Welcome to the North American Subaru Impreza Owners Club Friday December 2, 2016
Old 09-09-2006, 11:48 AM   #126
hippy
Member#: 36528
2002 Impreza Wrx
Originally Posted by PeteDucati View Post
.... "..how does it not ignite immediately during spray into the throttle body".
Could be partly because positive might(I think it does, but I'm havin a rough morning) increase the temp at which the alc lights. It's also because alcs flashpoint is not the temp at which it ignites without a spark.
peace
Old 09-09-2006, 01:39 PM   #127
dibblejr
Member#: 94070
05 LGT
My bottle temp stays costant 118 deg F, it sits right under my SPT intake.
I did have a recent developement though, the cheap Autozone tank I bought rupyured and my meth ran out. The tank I had purchased from Autozone had a wire bracket it sit in. I think that with my JIC coilovers that the bouncing help cause the rupture.
For the fix I cut off one side ( mounting bracket) on the heavy duty tank that came with the kit. It is a big difference in the thickness of the plastic in comparrison to the Autozone cheapo. I bolted the other side bracket right to my SPT heat shield. My new temp is exactly the same 118 f.
dibblejr is offline   Reply With Quote
Old 09-09-2006, 01:42 PM   #128
dibblejr
Member#: 94070
05 LGT
I have tried to answer this question before and everyone got bent out of shape. I will say this today to keep it simple.
The temp of the alky running through the lines may be enough to cause it to ignite, but you have to have an ignition source. ie; you cant make a fire without a spark. When the juice meets the TB it is cooled down by the air, then it is consumed into the combustian chamber, thats why it doesnt ignite in the TB.
Hopefully that explains it even easier than the first time a week ago.
Jay-R
peace
Old 09-09-2006, 02:08 PM   #129
dibblejr
Member#: 94070
05 LGT
Yes they all have different FP's and BP's.
Here they are;
Alcohol FP 140F, 60C, BP 78.3C
Methanol FP 51.8F 11C, BP 149F 65C
Here's a helpful chart with mixing fuel and water
Originally Posted by PolarisSnT View Post
I run 100% denatured alcohol and I havnt run into this problem yet. I use my washer tank as theh storage tank and my pump is stored in my driver fender. Does the denatured alcohol have different properties as Meth or am I just lucky?
Old 09-10-2006, 10:02 AM   #130
hippy
Member#: 36528
2002 Impreza Wrx
Jay-R
You can make fire without a spark. That's exactly how diesel engines work and how knock, pre-ignition, and afterfire occur(as far as I know). You do need oxygen for fire, but alc has that build in. Not saying that alc is igniting on the way into the engine, because it would need to get MUCH hotter then its flashpoint temp for this to occur without a spark.
As far as I know, the autoignition temp(temp at which it will ignite without a spark) is higher then 700F. This would mean that the chances of it igniting inside the intake track(like at the throttle body) are most likely pretty close to nil, but it could easily happen if the alc was being injected into the engine compartment(because of things like a hot turbo and exhaust parts).
peace
Old 09-10-2006, 12:26 PM   #131
dibblejr
Member#: 94070
05 LGT
Diesel engines do have an igniter, it's called the " glow plug". We are not talking diesel engines here, that is a totally different operating platform.
If your alky/meth is hot enough to burn on it's way into the engine then your entire car will be on fire because the plastic tanks would melt. I include a copy of some of the Plastics properties for review.
jay-r
peace
Old 09-14-2006, 06:15 AM   #132
PeteDucati
Member#: 44629
CNC 'd heads, cams
DB18g/EWG - F/S $8K
It's some where in the mid 800's.. gasoline is a couple hundred degrees less.
Diesels only use glow plugs for cold starts - and that's only on very light duty diesels, tractor trailers don't have glow plugs.
The 147 degree boiling point of methanol has nothing to do with it's ignition point. And the air/fuel ratio also plays a huge role determining this, too.
PeteDucati is offline   Reply With Quote
Anyone running SMC Kit? David L. Water/Methanol Injection, Nitrous & Intercooler Cooling 30 11-19-2007 12:49 PM
What else needed with SMC kit before tune... vtec2sti Factory 2.5L Turbo Powertrain (EJ Series Factory 2.5L Turbo) 13 02-07-2007 08:54 PM
Power/performance difference between 50/50 and 100% methanol for water injection? sticrazy Water/Methanol Injection, Nitrous & Intercooler Cooling 42 11-19-2006 11:00 PM
About to get the SMC Injection Kit- Run with Meth or Alcohol? The_Urban_Knight Water/Methanol Injection, Nitrous & Intercooler Cooling 15 10-01-2006 03:12 PM
injection questions..smc kit..50/50 water denatured or 50/50 water methanol...discuss mpower22 Water/Methanol Injection, Nitrous & Intercooler Cooling 28 08-26-2005 01:24 AM
