Go Back   NASIOC > NASIOC Technical > Engine Management & Tuning > Other Engine Management
Old 08-06-2006, 03:18 PM   #1
STIGuy50
Member#: 122232
Default Xede Boost
Hey Guys
I recentely installed the Xede from Vishnu in my 2005 STI. The problem i have is that the boost is actually down about 2-3PSI. Has anybody else had this problem or know how to fix it? Any help would be greately appreciated
STIGuy50 is offline   Reply With Quote
Old 08-06-2006, 07:51 PM   #2
vaj
Member#: 59136
04/5 APRWidebody STi
Parts all over the state!
Well, unless something has happened in vishnu-land you need XMap version 2.x, a serial connection and then you can edit the boost table to get you to your preferred boost level. The Vishnu OTS maps for STi's are conservative. Additionally, since all cars are "individuals" to some extent, your boost map may need work to match your car.
Are you running the factory bcs?
vaj is offline   Reply With Quote
Old 08-17-2006, 03:25 PM   #3
xplane
Member#: 66152
04 wrx sti
blue
IIRC its recomended to do the 3/16 mod with xede, it will see boost quicker...
xplane is offline   Reply With Quote
Old 08-17-2006, 09:20 PM   #4
vaj
Member#: 59136
That works too.. As long as you aren't pushing more than factory boost. Anything higher and you may see some spiking depending on a number of factors specific to your car. Some STi's see the spiking, some don't.
XEDE Vishnu STi Stage 1 maps off Vishnu's website, boost map is wrong? STi City Factory 2.5L Turbo Powertrain (EJ Series Factory 2.5L Turbo) 14 02-03-2004 11:02 PM
How do you increase the boost on the XEDE? STi City Engine Management & Tuning 3 01-08-2004 05:44 PM
xede/utec or blitz sbc-id boost controller 709394 Factory 2.5L Turbo Powertrain (EJ Series Factory 2.5L Turbo) 3 10-05-2003 08:51 AM
XEDE & boost control EJ20K Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 16 06-27-2003 11:04 AM
dual solenoid UTEC or XEDE boost control DjRez4 Engine Management & Tuning 5 03-10-2003 05:55 AM
