM
2008 WRX Stock vs. Stage II dyno tuning Dyno Flash Proven Power Bragging 41 08-29-2012 10:05 PM
Stock 2010 LGT 6MT Dyno Graphs Innovative Tuning Proven Power Bragging 92 11-30-2010 09:10 AM
Help with turbo dyno graphs Unabomber Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 23 03-30-2006 08:48 PM
STI Dyno graph comparison vf39 vs DB td06-20g Thanks to Harman Motive! mitchwrx Proven Power Bragging 10 09-22-2005 12:37 AM
