Old 10-13-2011, 10:19 AM   #3526
Br.swans
Member#: 245192
11 WRX 4dr
Same as all the other mounts for oem bars. It's got the two half oval shaped clamp things that bolt together.
Br.swans is offline   Reply With Quote
Old 10-13-2011, 12:27 PM   #3527
Br.swans
Member#: 245192
11 WRX 4dr
Who else is pumped?!
Old 10-13-2011, 08:29 PM   #3528
SimonTuffGuy
Member#: 28550
2002 WRX Wagon
Originally Posted by Xcelr8to1320 View Post
That has the extension in it? Any straight on side shots of it? I'm debating if I want to add the extension or not.
SimonTuffGuy is offline   Reply With Quote
Old 10-14-2011, 12:47 PM   #3529
Xcelr8to1320
Member#: 131272
2003 WRX Wagon
Here you go!
Xcelr8to1320 is offline   Reply With Quote
Old 10-17-2011, 10:14 PM   #3530
rmj
Member#: 276611
2011 STi 5-Door
Plasma Blue Pearl
Put on a Yakima Forklift for my bike yesterday!
rmj is offline   Reply With Quote
Old 10-17-2011, 10:57 PM   #3531
FlyinLow4ever
Member#: 277187
11 wrx sedan
Yesssssssiiiiiiiiirrrrrrrrrrrr!!!!!!! counting the days down!!!!
FlyinLow4ever is offline   Reply With Quote
Old 10-19-2011, 12:40 AM   #3532
rmj
Member#: 276611
2011 STi 5-Door
Plasma Blue Pearl
I ordred some 3M vinyl to put underneath the feet of my OEM Aero bars, and for the time being, put some painter's tape below it to prevent scratching.
When I removed my fairing, even after a week of pretty minimal driving, the fairing's feet scuffed up the clear coat quite a bit. I'm disappointed this happened so quickly.
I waxed at these locations, but was not able to buff them out. Any suggestions?
I think I am going to have to put some clear 3M protection there as well. For now, there's some painter's tape there too to prevent it from getting any worse.
Old 10-19-2011, 12:56 PM   #3533
olazy
Member#: 263322
2011 WRX Limited
WRBP
I had the same from my thule failing. Not sure if it was the feet or from stuff being deflected onto the roof. What did you use as polish? I was able to get mine out using my porter cable DA buffer and some meguiars m105.
olazy is offline   Reply With Quote
Old 10-19-2011, 02:37 PM   #3534
rmj
Member#: 276611
2011 STi 5-Door
Plasma Blue Pearl
I haven't tried polishing it yet - there is just the painter's tape over the 4 spots for now. I'll have to start looking into products and try it out before I apply any 3M.
Old 10-19-2011, 04:56 PM   #3535
olazy
Member#: 263322
2011 WRX Limited
WRBP
i don't have any pics but mine looked pretty bad. With a light cut pad and some m205 (not m105) it got it right out on 1 pass, definitely consider it. good luck.
Old 10-21-2011, 12:01 PM   #3536
NutWagon
Member#: 230925
04 WRX Wag Stage 4
06 Impreza 2.5I
Where can i find them. I got a load warrior but with no mounting hardware.
NutWagon is offline   Reply With Quote
Old 10-21-2011, 12:03 PM   #3537
Br.swans
Member#: 245192
11 WRX 4dr
Old 10-21-2011, 12:16 PM   #3538
Br.swans
Member#: 245192
11 WRX 4dr
Load warrior has different mounts than mighty mounts. Have to use those ones
Old 10-21-2011, 12:24 PM   #3539
NutWagon
Member#: 230925
04 WRX Wag Stage 4
06 Impreza 2.5I
Yes Bro you are awesome!!!!!!! This is the cheapest replacement parts ive found. I need a few things too. A new flairing mounting hardware etc. Thanks again! Made my day.
Old 10-21-2011, 12:26 PM   #3540
NutWagon
Member#: 230925
04 WRX Wag Stage 4
06 Impreza 2.5I
Load warrior has different mounts than mighty mounts. Have to use those onea
Im not sure exactly what brand it is? But it looks just the the load warrior. Would the flairing and hardware be different?
Old 10-21-2011, 12:27 PM   #3541
Br.swans
Member#: 245192
11 WRX 4dr
No prob. Should be the same. It just clamps over the bar on the basket and the bottom attaches to the bars the same
Old 10-21-2011, 12:50 PM   #3542
NutWagon
Member#: 230925
04 WRX Wag Stage 4
06 Impreza 2.5I
+10 man. Br.Swans FTW! Thanks again
Old 10-21-2011, 01:06 PM   #3543
junk240sx
Member#: 53826
2005 WRX STi
CGM
I first tried Thule but they place the bars too close to each other (only 18" apart if I remember correctly!).
I really didn't want to do the rain gutter mod where I would be doing any drilling...so I found Yakima's rack actually spaces them out much wider. So I ended up with Yakima on my STi. Pretty important since I put longboard surfboards on the car often.
junk240sx is offline   Reply With Quote
Old 10-21-2011, 02:12 PM   #3544
Lord Fatmon
Member#: 241916
1995 Impreza L (GC8)
2005 JBP STI
Hey guys, question. What would be the best set of mounts to mount a Yakima bike rack onto the top of my '05 STI? Also, is there a way to be able to keep the bike rack mounted to the car and be able to add the rain guards over the windows?
Lord Fatmon is offline   Reply With Quote
Old 10-21-2011, 02:33 PM   #3545
Br.swans
Member#: 245192
11 WRX 4dr
It will mount to whichever brand you choose to go with for the bars. There is a system floating around here that will allow you to use an 08+ type system but requires you to drill holes in your roof channel. Either way you will be put the window visors on bc those mount to the door and the rack mounts to the roof of the car and clamps inside the door
Old 10-21-2011, 03:27 PM   #3546
guy45
Member#: 183828
02 insect wagon
wrb
Nice rack xclr8 by the way two biike carries fit perfect inside it.
guy45 is offline   Reply With Quote
Old 10-21-2011, 03:53 PM   #3547
Br.swans
Member#: 245192
11 WRX 4dr
Just picked up winter wheels
Old 10-21-2011, 07:03 PM   #3548
ANR62NV
Member#: 283589
2011 Impreza WRX
Red
Ok so I've tried to do research and ran across a couple fitment guides , but didn't help.... Question: I wanna get either a Thule roof fairing or Yakima . But I don't know which measurement to go with. Idk where the rack is measured from
Is it just the aluminum piece that gets measured length wise . Or do you include the two side pillars with the measurement ???
I wanna place my order but don't wanna order too big or small....
I have the OEM roof rack on my 11' WRX
Any help ?
ANR62NV is offline   Reply With Quote
Old 10-21-2011, 07:34 PM   #3549
Br.swans
Member#: 245192
11 WRX 4dr
38" (Thule or Yakima), medium Inno
Old 10-21-2011, 07:36 PM   #3550
ANR62NV
Member#: 283589
2011 Impreza WRX
Red
Alright sweet... Thanks...
Bugeye Roof Rack - What All Do I Need? TheShadowWRX Interior & Exterior Modification 1 02-10-2010 03:33 AM
FS: SoCal: Thule roof rack for all 2006-2007 Impreza (WRX and STi) hacker1600 Exterior/Styling 7 03-30-2009 03:58 AM
question about roof racks.... Meat Supply Interior & Exterior Modification 4 11-08-2007 02:37 AM
Totally *stupid n00b* question about roof rack sdecker Tribeca Forum 5 06-07-2006 09:22 AM
Question for all with a roof rack... eugenekid General Forum Archive 0 09-28-2000 01:45 PM
