Old 08-08-2006, 11:05 AM   #1
Parsons
Member#: 65688
2001 junkyard heap
Black/dirt
Default OL/CL delay and P0328?
P0328 being knock sensor high high output
I assume these two are related on my car. I tried some searching but it seems not many people have both these problems at the same time. Also note, my car is cursed, if its the worst thing that these problems could be, thats what it is.
I have an 04wrx engine in my 01RS, when I did the swap I bought a custom 2.5" catless TBE.
I didn't know about the OL/CL delay problem at all. I just knew a stock RS exhaust wouldn't fit/work at all, so I bought a new one. If you HAVE to buy an exhaust, who buys a stock one?
After swap was all done everything was installed it ran fine. It was WAY too loud and wouldn't pass inspection so I put a 2.5" cat in 3rd cat location. Then my car runs limp mode and gets the new CEL, P0328. BUT the problems I noticed are described in both OL/CL delay threads and threads about P0328.
When I posted thinking it was knock senor being bad (http://forums.nasioc.com/forums/show...php?t=1041638), eveyone said "just replace it". Now I read that its an issue with the OL/CL delay in the 04wrx with a catless DP.
So my question is: If you actually have knock, setting the sensor off, does the code stay up ALL the time, Or is that a sign of a bad sensor?
If I get my ECU reflashed, will the CEL turn off?
I don't want to spend the money to get the knock sensor replaced just to find out a reflash (which I am not paying for) will fix it.
Parsons is offline   Reply With Quote
Old 08-08-2006, 11:15 PM   #2
Parsons
Member#: 65688
2001 junkyard heap
Black/dirt
Nothing?
Someone has to have run into this problem on an 04 WRX.
Old 08-08-2006, 11:41 PM   #3
hondaeater69
Member#: 60324
how about test the sensor for resistance, if it's within spec youre knocking, if not replace it. do a search for the specs i have no idea what they are.
Old 08-08-2006, 11:52 PM   #4
Parsons
Member#: 65688
2001 junkyard heap
Black/dirt
I'll ask the tuner who's doing my reflash about that, thanks
Does COBB for the 07 deals with the OL/CL delay issue? BBBsti LTD AccessPort 4 09-07-2007 09:54 PM
OL/CL delay... I havent kept up. Give me lowdown (07 FXT) Davenow Factory 2.5L Turbo Powertrain (EJ Series Factory 2.5L Turbo) 19 04-26-2007 12:31 AM
The OL/CL Delay and STX yobtah Motorsports 1 01-01-2007 11:45 AM
Please help with the OL/CL delay problem accelguy Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 5 05-09-2006 05:26 AM
prevent ol/cl delay? dypeterc Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 27 09-26-2005 02:37 PM
