Old 08-08-2006, 06:19 PM   #1
V8Slayer
Member#: 111565
1999 Legacy 2.5GT
2007 Legacy GT Spec-B
Question More hp?
I am thinking of removing my ac. My first question is, will i see any hp gains( from less paresitic drag). If i just remove the belt will I see the same results as if I removed the whole system. And what would be some problems that might occure? Has anyone done this before and what were the results?
V8Slayer is offline   Reply With Quote
Old 08-08-2006, 06:32 PM   #2
Matt Monson
Member#: 832
99 2.5RS, '85 911
'73 914 and 2012 BRZ
You will see some marginal gains if you remove it. It doesn't matter if you take it out or just take the belt off. But taking it out completely, drops 30-40lb of weight. But since you are in Canada, I suggest just removing the belt. You will want it in the winter to make your defroster work properly...
Old 08-08-2006, 06:37 PM   #3
V8Slayer
Member#: 111565
1999 Legacy 2.5GT
Thank you for the quick reply. If the gains are minnimal, is it worth doing?
Old 08-08-2006, 06:54 PM   #4
illegal2.2
Member#: 58329
2005 Baja Turbo 5mt
Garnet Red Pearl
i don't think it makes a difference. for meh, i buy a car for AC and heat LOLZ
illegal2.2 is offline   Reply With Quote
Old 08-08-2006, 10:01 PM   #5
ballitch
Member#: 74907
98 cam'd EJ251
Wrx Tranny,slowr than ish
you gots to have a/c in the hot a$$ summer, and you really need the defroster for those cold a$$ mornings. like matt said, if you removed just the compressor you'd drop about 30-40 lbs. but if you removed all the a/c components (compressor, lines, fluid, condensor/evaporator) you could lose up to about 60 lbs. but i dont think its worth it.
~Josh~
Power Parts - More HP & More TQ - GREAT DEALS! Subimods Engine Management 23 10-12-2009 10:52 AM
Power Parts - More HP & More TQ - GREAT DEALS! Subimods Engine/Power/Exhaust 16 09-25-2009 03:26 PM
More Torque? more HP? suby_dude Motorsports 33 02-27-2004 12:34 PM
more hp and less hp re92 New England Impreza Club Forum -- NESIC 3 09-04-2001 08:44 PM
('93-'01) I just realized I need about 200 more hp and 2 more gears WRXwannbe Impreza Forum 4 05-05-2001 07:25 PM
