Old 03-01-2011, 11:11 AM   #2776
jehymel
Member#: 260385
2011 Impreza WRX
Spark Silver
Originally Posted by Superorb View Post
What worries me about this carrier is that one could just unscrew the part where the rack clamps onto the cross bars and walk away with the whole carrier, including anything attached.
I've got this same carrier (FatCat 6), and in order to take it off of the cross bars, you have to open it all the way up to access some bolts inside, so as long as the rack is locked, you can't get it off of the cross bars.
jehymel is offline   Reply With Quote
Old 03-01-2011, 04:00 PM   #2777
BeetsBearsBattlestar
Member#: 244980
2010 STI SE
this isn't accurate. there are covers that rotate over the bolts which prevent someone from doing what you're describing. there aren't any exposed bolt heads on the fatcat.
BeetsBearsBattlestar is offline   Reply With Quote
Old 03-01-2011, 06:03 PM   #2778
Superorb
Member#: 135252
2002 WRX Wagon
86% Operational :(
I'm talking about the bracket that mounts to the crossbars, not where it mounts to the carrier. It looks like two pieces sandwiched together over the crossbars.
These guys in the pic, are they what comes on the Fatcat? How can you prevent someone from just unbolting the halves?
Superorb is offline   Reply With Quote
Old 03-01-2011, 06:20 PM   #2779
JeffrWRX
Member#: 48589
2016 WRX 6mt CWP
If the Ski/Board Carrier is locked shut then you cannot access the top bolt. You have to loosen the top bolt and rotate the top assembly to gain access to the 2 bolts that clamp it on the bar.
-Jeff
JeffrWRX is offline   Reply With Quote
Old 03-01-2011, 07:57 PM   #2780
nighthawk06si
Member#: 267490
2011 WRX Hatch S2+SF
Yeah, in order to rotate the carriers at all that inside bolt has to be loosen for any movement. So as long as they're locked then you're good. At first i thought you meant the crossbars but even subaru thought about it and made a special screw type pattern for it so the bars aren't even jackable.
nighthawk06si is offline   Reply With Quote
Old 03-01-2011, 11:18 PM   #2781
Superorb
Member#: 135252
2002 WRX Wagon
86% Operational :(
-Jeff
Ohhh, ok, I see what you mean now. Thanks, I'll add the Fatcat back to my list
I thought the OEM setup wasn't lockable so anyone could just unbolt the feet from the car and walk away with the entire rack.
Old 03-01-2011, 11:24 PM   #2782
Member#: 244980
2010 STI SE
I have a full yakima setup with landing pads/crossbars/fatcat 6 and it's by far the nicest rack setup I've ever used or been around. If you have the factory crossbars the fatcat 6 comes with locks which is nice. if you're like me and went aftermarket all the way you can still get a SKS and install new locks to have one key to rule them all
Old 03-02-2011, 05:05 AM   #2783
nighthawk06si
Member#: 267490
You're correct, they don't lock or can't be lock using such things like SKS Lock w/keys but I took a closer look at the tool they gave me and the screw that is accessable hidden inside the bars, it's a special type of star pattern so it can't really be taken off by the average joe with a regular phillips head. You need that special head that Subaru gave you in the package to unscrew the bars from the landing pads.
Old 03-02-2011, 07:35 AM   #2784
The1SloR/T
Member#: 251879
1998 Neon R/T 178whp
2010 Wrx Sedan WRB
Its just a torx bit. You'd be surprised how many average joes keep a little torx set in their car, let alone theives
The1SloR/T is offline   Reply With Quote
Old 03-02-2011, 09:39 AM   #2785
bwc
Member#: 102279
05 WRX SW
I have a sw, and I want to put Roof Racks. what I need to buy?
bwc is offline   Reply With Quote
Old 03-02-2011, 12:52 PM   #2786
littlewhitewagon
Member#: 103068
11 STI sedan
Nice...
Try Thule.com or yakima.com to start. Pick your car and have fun choosing.
littlewhitewagon is offline   Reply With Quote
Old 03-02-2011, 12:53 PM   #2787
Superorb
Member#: 135252
2002 WRX Wagon
86% Operational :(
Any pics of the Yakima setup on your car?
I have a Torx set as well, it's not all that uncommon.
Old 03-02-2011, 01:03 PM   #2788
The1SloR/T
Member#: 251879
2010 Wrx Sedan WRB
Exactly
Old 03-03-2011, 02:02 PM   #2789
TacomaJack09
Member#: 275685
Originally Posted by WRXSIG View Post
top shelf you know
Lovin' all the wood grain racks!
I wanna see these racks and Subie's packed full of gear and toys!!
TacomaJack09 is offline   Reply With Quote
Old 03-03-2011, 02:10 PM   #2790
The WoRX 14
Member#: 274681
2011 WRX Limited 5d
I was looking for a base system on thule.com.
It says they dont have any for 2011 WRX yet. Is it safe to assume I can just use the 2009 or 2010 parts?
That car looks awesome btw
The WoRX 14 is offline   Reply With Quote
Old 03-03-2011, 04:31 PM   #2791
littlewhitewagon
Member#: 103068
11 STI sedan
Yes, same thing. But why Thule? Why not Yakima?
Old 03-03-2011, 05:29 PM   #2792
farBeyondDriven
Member#: 127018
2006 WRX
Sold the WRX and now selling the roof rack. I'm definitely going to miss it.
farBeyondDriven is offline   Reply With Quote
Old 03-03-2011, 06:22 PM   #2793
'Buru in the Burgh
Member#: 262205
2003 Legacy
18x Regatta Red
wish I took this picture before I took the other kayak off
'Buru in the Burgh is offline   Reply With Quote
Old 03-03-2011, 07:30 PM   #2794
Drewski's
Member#: 275486
still looks sick with the one.
Drewski's is offline   Reply With Quote
Old 03-03-2011, 07:52 PM   #2795
riderome
Member#: 210603
2005 STI
riderome is offline   Reply With Quote
Old 03-03-2011, 08:07 PM   #2796
JavaBot
Member#: 156723
05 crp foresterX
rip 2.0i/2.5rs
awesome! now just switch back to skiing...
Don't think I've had both on there at the same time yet.
JavaBot is offline   Reply With Quote
Old 03-03-2011, 10:37 PM   #2797
ShawnB86
Member#: 103246
Hey guys, let me start off by apologizing for not going through the entire thread. I'm kind of in a situation. I need to move cross country in my STi and I have some items to take with me. I need an extremely useful basket-type roof rack for my 2004 STi. Does anyone have any suggestions?
Below is an example of what I am hoping to find. I am extremely appreciative of any help anyone can provide. I am moving in less than 2 weeks, so it's pretty urgent so thanks NASIOC members and hopefully I don't get flamed.
ShawnB86 is offline   Reply With Quote
Old 03-04-2011, 03:58 AM   #2798
littlewhitewagon
Member#: 103068
11 STI sedan
What you have displayed can be had by getting the base kit, wheel fork, load warrior basket, fork mounted bike carrier, and the cargo net. I suggest you get lock cores for the base rack and bike carrier.
Just go to Yakima.com and select your car, then pick the accessories. If you need everything in 2 weeks, j suggest you get a move on it. The basket may not be stocked locally.
Old 03-04-2011, 06:32 AM   #2799
The WoRX 14
Member#: 274681
2011 WRX Limited 5d
I like the rectangle bars better. They can't move in their base systems under a load like breaking or accelerating.
Old 03-04-2011, 07:39 AM   #2800
patricksmith04
Member#: 116816
2011 WRX
Shawn, the only way I ever made it across the country and back when moved was with a Thule cargo box. I would have never fit all my stuff in a basket. Just a thought...
patricksmith04 is offline   Reply With Quote
Bugeye Roof Rack - What All Do I Need? TheShadowWRX Interior & Exterior Modification 1 02-10-2010 03:33 AM
FS: SoCal: Thule roof rack for all 2006-2007 Impreza (WRX and STi) hacker1600 Exterior/Styling 7 03-30-2009 03:58 AM
question about roof racks.... Meat Supply Interior & Exterior Modification 4 11-08-2007 02:37 AM
Totally *stupid n00b* question about roof rack sdecker Tribeca Forum 5 06-07-2006 09:22 AM
Question for all with a roof rack... eugenekid General Forum Archive 0 09-28-2000 01:45 PM
