Welcome to the North American Subaru Impreza Owners Club Friday December 2, 2016
Old 08-06-2006, 04:29 PM   #1
MPtyza
Member#: 50824
1993 Impreza L
Rally blue #74F
Default OBDII codes
I've got two check engine codes that just will not go away. I've cleared them out many many times and they still return. So I decided to take the time to ask what I can do about them. I'm not used to the OBDII thing. All my previous cars were OBDI and my only other OBDII car was a 95 neon that I could check codes without the special scanner. These codes are from my '96 Brighton AWD coupe.
P0500
VSS A Malfunction
P0505
Idle control system malfunction
The car idles fine and my speedometer works perfectly normal so I'm a little confused here. What would I have to replace to get them to stop coming back?
Thanks in advance.
MPtyza is offline   Reply With Quote
OBDII code P1591? Slowpokewrx Engine Management & Tuning 3 01-15-2003 12:21 AM
Hey Karl OBDII code Revision Mid West Subaru Owners Club Forum -- MWSOC 4 10-23-2002 12:41 AM
OBDII Codes, may be usefull FuZZyLoGiC Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 8 05-09-2002 06:49 PM
OBDII Codes, may be usefull FuZZyLoGiC Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 0 05-09-2002 03:34 PM
