Welcome to the North American Subaru Impreza Owners Club Monday January 26, 2015
Old 09-10-2006, 02:28 AM   #1
benw
Member#: 103320
2005 wingless
aspen white
Default underhood WI parts.. safe to get wet?
I was just curious how the typical underhoods parts resist water. When I clean my engine bay, I spray it all down with simple green and then use the .25 cent car wash wand set to "spotless rinse" and spray it all down clean. Are water injection parts safe for this kind of thing? specifically, Coolingmist boost pressure switch, checkvalve, wiring relay, inline fuse holder etc. I don't want anything to zap and short out, then I lose injection and pop a motor.
benw is offline   Reply With Quote
Old 09-10-2006, 03:49 PM   #2
dibblejr
Member#: 94070
05 LGT
I would say if in doubt put a baggie or plastic wrap on them while you clean under the hood and avoid direct spray.
With the controller all I have under the hood is the pump, I sprayed mine down (pump) without covering it. I also used jelly belly wire connectors when I wired it up. If you dont know these are connectors filled with oil or jelly based substance.
I did not have a problem.
dibblejr is offline   Reply With Quote
Old 09-10-2006, 07:06 PM   #3
benw
Member#: 103320
2005 wingless
aspen white
I was thinking of making an enclosure, or just putting the relay and associated wiring inside the fender to avoid heat and direct water. thoughts?
Old 09-10-2006, 09:28 PM   #4
dibblejr
Member#: 94070
05 LGT
Still a lot easier to just cover with a plastic bag before washing and avoid direct spraying. We are only talking about a few parts,
Before I got my commander I had all Of my electrical parts in the glove box. My new setup with the commander is great also.
Old 09-11-2006, 11:17 PM   #5
MonsterRallySport
Member#: 104148
MRT Spur cut with
Rocket center Diff.
Everything under the hood is made to be cleaned by a pressurewasher... Even the factory air box.... Unless you have a car with a distributor, don't worry... (or an aftermarket intake.. in that case just wrap it before you spray it)
MonsterRallySport is offline   Reply With Quote
Old 09-12-2006, 12:06 AM   #6
dibblejr
Member#: 94070
05 LGT
Dude did you read the thread before posting your answer? We are talking about add on open electrical componets to alky systems.
You are in the wrong leaque here. Read the entire post and reply with something useful, thanks.
Jay-R
Old 09-13-2006, 01:42 PM   #7
benw
Member#: 103320
2005 wingless
aspen white
Jay-R
ouch! But yes, I was referring to WI kit parts like relays, fuses, etc. At the minimum I will try to place these things in the fender, to clean up the engine bay as much as possible.
Old 09-13-2006, 07:16 PM   #8
dibblejr
Member#: 94070
05 LGT
Jay-R
Old 09-13-2006, 07:19 PM   #9
dibblejr
Member#: 94070
05 LGT
Dude,
I apologize, the message I accidentally posted to your thread was meant for monsterrallysport, who odviously didnt have a clue as to what you asked and I replied to.
Please accept my apology and by all means feel free to bash me back. I will continue to help you with questions you may have.
Jay-R
70,000 miles SAFE to get a tune? lowrider89 Newbies & FAQs 18 08-21-2008 09:57 PM
is it safe to get this?? jonsdc Newbies & FAQs 4 08-21-2007 11:33 AM
Somebody is going to get wet... the_poser Texas Impreza Club Forum -- TXIC 16 07-04-2006 10:22 PM
my scoobes doesnt like to get wet.... arty29 Legacy Forum 0 09-10-2004 10:40 AM
Question: Delvan, WI quickest way to get there? kenchan Mid West Subaru Owners Club Forum -- MWSOC 5 03-06-2004 11:38 AM
