Welcome to the North American Subaru Impreza Owners Club Sunday August 2, 2015
Texas Impreza Club
Go Back   NASIOC > NASIOC Chapters > Texas Impreza Club Forum -- TXIC
Old 08-08-2006, 10:55 AM   #1
gregsatt
Member#: 38536
'02 WRX Wagon
FreeRentMoney.com White
Default Got the modding bug again
I installed a water sprayer for my top mount. Cost me all of $5. I bought some tubing and sprayer nozzles at WallyWorld. I plugged it into the rear wiper fluid pump and use the rear washer knob on the stalk to spray it Works like a champ.
Greg
gregsatt is offline   Reply With Quote
Old 08-08-2006, 11:18 AM   #2
Colbc
Member#: 37633
2003 WRX Wagon
Scooby Blue
Greg
Sounds easy. What type of tubing and nozzles? How did you mount it for best coverage on the TMIC?
Chris
Colbc is offline   Reply With Quote
Old 08-08-2006, 11:21 AM   #3
TJ
Member#: 41735
I'm on your lawn
do something about it
brass mister nozzles
are the best thing to get, but hardest to find!
TJ is offline   Reply With Quote
Old 08-08-2006, 11:26 AM   #4
DanzBorin
Subaru Bounty Hunter
Member#: 7131
2015 Outback - Croc
Dundee Edition Ice Silver
so, do you have to run the rear wipers everytime you spray the IC?
DanzBorin is offline   Reply With Quote
Old 08-08-2006, 01:14 PM   #5
gregsatt
Member#: 38536
'02 WRX Wagon
Yes, for now, the rear wiper runs when I spray it
I am going to unplug the wiper motor when I get a chance. I tried to unplug it the other day, but couldn't get the thing unplugged
The hose is the standard tuping sold at WalMart for running drip lines. I think the brand is Orbit drip master. The misters are Orbit Drip Master brand as well. Part number 61032D. I put two of the in. You need the tubing, the misters, and a T connector.
I would think that brass misters would spray too fine of a mist and the pump would have a hard time getting the water through. I think WalMart has these as well, but most of the people who have made their own sprayer, IIRC, used these plastic garden sprayers.
I'm sure I don't have the best coverage, but some is better than none. I need to look at an STi to see where the nozzels are positioned. I drilled out two of the holes that hold in the rubber flashing on the front side of the hood scoop and slid the tubing through the holes from the front then attached the misters so that they are above the IC.
Only took about half an hour to complete. Now I need to hook up the sprayer to my UTEC so it will spray at certain RPM and/or boost levels automatically
Old 08-08-2006, 01:22 PM   #6
brizey
Member#: 36505
2004 Forester XT PSM
2007 Acura RDX w/Tech CBP
Greg:
It is a BITCH to unplug. I used a screwdriver to pry the connector. The good news is that it gets easier. I disconnect the sprayer in the cooler/wetter weather so I get my rear wiper and washer back.
brizey is offline   Reply With Quote
Old 08-08-2006, 01:23 PM   #7
samagon
Member#: 26859
of TXIC
I also like (oYo)!!!!
you want to get some nozzles that will get the IC wet, and not evaporate in the air.
you will transfer heat better if the water evaporates directly from the IC.
Old 08-08-2006, 02:27 PM   #8
gregsatt
Member#: 38536
'02 WRX Wagon
I pried and pried and it still wouldn't budge I guess I'll give it another shot.
How did you mount your sprayers?
My sprayers soak the intercooler, not mist it
Originally Posted by brizey
Greg:
Old 08-08-2006, 06:10 PM   #9
Colbc
Member#: 37633
2003 WRX Wagon
Scooby Blue
I guess this means you don't run wiper fluid anymore just good old H2O?
Chris
Old 08-08-2006, 06:43 PM   #10
TJ
Member#: 41735
I'm on your lawn
pics?!
Old 08-08-2006, 07:17 PM   #11
Texas25RS
Member#: 3148
2012 Mazdaspeed 3
Crystal White Pearl Mica
I got a set of mister from Home Depot for a patio cooling set up... they have like 3-4 inches of stiff tube connected to them so they can be bent into a shap or position... not for my intercooler, but for my radiator on my Integra...
Texas25RS is offline   Reply With Quote
Old 08-09-2006, 10:44 AM   #12
gregsatt
Member#: 38536
'02 WRX Wagon
I never did run washer fluid, but you still can run it if you like. It actually evaporates faster than water so it should actually cool better.
I'll get some picks up later.
Chris
Old 08-09-2006, 12:35 PM   #13
ATXWRX
Member#: 81244
2002 My old SN
dyslexicwrx
That is a cool idea! I wish I had a rear wiper to do that with.
ATXWRX is offline   Reply With Quote
Old 08-09-2006, 01:18 PM   #14
SilverSpool
Member#: 55869
BMW / Ducati / Kawa
135i / M796 / ZX6R
The reservoir has a spot for it, just go to autozone, buy a 10 dollar wiper pump and a 5 dollar switch, some wires... and you have yourself a pump w/ switch
SilverSpool is offline   Reply With Quote
Old 08-09-2006, 03:41 PM   #15
brizey
Member#: 36505
I have 4 nozzles. I teed the tubing just inside the splitter, then added two short pieces of tubing, then 90 degree nozzles. One T on each side. I just stuffed the tubing between the splitter and the tube. I ziptied the tubing under the hood so there is no strain at the splitter. Hasn't moved for two years.
I run about a 50/50 mix of distilled water and washer fluid. My IC is still filthy, though, and I have a gabillion bent fins.
I'll try to snap a few pics.
Old 07-31-2007, 12:57 AM   #16
El Supremo
Member#: 38388
gregsatt,
Hate to dig up old threads/wounds, but how did you eventually get the rear wiper motor unpluged? I've been priing (sp) for awhile myself with no success. Getting pissed, ready to cut wires. Is there a fuse I can take out somewhere? Don't want to put the screwdriver through my hand, not a big fan of stigmata.
Thanks,
Supremo
El Supremo is offline   Reply With Quote
Old 07-31-2007, 01:27 AM   #17
trxdam
Member#: 93818
1999 Mazda Mx-5
Got jokes?
Originally Posted by El Supremo View Post
gregsatt,
Thanks,
Supremo
You know you can go around the rear motor where the wire comes off of the motor in the front, snip the wire and run it to a on/off switch (2-5 bucks at a autoparts store) and ground it. That way your rear wiper won't go every time hit it. That and you can put the switch in a more convient place like near the shifter.
I did it this way, it didnt take me very long.
trxdam is offline   Reply With Quote
Old 07-31-2007, 01:49 AM   #18
uathatis
Member#: 117300
i'd kinda like to figure out if its possible to splice the wire for the water pump to a on/off switch and keep the rear wipermotor and wiring in place...
or are they running the exact same wire? (not 2...?)
uathatis is offline   Reply With Quote
Old 07-31-2007, 07:07 AM   #19
El Supremo
Member#: 38388
Good Idea trxdam, I'll just cut and bypass the sumbitch.
Thanks,
Supremo
I got bit by the mod bug! WRX Smokescreen General Community 11 08-11-2007 04:18 PM
I've caught the WoW bug again... eurojax Off-Topic 21 08-09-2005 06:56 PM
got the mod bug. hirevn Alaskan Impreza Club Forum -- AKIC 0 09-08-2004 01:29 AM
How to cure the mod bug MustGoFast Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 21 10-31-2003 06:20 PM
The Mod Bug Bites Hard(ouch) Jard Mid Atlantic Impreza Club -- MAIC 0 05-28-2003 04:01 PM
