Old 08-06-2006, 04:18 PM   #1
smackedownz
Member#: 84841
2010 WRX
Default stock BCS questions
Ok, so I think my stock boost solenoid took a crap because I cant boost over like 12 psi on my vf30 with my 2.5 map. All hoses and stuff have been checked so its really the only thing left. My question is can I just swap in a new solenoid from any wrx 02-05 or does the year matter? Im going to get a protune on it but it sux only putting down 220whp because of such a small problem. How hard is it to swap in a new solenoid?
smackedownz is offline   Reply With Quote
Old 08-06-2006, 04:25 PM   #2
hoffmanEstates
Member#: 122043
04 wagonier
psm
Lightbulb
it at the T from the turbo is ur solenoid
hoffmanEstates is offline   Reply With Quote
Old 08-06-2006, 06:47 PM   #3
smackedownz
Member#: 84841
2010 WRX
bump^
Old 08-06-2006, 07:13 PM   #4
firebox40dash5
Member#: 107361
Now, with 100% less
trunk space!
Yes you can just put a new one in. PM if you want one, I took mine out at about 35k to use a Prodrive solenoid. I'll give it to ya for my gas money to Cary. But first double check all the hoses, and make sure the restrictor is in the hose from the compressor aoutlet to the T fitting.
Edit: I'll also accept the aforementioned beer from your other thread!
firebox40dash5 is offline   Reply With Quote
Stock STI Springs, Stock BCS , Stock Intercooler Elbow FunSTI619 Engine/Power/Exhaust 3 12-01-2009 07:51 PM
stock bcs and stock air box/or injen cold air 02 wrx roar Engine/Power/Exhaust 5 09-21-2009 10:15 PM
Hallman Pro MBC, Stock bcs, Stock BPV ryansport22 Engine/Power/Exhaust 3 05-30-2009 08:02 AM
IL: stock sti injectors (sidefeed), stock BCS, short ram intake, and more STiGMATA Engine/Power/Exhaust 14 10-19-2008 11:22 PM
STI Intercooler, 05 WRX Coil Packs all 4, Stock BOV, TXS Racing BPV, Stock BCS mrtrex Engine/Power/Exhaust 11 03-30-2008 07:34 AM
Message Board Statistics All times are GMT -4. The time now is 02:05 AM.
