Old 08-30-2006, 09:47 PM   #101
sti killa
Member#: 124571
95 turbo domestic
not gay pink like sti's
Default sti people are lame
A bunch of off the wall people own these cars. WTF? I mean come on. You spend a grand on a top mount. Spend tons on pink motorolla cell phones, but wont buy a quality alky kit. Call on saturday nights or sunday mornings. Walk like they have something lodged in thier rearends and I am not talking about the cars rearend either. Sit on websites going
I cant understand why people wont wake up and smell the roses. Buy a car that is not gay. When it comes to imports I always liked the evos better than subaru's because evos are not rainbow sticker magnets like subaru's.
sti killa is offline   Reply With Quote
Old 08-30-2006, 09:49 PM   #102
east milford wrx
Member#: 102301
air can leave the trunk throught the rear fender. incase you didnt know if you remove the rear bumper there is a vent type thing on each side. if you notice when you shut the door air does come out of them..thus air in the trunk can make it through the rear side wells and be vented out...idk atleast some fumes will escape
east milford wrx is offline   Reply With Quote
Old 08-31-2006, 08:09 AM   #103
PeteDucati
Member#: 44629
CNC 'd heads, cams
DB18g/EWG - F/S $8K
My SMC works PERFECT - until the methanol starts to boil. I'll be relocating the system to the trunk and use a vent tube from the cap to the underside of the car incase the fumes become an issue.. but methanol has a nice smell to it.
PeteDucati is offline   Reply With Quote
Old 08-31-2006, 09:05 AM   #104
Richard L
Member#: 85153
2004 Citroen Picasso
Methanol is poisonous, inhalted or swallowed, causing blindness.
Richard
Richard L is offline   Reply With Quote
Old 08-31-2006, 11:03 AM   #105
InfamousDX
Member#: 25413
Cured by ethanol!!!
Anyway, I'll have my SMC in the washer tank... hope it doesn't boil like yours Pete. You use 100% meth is that why? I was planing on 50/50
Old 08-31-2006, 06:21 PM   #106
krambte79
Member#: 97452
05 STi, 02 STi
& 09Ltd Tribeca
w/ the sti trunk system i am still able to use the stock i/c sprayer. i have not used it out of fear of lighting my car on fire, but is it okay or not to spray
100% meth across the top of your i/c?
krambte79 is offline   Reply With Quote
Old 08-31-2006, 09:06 PM   #107
djerickd
Member#: 3782
02 WRX WFC#040
Clean on 19's
Call 911 now
I don't think thats a good idea.
djerickd is offline   Reply With Quote
Old 08-31-2006, 09:42 PM   #108
dibblejr
Member#: 94070
05 LGT
Yeah with a flashpoint of 147 deg you would instantly start a fire. You might want to get the cast of Jackass to do it for you, they like to do stupin shiot.
dibblejr is offline   Reply With Quote
Old 08-31-2006, 11:13 PM   #109
krambte79
Member#: 97452
05 STi, 02 STi
& 09Ltd Tribeca
thanks, thats all i needed to know, but that being the case how does it not
ignite immediately during spray into the throttle body?
Old 09-01-2006, 09:45 AM   #110
PeteDucati
Member#: 44629
CNC 'd heads, cams
DB18g/EWG - F/S $8K
I'm running pure methanol from PowerMist - and a TMIC with coated headers - not wrapped. It gets pretty damn hot under there with no place for the heat to go - the meth stops spraying instantly (but comes back online after holding the "TEST" button for a second or two) after idling too long or cruising at very low speeds. Yes, last night my meth took a second to build pressure even though the outside temps were pretty cool.. it loses it's prime rather quickly when the underhood temps get too hot.
As far as the vapors killing me - I'll vent them through the bottom of the trunk.
Old 09-01-2006, 01:03 PM   #111
AZScoobie
Member#: 8785
02 [email protected]
netcom.com
I know a guy that put Alcohol in his IC spray tank.. He saw smoke.. Jumped out, and proceded to get burned because the flames where clear... You cant see Alchol flames. It torched the top of the motor. It was not to bad but instantly started a fire...
Clark
AZScoobie is offline   Reply With Quote
Old 09-01-2006, 01:24 PM   #112
djerickd
Member#: 3782
02 WRX WFC#040
Clean on 19's
OUCH!!!
Old 09-01-2006, 01:41 PM   #113
TurboRex
Member#: 8635
04 STI, 07 FXT
subscribed
TurboRex is offline   Reply With Quote
Old 09-01-2006, 03:47 PM   #114
dibblejr
Member#: 94070
05 LGT
It is sucked into the cylinder head so fast you cant see it burn.
I monitor my Alky, meth and or water with my temp guage since in the wagon there is no trunk it is mounted under the hood right under my SPT Intake and is seperated from the turbo and engine heat by my SPT heat shield. So far no problems at all.
Old 09-01-2006, 06:07 PM   #115
PeteDucati
Member#: 44629
CNC 'd heads, cams
DB18g/EWG - F/S $8K
Are you saying the methanol is ignited almost immediately after it's sprayed? If you are, you're quite mistaken. The ignition temperature is almost twice that of gasoline - and we all know gasoline doesn't ignite until that spark fires or detonation occurs. Also, if it were to ignite you'd blow all of the hoses off. Even though methanol has a low flash point - it's WAY higher than gasoline (-50F) versus methanol's +52 degrees.
Old 09-01-2006, 10:27 PM   #116
dibblejr
Member#: 94070
05 LGT
Nope, I know the flashpoints and pressures. I am just trying to let the OP know in simple terms. You cant see it burn, as with any combustian engine, internally everything happens so quick.
However if you spray it directly on the TMIC as mentioned in this thread you would surely set your car on fire.
Jay-R
Old 09-02-2006, 03:11 AM   #117
krambte79
Member#: 97452
05 STi, 02 STi
& 09Ltd Tribeca
i appreciate the simple terms. i will leave my i/c sprayer as non fuctional.
Old 09-02-2006, 08:44 AM   #118
PeteDucati
Member#: 44629
CNC 'd heads, cams
DB18g/EWG - F/S $8K
..but that being the case how does it not
This sure sounds like you were implying to Krambte that the meth is ignited before it enters the combustion chamber.
Old 09-02-2006, 02:17 PM   #119
dibblejr
Member#: 94070
05 LGT
i believe that everyone knows that the TB is not or does not have an ignition source.
if you are that shallow minded then next time i will spell it out just for you.
i believe the op has enough info to understand not to use meth or alky as an intercooler cooler.
Old 09-02-2006, 02:57 PM   #120
PeteDucati
Member#: 44629
CNC 'd heads, cams
DB18g/EWG - F/S $8K
I'm sorry - you posted, "It is sucked into the combustion chamber so fast you can't see it burn". That was the direct answer to, "..how does it not ignite immediately during spray into the throttle body".
I don't need it spelled out - and I'm not of shallow mind. But there are tens of thousands of NASIOC members that don't know how to change their own oil - how many of those do you think actually understand chemical cooling or even the basic principals of the internal combustion engine.
There's no need to insult me when you plainly stated it ignites in the manifold and gets sucked into the combustion chamber.
Old 09-02-2006, 03:18 PM   #121
dibblejr
Member#: 94070
05 LGT
I believe you do need it spelled out or even read to you; Here is what I actually said copied and pasted here just for your enjoyment: It is sucked into the cylinder head so fast you cant see it burn.I monitor my Alky, meth and or water with my temp guage since in the wagon there is no trunk it is mounted under the hood right under my SPT Intake and is seperated from the turbo and engine heat by my SPT heat shield. So far no problems at all.
i said cylinder head not combustian chamber.
The question was ' Why does it not ignite in the TB? Maybe I am wrong but I believe that it has to go through the TB to get to the cylinder head and combustian chambers. You are just wasting space on the site, the OP has already made his statement.
Old 09-02-2006, 07:00 PM   #122
krambte79
Member#: 97452
05 STi, 02 STi
& 09Ltd Tribeca
sorry to be the reason yous guys are arguing. i was just trying to understand the difference behind spraying meth across the intercooler and it igniting and if so why does it not ignite immediately when sprayed into the throttle body. i would think that inside the throttle body would be at a much higher temp than across the top of the i/c. and yes i do not know much of anything about chemical cooling or combustion for that matter.
thanks for the info guys
Old 09-02-2006, 08:47 PM   #123
dibblejr
Member#: 94070
05 LGT
No big deal. I was just trying to keep it in understandable terms. If you stay on this site you will soon realize that no matter what type of question you are trying to answer there is always somebody who wants to make negative comments just to try to spice things up a bit.
This is the problem when you have a wide spectrum of WRX owners from young to old.
Your best bet would be to keep your TMIC sprayer as a sprayer. In the winter dont forget to use window cleaner for whatever temp you will need. You can also add some alky 50/50 to your water to keep it from freezing.
Jay-R
Old 09-09-2006, 04:31 AM   #124
PeteDucati
Member#: 44629
CNC 'd heads, cams
DB18g/EWG - F/S $8K
Today I bought one of those infra red temperature guns. I shot the washer tank after the meth crapped out - lo and behold - ~147 degrees. The body of the pump and the brass fittings were the same temperature. UPS also dropped off the different tank, extended harness, and braided line - everything is now mounted in my trunk.
Old 09-09-2006, 08:44 AM   #125
PolarisSnT
Member#: 85905
2004 WRX
I run 100% denatured alcohol and I havnt run into this problem yet. I use my washer tank as theh storage tank and my pump is stored in my driver fender. Does the denatured alcohol have different properties as Meth or am I just lucky?
PolarisSnT is offline   Reply With Quote
Anyone running SMC Kit? David L. Water/Methanol Injection, Nitrous & Intercooler Cooling 30 11-19-2007 11:49 AM
What else needed with SMC kit before tune... vtec2sti Factory 2.5L Turbo Powertrain (EJ Series Factory 2.5L Turbo) 13 02-07-2007 07:54 PM
Power/performance difference between 50/50 and 100% methanol for water injection? sticrazy Water/Methanol Injection, Nitrous & Intercooler Cooling 42 11-19-2006 10:00 PM
About to get the SMC Injection Kit- Run with Meth or Alcohol? The_Urban_Knight Water/Methanol Injection, Nitrous & Intercooler Cooling 15 10-01-2006 02:12 PM
injection questions..smc kit..50/50 water denatured or 50/50 water methanol...discuss mpower22 Water/Methanol Injection, Nitrous & Intercooler Cooling 28 08-26-2005 12:24 AM
