Old 08-07-2006, 12:56 AM   #1
SilverWRX500
Member#: 106567
04 EJ207 20g
Default Quest for 600 AWHP
Starting the journey for 600 Awhp. i have started the build...
2.5 block
Cosworth Heads
Cosworth Cams
JDM Crank
35R 82 trim
Anyone have any advice for the build and/or suggestions or parts to use?
SilverWRX500 is offline   Reply With Quote
Old 08-07-2006, 01:01 AM   #2
VTsuby
Member#: 81369
2007 STI
names like mahle, manely, del west, carillo, and arp come to mind
VTsuby is offline   Reply With Quote
Old 08-07-2006, 04:48 AM   #3
kp05sti
Member#: 80973
the 1.06 A/R 35r would be a better bet for 600whp
kp05sti is offline   Reply With Quote
Old 08-07-2006, 09:44 AM   #4
pux888
Member#: 8356
02 STi swap
12 WRX limited
you might as well by the Cosworth crank while your at it.
pux888 is offline   Reply With Quote
Old 08-07-2006, 09:52 AM   #5
Junior2JZ
Member#: 64908
10.8 [email protected] GR+
9.1/157mph 2015 STI
Yup.. and rev the motor ... 600whp shouldnt be that hard with a good engine and some support mods.
Junior2JZ is offline   Reply With Quote
Old 08-07-2006, 10:01 AM   #6
SloRice
Member#: 44351
2004 Mitsubishi Evo
701whp [email protected]
Pistons, head studs, 35R .82, race gas and 100 shot of nitrous.
I just made 505 with this setup without the nitrous.....on a Mustang Dyno. Put it on a Dynojet or Dynapak and that number goes up considerably.
SloRice is offline   Reply With Quote
Old 08-07-2006, 10:23 AM   #7
traction issuez
Member#: 86559
2005 RS Wagon
why not gt40r? it's more than capable. if you really want 600 to the ground i would sugguest gt40r its just more practical - look at hydra's website, gt35r+1.06 and fully built heads etc made 590, with a gt40r your built block is the best way to go.
http://www.elementtuning.com/whatittakestomake590hp.htm
traction issuez is offline   Reply With Quote
Old 08-07-2006, 10:50 AM   #8
burnin4
Member#: 59764
10 sec STi
10 sec Z06
I'd shoot for a qtr mile ET or mph instead of the "600whp." It'll only be 600whp on one dyno, since they all read different. I would definitely get the 1.06 35r if you're looking for that kind of hp. I'd also get some equal length headers, and a small shot of nitrous 50-75, and lots of race gas. You're also gonna need an adequate fuel system, 1000cc injectors and rails, and either dual walbros or an external setup. What kind of tranny and clutch do you plan on using? I think you can get away with a mid/upper 500's with the 2.5, anything higher starts to more challenging.
I hope you have 15k+, cause you're gonna need it. Good luck!
burnin4 is offline   Reply With Quote
Old 08-07-2006, 11:02 AM   #9
EVOTHIS
Member#: 66822
i dunno if id try it on a usdm 2.5. You should look into a crawford 2.65L. It will make getting to your goal so much easier
EVOTHIS is offline   Reply With Quote
Old 08-07-2006, 11:10 AM   #10
SuperSTI
Member#: 67182
2004 Subaru STi
11.0 @ 128mph - 93/Meth
AutoMasters STi made 630whp on a dyno dynamics on there own reflash on just 28psi. I think its makes more than that now still on stock ecu. I saw the car. Insane!!!! Thats well over 700whp on a dynojet
+1 automaster
http://www.iwsti.com/forums/showthread.php?t=57868
http://forums.nasioc.com/forums/show...ght=automaster
SuperSTI is offline   Reply With Quote
Old 08-08-2006, 07:56 AM   #11
mokujin22
Member#: 112450
2002 Silver Bug-eye
30 mpg 2000 Neon...Hi!
Alcohol Injection will help you not blow yourself up.
mokujin22 is offline   Reply With Quote
Old 08-08-2006, 05:05 PM   #12
700hp
Member#: 104164
'95 Impreza 800+hp
9.1 152mph
the car you speak of is my car. A little while later with a few more mods it made678whp.
It made 590whp with the kingpin 35r kit ( 1.06 ) on the stock exhaust manifold. Also this was with 272 non AVCS cams, 1000 cc injectors ( although it took 100% duty cycle to make that power ) no nitrous, Also stock crank. Just make sure you go with big valves, big cams, porting, pistons, and rods.
I found that the 1.06 housing spools slowly so if you want to drag race than you either need to spray it or go with a smaller housing (my best time was a 10.9 @ 138 because I couldn't keep boost between gears). However if you want high power #'s and like to freeway race than this is the housing for you.
I highly doubt that you really need the 40r.
But then again i'm sure someone else will have a different opinion.
Good luck
Alex
700hp is offline   Reply With Quote
time for 300 AWHP flyingtaco Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 56 04-04-2010 03:42 AM
Formula for converting awhp into bhp The Blue Pilot General Community 24 11-29-2007 01:11 PM
Looking for 600+awhp! bloopsta26 Built Motor Discussion 79 09-05-2007 01:14 PM
500-600 Awhp MB38 Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 41 12-28-2004 10:47 AM
Kings Quest I & II an Quest for Glory remade + free dl! soundwave Off-Topic 19 09-15-2003 05:56 AM
