Old 08-07-2006, 08:50 AM   #1
JamiePasson
Member#: 33909
Default 2.2.valve tap...
Hello,
I posted last week about the 2.2 valve tap. You guys replied about pulling the lash adjusters out and refilling them. I did this, It WORKED! kinda... It is defintely better than it was, however, the tapping still is there. Not near as bad, and it comes and goes, but still there. Is there any chance that the small "O" rings around the lash at fault, letting oil past them?
Thanks,
Jamie
JamiePasson is offline   Reply With Quote
Old 08-07-2006, 10:52 AM   #2
sketron13
Member#: 116158
2005 Legacy GT wagon
Just make sure you are using the right type/viscosity oil and changing it regularly. Also, keep the oil level full.
sketron13 is offline   Reply With Quote
Old 08-07-2006, 11:26 AM   #3
JamiePasson
Member#: 33909
Just changed it using 10 W 40 which I have used in every sub I have owned except the 88 Turbo. (which totals 11 so far.)
Old 08-07-2006, 04:06 PM   #4
petregeus
Member#: 42420
1996 Impreza LX
If changing the HLA worked for you, that's great.
Did you verify your old adjustor was bad?
I had the same problem and this worked only for a few miles. I'd suggest substituting a quart of Rislone at your next oil change. You could also spend a little more money and buy AutoRX. (I happen to be on my 2nd AutoRX flush cycle right now, and have not had any tapping whatsoever for a few thousand miles now.)
Good luck.
petregeus is offline   Reply With Quote
Old 02-20-2013, 09:00 AM   #5
car_boy_16
Member#: 70279
1989 Prelude Si 4WS
Phoenix Red
What is the actual PART number for the HLA O-rings??
I've been searching everywhere and can't find anything except for everybody and their grandmother casually saying "replace the O-rings with new ones" but not once have I seen anybody post a part number or a link so I can actually buy them.
Very frustrated right now Anybody know the part number for the HLA O-rings so I don't have to buy new HLAs?
car_boy_16 is offline   Reply With Quote
Old 02-20-2013, 10:01 AM   #6
13subes
Member#: 180426
This is a WAY old thread. I never posted what fixed my problem. When I pulled the rocker shafts off, there was a small aluminum shaving blocking the oil port which fills the rockers thus starving the lash adjusters for oil. Cleaned this out, refilled the lash adjusters and reassembled. Worked great for a LONG time. Then it happened again, SAME problem. I repeated the above procedure and have never looked back. Problem solved. that was 100,000 miles ago.
Jamie
13subes is offline   Reply With Quote
Old 02-20-2013, 10:20 AM   #7
Jessekrs123
Member#: 236927
2015 BRZ, 93 Legacy,
1984 BRAT
Good find^^^
Those small oil galleys do like to get plugged up rather easily.
Car_boy, go to a local Subaru dealer or call one up. They should be easily able to tell you the part numbers for the HLA o-rings.
Jessekrs123 is offline   Reply With Quote
Old 02-20-2013, 11:30 AM   #8
car_boy_16
Member#: 70279
1989 Prelude Si 4WS
Phoenix Red
Haha Jamie, well then I guess it was good I posted in your old thread -- now we have even more helpful information. I will be removing my rocker assembly to check my ports closer.
Thanks Jesse, I will call them and see if they have the O-rings, and I will -- for what may be the only part # posting of them on here -- post the numbers in this thread if I get them.
Cheers, guys.
Old 02-26-2013, 07:46 AM   #9
framer7781
Member#: 198386
1998 Coupe
I had bad lifter tick in my old legacy. I checked all my HLAs and nothing. Turns out my oil pump was bad. The engine wasn't getting the proper oil pressure and the oil was getting air bubbles in it not allowing the HLAs to stay full.
framer7781 is offline   Reply With Quote
Old 02-26-2013, 12:35 PM   #10
franklinstower
Member#: 263885
89 Westy
HLA O-Rings: Part # 13396-AA000
franklinstower is offline   Reply With Quote
valve tap on a 2.2 JamiePasson Normally Aspirated Powertrain 11 08-03-2006 12:16 PM
2.2 valve tap JamiePasson Service & Maintenance 0 08-02-2006 03:53 PM
valve tap? 5zigenwrx Southern California Impreza Club Forum -- SCIC 2 02-13-2004 11:45 AM
Valve tap?!? SoLo OnE Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 5 02-11-2004 12:08 AM
Valve tap??? JaBooo Normally Aspirated Powertrain 10 12-03-2001 08:12 PM
