Old 08-08-2006, 08:09 AM   #1
speedyHAM
Member#: 48377
1996 Gutted, built
XP class Impreza L
News Want to get better gas mileage???
Too bad, there's nothing you can do.
http://www.cnn.com/2006/TECH/science...ion/index.html
I love the magnet company response.
speedyHAM is offline   Reply With Quote
Old 08-08-2006, 08:10 AM   #2
HOV
Member#: 64632
IBmythbustersepisoderecaps
[WTLW]If you just drive the speed limit and don't play boy racer at every stoplight, you'll gain a few MPG[/WTLW]
HOV is offline   Reply With Quote
Old 08-08-2006, 08:15 AM   #3
vapore0n
Member#: 21356
2017 Toyota Corolla
Limited, LBP, ABP, TTD, I
what? the turbonator works. Put two inline to double the efficiency!!
vapore0n is offline   Reply With Quote
Old 08-08-2006, 08:35 AM   #4
teh Phil
Member#: 24888
Man, I wish I was a professionally trained magnet installer.
teh Phil is offline   Reply With Quote
Old 08-08-2006, 08:55 AM   #5
wyn525i
Member#: 27986
Maybe someday, maybe, you can have that skill.
wyn525i is offline   Reply With Quote
Old 08-08-2006, 08:58 AM   #6
The Enemy
Member#: 12851
The Enemy is offline   Reply With Quote
Old 08-08-2006, 09:07 AM   #7
plunk10
Member#: 32342
13 BubblePrius
compressed air might increase your fuel economy (higher tire psi). that's about it.
plunk10 is offline   Reply With Quote
Old 08-08-2006, 09:11 AM   #8
Chuck H
Member#: 20442
There's lots you can do, but unfortunately, it's all common sense stuff, instead of miracle scientific breakthroughs like people are hoping for.
Keep your tires properly inflated, slow down and drive the speed limit, get rid of your land yacht and drive a lightweight vehicle with a small motor. It's pretty basic stuff.
I guess gas prices haven't hit my threshold of pain yet, though, because I'm still not ready to trade in my relatively inefficient WRX for a hybrid or tiny econobox. I'll pay the extra $$$ for the smiles the Subie gives me on a daily basis!
Chuck H is offline   Reply With Quote
Old 08-08-2006, 09:33 AM   #9
Master2192
RIP 10/12/83 to 02/10/08
Member#: 83254
98 2.5 RS
04 WRX
Actually, boost will increase fuel mileage as well...at low rpms. There was another one of those fuel mileage debates in general and this Article came up.
http://www.roadandtrack.com/article....rticle_id=1820
It seems to work, I shift at 2500 rpms but give it plenty of throttle (ie. almost WOT). Works on both the WRX and my RS.
Old 08-08-2006, 12:37 PM   #10
Midwayman
Member#: 1997
2006 Acura TL 6spd
STMGM6 alumni
ITs not boost. That raises your BSFC, and lowers your fuel mileage. But full throttle at low rpm is the way to go. It make your engine more volumetrically efficient. No throttle plate restriction to increase pumping losses,etc. The key is that you have to short shift.
Midwayman is offline   Reply With Quote
Old 08-08-2006, 12:44 PM   #11
hotass6gt
Member#: 109315
89 Mazda MX6 GT
Blaze Red
my 2.2 gets 23mpg
hotass6gt is offline   Reply With Quote
Old 08-08-2006, 05:09 PM   #12
plunk10
Member#: 32342
13 BubblePrius
<---30-32 mpg
0-60 in 6.5
but only 2 seats, and hardly any trunk FTL
Old 08-08-2006, 05:14 PM   #13
Master2192
Member#: 83254
98 2.5 RS
04 WRX
BSFC will be based off if you are running rich. With the ultra low compression of a turbo motor, it needs a good amount of boost to raise that and increase engine efficiency. I don't know how the WRXs run, but my RS stays stoic until about 95% throttle at these low of rpms. You may be able to pull off stoic with the 04-05 WRXs at these low rpms and mid to high boost. However a 2 liter low compression engine is pretty gutless below 2500 rpms, even at full throttle.
Old 08-08-2006, 05:26 PM   #14
Janq
Member#: 33246
I saw this on CNN earlier today, the magnet part cracked me up.
Chuck H is on point about tire pressure (!).
Just this past Sunday I was chatting with a guy I know here whos only means of transpo is a scooter. Last spring I saw him in town and while chatting I noticed his front tire looked low on air. Not flat or anythign but just low. I told him to swing by my house and I'd check it for him and top it off with my compressor.
It turns out he was down IIRC 10+ psi front and roughly same at the rear. He'd not noticed any handling issues up to that point and had never thought to check his tire pressures before.
FFWD to this past Sunday I saw him again in town and offered to have him swing by for dinner and to have some burgers with us.
He stops by and he mentioned that since I filled up his tires he immediately noticed his scooter was easier to steer and more importantly his mileage "shot up" which he does track by the tank. He'd said that he saw a near 15% increase in mileage per tank just from the tires being topped off to proper levels with air. He's not even a big guy and his bike is a little Vespa looking knock off. We rechecked his air pressure again to be sure it's still up to spec.
Proper air pressure can take you a long way.
- Janq
Janq is offline   Reply With Quote
Old 08-08-2006, 05:34 PM   #15
ColinL
Member#: 114
'03 Evo, Rice White
'01 Erion CBR 929
<---30-32 mpg
0-60 in 6.5
<-- 36-42 MPG depending on my wrist
0-60 in well under 4.0
but only 2 seats, trunk space for two 6" sub sandwiches, no AC and no cruise control.
ColinL is offline   Reply With Quote
Old 08-08-2006, 05:44 PM   #16
bemani
Member#: 5673
16 Hellcat
05 LGT, 02 bug eye
- Janq
Except the problem is unless you measure the mpg for all pressures on your particular tires, you don't know what pressure is proper.
Manufacturer recommended tire pressure is only good for the oem tires.
bemani is offline   Reply With Quote
Old 08-08-2006, 05:47 PM   #17
Pretty Waste
Member#: 103166
Nope. 15MPG makes me happy. *Smacks forehead*
Pretty Waste is offline   Reply With Quote
Old 08-08-2006, 05:51 PM   #18
Midwayman
Member#: 1997
2006 Acura TL 6spd
STMGM6 alumni
BSFC isnt really about running rich or lean. Its about fuel consumed per HP. I suppose on a real low compression engine, there is a point at which some small amount of boost would produce more hp per gallon. Its not really the point though. Its that low rpm is the deal to increase MPG, not worrying about boost.
Though I wonder about the whole closed loop/open loop issue. Most car run really rich in open loop mode, so you'd probably need to stay in closed loop mode to achieve the best fuel saving.
Or just go buy a more fuel efficient car and not worry about it.
Old 08-08-2006, 05:53 PM   #19
Midwayman
Member#: 1997
2006 Acura TL 6spd
STMGM6 alumni
- Janq
Not to mention improper air pressure on a scooter or motorcycle is flat out dangerous.
Old 08-08-2006, 05:56 PM   #20
Calebz
Member#: 54398
1980 CB400 Hawk
1996 GrandCherokeeLimited
I was in that Biowhatever office about 2 months ago. I do IT work for another company in that building. My client sent me over there because they had some questions.
It was .... interesting
Calebz is offline   Reply With Quote
Old 08-08-2006, 06:02 PM   #21
Samuelleeogden
Member#: 66066
04 STi
black on sold
i shift at 2k rpm when i'm around town.
it SOUNDS like an 18 wheeler, so it must be getting bett4r milage!
Samuelleeogden is offline   Reply With Quote
Old 08-08-2006, 06:10 PM   #22
WRX02WRB
Member#: 36240
2015 STi
We need details.
WRX02WRB is offline   Reply With Quote
i love my rex but I needed to get a bit better gas mileage... ccacher1 Member's Car Gallery 30 07-23-2008 10:26 AM
Ways to get better gas mileage 05rswagon Normally Aspirated Powertrain 16 10-14-2006 05:59 PM
Easy way to get better gas mileage... WRX_Convert Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 19 04-12-2004 04:34 AM
you guys get better gas mileage in valet mode? SpeedShift Engine Management & Tuning 5 06-20-2003 10:59 AM
