Old 08-06-2006, 05:33 PM   #1
farrell
Member#: 47746
2000 Impreza 2.5 RS
silverhorn
Default Engine Problems on 2.5rs
Sooo my car needs some maintance. It feels like its choking, for lack of a better word, when I step on the gas hard. Most of the time it feels like the engine kicks back in as I get into 5k RPM, but some times it works right all the way through. Also, it may just be a coincidence but my Air conditioner seems to go on and off as I drive, blowing normal air and then cold air, when its soposed to obviously be all cold.
Recently it has been brought to my attention that a cylinder may not be running and that I should check the spark plugs and spark plug wires. Does anyone have any other ideas on what I should check out for the first problem? I plan on checking that out on tuesday, but could that also be the problem for the AC? Thanks
farrell is offline   Reply With Quote
Old 08-06-2006, 05:46 PM   #2
hatchbuilder
Member#: 102562
It sounds like a bad ground maybe? Check all your electrical connections etc. Have you installed anything recectly that you had to unhook, splice into or otherwise take apart your engine bay for? That might be it. Check your plugs and wires too though but the presence of other electrical glitches makes me think there is something else going on.
hatchbuilder is offline   Reply With Quote
wtb: ej25 sohc engine 99-01 2.5rs engine blueGC MWSOC Private Classifieds 0 04-05-2008 08:37 AM
Engine fan stoped wroking on 2.5rs mmmprza Engine Management & Tuning 2 11-11-2003 06:15 PM
engine fan stoped working on 2.5rs mmmprza Electrical & Lighting 1 11-10-2003 10:50 AM
2.0l Legacy Turbo Engine in a 2.5rs Audipwr1 Normally Aspirated with bolt-on Forced Induction Powertrain 9 09-27-2001 04:34 AM
engine swap into 2.5rs Silver_Fox General Forum Archive 1 03-26-2001 07:04 PM
