Old 08-08-2006, 05:35 PM   #1
nsvwrx
Member#: 122104
Default Sealing a meth hole in an IC
anyone have an idea how?
nsvwrx is offline   Reply With Quote
Old 08-08-2006, 05:55 PM   #2
PolarisSnT
Member#: 85905
2004 WRX
If you are talking about making sure there are no leaks around and injector, i used epoxy. If you are trying to seal the entire hole, welding is your best option.
PolarisSnT is offline   Reply With Quote
Old 08-08-2006, 07:23 PM   #3
hippy
Member#: 36528
2002 Impreza Wrx
Some washers and o rings should do it(with a nozzle or without). you probably don't want apoxy in your engine. On the same note, it might not be the best idea to glue anything in the engine compartment. Most apoxies can't take the heat, and might end up drying out and breaking off or something. Course I did know this guy back in the day with a cracked block that glued it back together(seriously)........
peace
Old 08-08-2006, 07:30 PM   #4
hotrod
Member#: 14141
2002 Impreza WRX
It might help if you gave us enough info so we have a clue what your trying to do!
Where is the hole, how big is it, why do you have a hole in the intercooler in the first place, (did the methanol corrode a hole or is this a hole drilled for an install that you are removing? )
Remember --- who, what, when, where !!
Larry
hotrod is offline   Reply With Quote
Old 08-08-2006, 08:16 PM   #5
jays05
Member#: 78165
05 STI 35r + e85
JB-Weld
jays05 is offline   Reply With Quote
Old 08-09-2006, 03:57 PM   #6
nsvwrx
Member#: 122104
it was drilled to let meth in..
and i think im going toseal it with a bolt few washers and jb-weld
Old 08-09-2006, 04:16 PM   #7
hippy
Member#: 36528
2002 Impreza Wrx
There should be a type of plug/fitting at home depot and/or lowes which should be the perfect size and work really well. You could probably just put a screw in it too(might not be such a good idea), or get it welded. Imo jb weld(or any kind of glue) is a bad idea......
peace
Old 08-09-2006, 06:35 PM   #8
nsvwrx
Member#: 122104
isnt jb weld raited to 3900 psi and 500 *f? peopel glue ther cracked blocks with this stuff
Old 08-09-2006, 08:37 PM   #9
hippy
Member#: 36528
2002 Impreza Wrx
People do lots of things, and that's probably one of the reasons jb weld is still around. Why glue something when ya don't have to? In my mind, there are only two good reasons to use glue to hold your block or anything in your engine compartment together. The first and best would be that you can't afford anything else. The second would be if you're trying to prove that it will hold. We know a fitting like the nozzle that was in there but a plug will hold, never break off, and someone could put the nozzle back if they wanted. Also, 500F is not hot.
peace
Old 08-09-2006, 09:40 PM   #10
DISCOPOPE
Member#: 43339
2oo4 STi
URgt35r w/t3hM3finj3cki0n
weld on an aluminum 1/8npt bung. seal it with a 1/8npt plug.
you do not want a bolt letting go and getting sucked through.
and if the hole is underneath, you will not have the option of checking it frequently.
DISCOPOPE is offline   Reply With Quote
Old 08-09-2006, 09:40 PM   #11
nsvwrx
Member#: 122104
good idea with the nossle!
Old 08-09-2006, 09:41 PM   #12
DISCOPOPE
Member#: 43339
2oo4 STi
is this an ebay's perrin tmic?
Old 08-09-2006, 11:21 PM   #13
dibblejr
Member#: 94070
05 LGT
JB Weld-Good stuff, I repaired a broken BOV on my Bugeye a couple years ago. Worked like a charm.
dibblejr is offline   Reply With Quote
Plug meth holes in intercooler Tgui Water/Methanol Injection, Nitrous & Intercooler Cooling 0 05-18-2010 11:54 AM
Welding shut a meth hole in TMIC safe for long term & high boost? lotarg Water/Methanol Injection, Nitrous & Intercooler Cooling 8 01-15-2010 03:30 AM
WTB shurflo meth pump for an HomeBrew IC sparayer project. morrocco88 Private 'Wanted' Classifieds 1 07-07-2009 07:38 AM
HR: Need an IC hole welded D_Block Mid Atlantic Impreza Club -- MAIC 37 12-05-2005 12:20 PM
Sealing holes in trunk Pochebum Southern California Impreza Club Forum -- SCIC 8 01-21-2003 11:27 AM
