Old 08-07-2006, 08:20 PM   #1
jason bouchard
Member#: 99239
Default ewg dp questions on tuning
ok i have an 06 sti, with a cat-back
i have but didnt install a UR uppipe with a 38mm tial EWG
and a helix dp
if install the dp and the ewg can i run it untuned ?
( the wg spring is set to 1 bar(14.5 psi) which is stock for an sti
will i get boost spiking ?
( i was thinking if i get the stock internal wg closed ( extra spring, or welded shut) and have the EWG to work, i can really overboost ( boost spike) can i ??
2nd if and when i get EM ( im lookin at cobb accessport) is there any downloadable tunes for tbe and ewg on an otherwise stock car ?
thanks
sorry if my questions are alittle crappy, im new with this, and i want to learn, i am not a noob though, but a noob with subaru more or less ; )
jason bouchard is offline   Reply With Quote
Old 08-08-2006, 07:22 PM   #2
jason bouchard
Member#: 99239
bump, help a guy out
Old 08-09-2006, 12:31 AM   #3
Christian.
Member#: 87604
We (Cobb Tuning) have published a tuning guide and a document which explains how you can set up the stock boost control system to work with an external wastegate. Tuning EWGs is very easy to do once you understand how the closed-loop boost control system works. E-mail me [email protected] and ask for the tuning guide, worksheet, and document about the stock boost control system in the Subject:
Take care,
Christian.
Christian. is offline   Reply With Quote
Old 08-09-2006, 12:18 PM   #4
Ben-EcuTeK
Member#: 57867
1999 Volvo
Ben-EcuTeK is offline   Reply With Quote
Old 08-09-2006, 03:27 PM   #5
Freon
Member#: 88322
2009 BMW 135i
I'm running a 4 port Grainger solenoid now with a reflash to control my dual port external gate. It works fine, but needed duty cycles are very low (30-40% steady state) and it requires some tweaking of the dynamics maps as well.
I think the factory ECU if tuned properly is plenty smart to control any single PWM system. Unless your aftermarket unit has two independent PWM outputs I don't think you're going to gain much.
Any change of solenoid or swapping to an external gate would require retuning.
Freon is offline   Reply With Quote
Old 08-12-2006, 05:38 PM   #6
jason bouchard
Member#: 99239
i did the install and i was over boosting, so i took the line out that has the brass "pill restictor" and replaced it with a reg line, and now im boosting perfect ( 1 bar, 14.5)
because of my 1 bar wastegate spring, everythign is running perfect and faster ( lots of low end tq) my tuner(andy from xotic motorsports) said its fine and safer then just running a dp untuned so its like a stock car with catless dp/exhaust and and ewg
car feels great and its Fing loud !!!
thanks for everyones help, i hope this helps someone else down the road . .
feel free to pm me with any questions
4 inch DP questions on sti. evol04gt Newbies & FAQs 10 09-20-2008 01:51 PM
DP question on 16g set up! subyduby Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 17 04-30-2008 12:41 PM
Question on Tuning WRX w/ VF-39 Sp00L AccessPort 7 01-23-2008 06:42 PM
Question on tune 94'325is Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 3 12-04-2006 08:37 PM
Question on Tuning a UTEC with a EBC... samh22a Engine Management & Tuning 3 02-09-2004 11:45 PM
