Old 08-08-2006, 05:07 PM   #1
daniel_gabriel
Member#: 114154
2002 WRX SportWagon
Default p0420 CEL - what to replace?
I've got 2 of them, resulting in a 'cat efficiency below threshold' message. I know there are 2 catalytic converters on the car. I presume that because there are 2 codes, they come from the front and rear oxygen sensors. My question is, which catalytic converter to replace?
In this picture (http://www.rockauto.com/ref/Walker/D...html?1652.jpg), do I need to replace part 16089 or 16090?
Thanks in advance,
-Daniel
daniel_gabriel is offline   Reply With Quote
Old 08-08-2006, 05:33 PM   #2
Matt Monson
Member#: 832
99 2.5RS, '85 911
'73 914 and 2012 BRZ
Do you have headers? If so, the headers are causing the code. It's really rare to actually have a cat go bad. I have run with an 0420 code for about 3 years now. It doesn't effect driveability at all...
Old 08-08-2006, 05:55 PM   #3
EJ1
Member#: 61296
If you are under 80K/8 years emissions warranty, just go to a dealer and voila!... new cats. If not, you can live w/ it, get a CEL or mechanical fix. Just do a search for those. There's a slight chance that it's the rear o2, but probably not. It could be off (not necessarily bad) and cause the P0420 to be thrown.
EJ1 is offline   Reply With Quote
Old 08-08-2006, 11:07 PM   #4
daniel_gabriel
Member#: 114154
2002 WRX SportWagon
everything is completely stock, and the car is a 99 OBS with about 92K on it. I live in MD, and I have emissions testing coming up, so I need to get rid of the code before then. Hence the question. I've been told previously by a few other members that it indeed is the cat causing this code to be thrown.
Do you know if the O2 sensors are before and after the cat on the exhaust manifold, or the cat on the downpipe?
Old 08-09-2006, 09:22 AM   #5
Siper2
Member#: 1134
2007 BMW 328xi wagon
The sensors bolt directly into the actual cats I think.
P0420 on a car with a high-flow cat pipe unit, and/or headers is usually a fault of the rear O2 sensor, because there's no cat there. There's a high-flow cat in the forward location, no cat in the rear. So you need one of the PDM O2 bung extension units to try and eliminate it.... but mine never worked.
On a stock car, though, my guess would be rear cat, but I suppose it could be either. Subaru CEL code log:
http://forums.nasioc.com/forums/show...1&postcount=12
=S2=
Siper2 is offline   Reply With Quote
Old 08-09-2006, 09:33 AM   #6
Master2192
RIP 10/12/83 to 02/10/08
Member#: 83254
98 2.5 RS
04 WRX
Alot of times this code gets thrown when the rear O2 sensor is going out.
Old 08-09-2006, 09:53 AM   #7
daniel_gabriel
Member#: 114154
2002 WRX SportWagon
So, in the worst case, I would need to replace both O2 sensors, and which cat? the one on the manifold, or the one on the downpipe?
Old 08-09-2006, 12:51 PM   #8
G.Subramaniam
Member#: 64528
Rallitek sells a fix for the 420 CEL
G.Subramaniam is offline   Reply With Quote
Old 08-09-2006, 01:10 PM   #9
FalconRS
Member#: 92913
2005 2.5RS Wagon
Crystal Grey Metallic
Kay first off, the front O2 sensor is NOT there to monitor the cats. It comes before the cat, and reports the air-fuel ratio back to the ECU so the ECU can in turn adjust fuelling to keep the car running properly. You will NEVER get a cat inefficiency code from the front O2. The rear O2 is there exclusively to monitor the cats. But it will only throw ONE code if there's an inefficiency detected. It'll throw a code if one or both cats are going bad (no way to tell if it's one or both), or it will throw a code if the sensor is going bad. It can also throw a code if your cats aren't heating up to spec (mostly caused by headers) because cats use heat to initiate the catalyzing process.
Want a real easy solution? Replace the sensor first to rule that out. Second, tons of guys around here have bought high flow cat pipes or track pipes, replacing their stock cats. Buy one of their stock units and you're off to the races. There are no guarantees that a high flow unit will pass emissions (probably won't) so don't listen to the guys around here that try to talk you into it. Your emissions check is coming up, don't mess around.
EDIT: Should also add, with the age and mileage on your car, it's entirely possible that the sensor's toast, or the cats are either shot or clogged. At that mileage, it could be either or both. It's definitely one of them. Hope this helps.
FalconRS is offline   Reply With Quote
Old 08-09-2006, 01:44 PM   #10
daniel_gabriel
Member#: 114154
2002 WRX SportWagon
Thanks for your help.
So the front sensor is before the cat on the manifold, and the rear sensor is behind the cat on the downpipe?
And, in the worst case, I would have to replace the sensor and both cats, correct?
Thanks again,
-Daniel
Old 08-09-2006, 02:39 PM   #11
DreddRS25
Member#: 51642
2001 Impreza RS
BRP
Thanks again,
-Daniel
This may help with your question. The front sensor (A/F) is right infront of the first cat, it has the black wire (one on the right). The rear 02 sensor is at the rear of the rear cat, it has the red wire. So directly, both sensors are located on the cat pipe itself.
DreddRS25 is offline   Reply With Quote
Old 08-09-2006, 03:26 PM   #12
daniel_gabriel
Member#: 114154
2002 WRX SportWagon
Thanks for the picture, it helps much.
So, if after I replace the sensor the code comes back, there is no way whatsoever to distinguish which cat is the one to be replaced?
Old 08-09-2006, 03:39 PM   #13
FalconRS
Member#: 92913
2005 2.5RS Wagon
Like I said, your best best is to just grab a stock cat section off somebody here who's upgraded to a high flow unit. You can probably get that cheaper than getting the dealership to troubleshoot out this one (or any other garage).
Old 08-10-2006, 08:39 AM   #14
daniel_gabriel
Member#: 114154
2002 WRX SportWagon
Thanks for your replies. I have ordered a rear O2 sensor and will be installing it probably this weekend. We'll see how it goes and if it fixes the problem.
Old 08-10-2006, 09:06 AM   #15
Siper2
Member#: 1134
Here's another decent comparison photo.
This is a Stromung HFC that I had in my car, just took it out and sold it last week. I'm saving up for a turbo swap, so this unit does me no good once I put the new engine in.
=S2=
MBC on my 2006 Subaru TR...Now have a CEL. What to do? AllWheelDriveTurboBo Newbies & FAQs 5 05-14-2008 06:48 PM
got a CEL, what to do!? bgmike AccessPort 11 11-23-2006 02:17 PM
ACT Clutch going - what to replace? NE1 near Detroit willing to help? chapstien Transmission (AT/MT) & Driveline 0 05-23-2006 02:48 PM
Want to sell wrx, but dont know what to replace it with... WarHawk187 Tri-State Area Forum 34 05-23-2006 08:01 AM
Ack! My first CEL! What to do...? Porsche914boxer4 Southern California Impreza Club Forum -- SCIC 29 06-13-2003 06:50 PM
Message Board Statistics All times are GMT -4. The time now is 04:06 PM.
