Old 08-08-2006, 04:04 PM   #1
fishheadback
Member#: 68120
1998 RS 2.0 vf23 STi
& MK6 GTI
Default Cel- Po117
Just wondering if anyone knows what could be associated with a PO117- coolant temp sensor malfunction? I'm getting 2 codes, both a PO117. Think it could just be the coolant temp sensor? My gauge works fine and my fans kick on. Whats the deal?
fishheadback is offline   Reply With Quote
Old 08-09-2006, 03:40 PM   #2
fishheadback
Member#: 68120
& MK6 GTI
Any ideas?? I can't erase the code either. $40 bucks for the sensor, guess I'll just order one and replace it.
Old 08-09-2006, 03:43 PM   #3
fishheadback
Member#: 68120
& MK6 GTI
ALSO.... What kind of codes make a ecu go into limp mode. Could this code cause that? What about an EGR or EVAP code? Will those cause the ecu to go into limp mode?
washed engine bay, now car won't start CEL on pinoy_boy204 Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 42 06-08-2010 10:12 AM
0136 CEL w/ Pony Express CEL "fix" lstepnio Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 4 04-17-2003 05:26 PM
Anyone with Borla header and CEL, did the ECU recall fix the CEL? Suba_Roo Normally Aspirated Powertrain 14 01-25-2003 01:53 AM
Wierd Cel after ECU Reset, installed TurboXS TMI, No Cel in Log DiMensionX Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 1 09-13-2002 09:19 PM
CEL or no CEL? chuglobal Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 12 03-25-2002 04:23 PM
