Old 10-25-2001, 03:00 AM   #1
Woodywayne
Member#: 6173
2002 WRX Wagon
Ralley Blue
Default Where is turn signal Flasher located in an 02 WRX wagon?
Need Help as to where turn signal flasher is located in 02 WRX wagon.
Thanks,
Wca
Woodywayne is offline   Reply With Quote
Old 10-25-2001, 03:04 AM   #2
LttLDGN
Member#: 5478
do you mean the reflector above your headlights?!
front signal? rear?
clarify the question a little please... i'd like to help.. but dun get the question..
LttLDGN is offline   Reply With Quote
Old 10-25-2001, 04:25 AM   #3
Woodywayne
Member#: 6173
2002 WRX Wagon
Ralley Blue
I want to know where Flasher is that makes sound when you put the turn signal on and how you get to it.
Wca
Old 10-25-2001, 04:31 AM   #4
LttLDGN
Member#: 5478
oOoO .... hehe a more technical question...
sorry but i am not sure... but do a search on it... i remember there being a post about the signal flashers not being loud enough a few days ago..... sorry i couldn't help
Old 10-25-2001, 07:11 AM   #5
Rocky WRX
Member#: 9837
2002 White WRX Wagon
7800 ft
According to the wiring diagram it's buried inside the drivers side dash. You should be able to locate it if you turn on your flashers or turn signal, stick your head under the dash and home in on it by the sound it makes.
Rocky WRX is offline   Reply With Quote
Old 10-25-2001, 08:41 AM   #6
nhluhr
John Wayne Toilet Paper
Member#: 7327
2008 Mazdaspeed3
2006 Wrangler Sport
Wca
you must mean the relay that makes that clicking sound. It is behind your fusebox up under the dash. You need to remove the dash panel below the steering wheel (two metal screw and one plastic trim screw) then get creative to locate it exactly.
question - why do you want to find it?
nhluhr is offline   Reply With Quote
Old 10-25-2001, 12:06 PM   #7
Woodywayne
Member#: 6173
2002 WRX Wagon
Ralley Blue
To put a louder clicker since I suffer from hearing loss due to 20 years of being around cannons.
Old 10-25-2001, 12:23 PM   #8
Mlasky
Member#: 8743
2002 Impreza WRX
SRP woooohooo!
Not to make light of your hearing loss, but if you are going to be losing your hearing being around cannons is a damn cool way to do it. Cannons kick ass
Mlasky is offline   Reply With Quote
Old 10-25-2001, 02:00 PM   #9
SoobATV
Member#: 6883
MY04 Foz XS
MY02 Imp TS
Mlasky:
SoobATV is offline   Reply With Quote
Old 10-25-2001, 11:02 PM   #10
Sooberman
Member#: 5344
Location: Greenwood Lake, NY...where the heck is that?!? :P
2002 WRX WRagon
Platinum Slipper
Talking This might be helpful...
I made instructions for installing a driver's side vent gauge which entailed removing pretty much everything around there (including the instrument cluster). Here's a link to the step-by-step photos with directions which will probably help you to get to the relay...or at least dismantle your dash:
http://www.cartogra.com/home/ViewMyA...oll_id=1087224
Don't worry about the fact that the dash looks like a disaster, it's actually pretty simple to take apart if you know how and even easier to put back together.
Sooberman is offline   Reply With Quote
Old 10-26-2001, 06:20 AM   #11
Woodywayne
Member#: 6173
2002 WRX Wagon
Ralley Blue
Thanks for the help....I found it.
Is an 02 WRX wagon control arm the same as an 06 2.5i? ElementalFiend Brakes, Steering & Suspension 2 03-19-2010 10:40 AM
Where is the knock sensor located on an 04 WRX? shinsain Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 3 04-09-2009 12:54 PM
Help! Need to install 06 tail lights in an 02 wrx wagon hensblend Interior & Exterior Modification 3 10-21-2006 05:29 PM
Where can I find the spoiler for an 02 WRX wagon that goes right below the rear glass djplayboy Interior & Exterior Modification 7 12-16-2004 09:07 PM
Turn Signal Flasher location DDMan Electrical & Lighting 16 06-03-2004 11:09 PM
