Welcome to the North American Subaru Impreza Owners Club Friday May 29, 2015
Old 09-09-2006, 05:14 PM   #1
ejh25
Member#: 65267
Default My tank choice for the Hydramist
Here is the choice I made for my methanol/water tank for my Hydramist:
Where should I hook my pump up and how?
Should I use the petcock at the bottom and just run a hose to the pump?
Thanks for the help.
- Eric
ejh25 is offline   Reply With Quote
Old 09-09-2006, 10:53 PM   #2
Absubtle
Member#: 85862
That is a nice tank. I like that a lot. You can use that hole from which the petcock is threaded in or even open it and slip the hose over the end. Depends on where you are mounting this tank... I kinda like the drain feature, since I play around w/ mixtures when I can get methanol or when the weather get too cold (heading to the mountains), I change the mixture to more alcohol. I usually run a 70-30 water/rubbing alcohol, but add more alcohol to the mix.
But anyway, I think the drain is a good idea, even to drain the dirt and residue that settles to the very bottom of the tank. Most people dont see it or notice it.
I would drill and tap the pipe tread of your choice ( or just use the fitting as the tap and seal it) about a 1/2-1" off the base of the tank and just teflon wrap it for safe measure, and keep the petcock.
I would plug the vent on top though, just in case it gets hot and your alcohol doesn't evaporate.
I hope this helps, more info/details on your side could help future advice.
Absubtle
CO
Absubtle is offline   Reply With Quote
Old 09-10-2006, 06:22 AM   #3
Richard L
Member#: 85153
2004 Citroen Picasso
The Hydramist comes with a tank adaptor, drill a 22mm hole, deburred and put the tank adaptor in. Good loaction will be abouit 1"-1.5" from the bottom of the tank. Outlet facing the rear of the vehicle, this will avoid water surge probelm during acceleration.
I am glad you have decided to go for a more professional approach as well as as your tank selection, Fuelcell is designed for use in racing condition and great for the fast road. Alcohol resistant foam is also available as an optional extra at Summit.
Alternatively, you can use petcock as you water outlet but it will have to rely on some ingenuity to marry up the two diameters - ensure it is absolutely air-tight.
Richard
Richard L is offline   Reply With Quote
Old 09-14-2006, 12:11 PM   #4
ejh25
Member#: 65267
Richard
Richard,
Thanks for the info.
I was thinking I would use the petcock as the water outlet. Phil @ Element said that I could use a 6mm hose attached to the petcock and have the supplied Hydramist hose forced inside of that hose and that should be air tight. I might wrap the connection with some sort of tape or maybe a zip tie that didn't pinch the connection. Let me know what you think.
Thanks,
Eric
Old 09-14-2006, 03:06 PM   #5
Aquamist
NASIOC Manufacturer
Member#: 110029
Originally Posted by ejh25 View Post
Richard,
Thanks,
Eric
I think by following Phil's instruction, you won't do much wrong. He described the connect of the two hose for me, it was very air tight.
Aquamist is offline   Reply With Quote
Old 09-14-2006, 04:06 PM   #6
ejh25
Member#: 65267
Hopefully I will have the kit in my hands soon so I can start taking some install pics!
Old 09-14-2006, 05:08 PM   #7
Aquamist
NASIOC Manufacturer
Member#: 110029
If you are using a rubber hose to splice the two hoses together, ensure the nylon hose tip is not too sharp, ,may produce some rubber debris. If you can run a hot air gun onto the tip of the nylon hose, it will round it up. I know there is a filter ahead. Particles smaller then 100 micro will get through and eventually causing unnecessary built up.
Richard
Old 09-14-2006, 10:20 PM   #8
ejh25
Member#: 65267
Richard
Good tips.
Thanks!
- Eric
Anyone have a volt vs flow chart for the hydramist turbine sensor? White 2.5rs Water/Methanol Injection, Nitrous & Intercooler Cooling 5 05-22-2009 11:31 AM
This pet was likely not the best choice for the baby GodWhomIsMike Off-Topic 3 11-18-2008 02:31 PM
Make my RB choice for this week..... eurojax Off-Topic 6 11-25-2006 11:34 PM
My Second Choice for a Wagon el~sharko Mid Atlantic Impreza Club -- MAIC 0 08-19-2003 04:42 PM
What is my best choice for chips? oney01 Normally Aspirated Powertrain 9 09-12-2002 01:43 PM
