Old 08-07-2006, 12:42 AM   #1
G.Subramaniam
Member#: 64528
Default Question on NA vs Turbo fuel efficiency
Am I correct in assuming that since Turbo cars need a rich Fuel mix, they need to run AFR around 11, vs NA cars that can run around 14
This should make NA cars much more fuel efficient
G.Subramaniam is offline   Reply With Quote
Old 08-07-2006, 12:43 AM   #2
reddevil
Member#: 64673
1990 Legacy wagon
goes 12.387 @ 116.5
More power = more fuel. 600 hp NA monsters eat more fuel than 400 turbo monsters.
Old 08-07-2006, 08:31 AM   #3
Master2192
RIP 10/12/83 to 02/10/08
Member#: 83254
98 2.5 RS
04 WRX
First, turbo cars can run 14.7 (stoic) just as much as a N/A car. Its not the AFRs that make them inefficient, its that they have a exhaust restriction (turbo) and run a low compression ratio.
An all out N/A car will run around a 12-13 AFR anyway, thats not much better than a Turbo car either. But that is full throttle, which you shouldn't be doing if you are worrying about fuel efficiency.
What Red Devil said was right though.
Old 08-07-2006, 04:28 PM   #4
G.Subramaniam
Member#: 64528
Does the WRX / GT give less mileage than the RS, and by how much
Does increasing compression increase mileage, and by how much
Old 08-07-2006, 06:00 PM   #5
Master2192
Member#: 83254
98 2.5 RS
04 WRX
1. Yes, especially in the city. But on the highway the 04 WRX gets only 1 mpg less than my 98 RS. My RS cruises at about 500rpms higher than the WRX and still gets better mileage.
2. Increasing compression ratio raises the Engines Thermal Efficiency. IIRC it continues to increase until a 19:1 compression ratio. There was a graph inside one of the E85 threads from the EPA that showed this. Raising thermal efficiency means more of fuel gets turned to motion instead of just heat.
The RS should always get better fuel mileage than the turbo models, mostly because of compression ratio.
increasing turbo fuel efficiency moonzie Baja Forum 5 06-12-2007 12:36 PM
NA Vs. Turbo ferretboy Normally Aspirated Powertrain 10 07-28-2002 04:34 AM
Turbo fuel efficiency question driver8 Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 8 10-19-2001 08:38 AM
NA vs. Turbo MINDGAME Normally Aspirated Powertrain 12 06-23-2001 11:20 PM
NA vs. Turbo MINDGAME Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 13 06-21-2001 09:19 PM
