Welcome to the North American Subaru Impreza Owners Club Friday November 21, 2014
Old 08-09-2006, 12:45 AM   #1
Shockster0429
Member#: 122468
02 WRX
Default sloppy shifts
Well i just purchased my first subaru, a 96 legacy awd 5 speed, good winter car for me.. well the shifter is the sloppiest shifter i have ever used, tranny works amazing, clutch feels great, shifter just flops about.. im guessing linkage problem, most likely bushings worn out? how complex is the linkage, is it multiple bars? single? ive been searching for a few hours now looking for oem companys that sell them, and am having no luck. any advice or answers, would be grealty appreciated. thanks.
Shockster0429 is offline   Reply With Quote
Old 08-09-2006, 12:59 AM   #2
Turn in Concepts
Member#: 93646
Many Track Records
Let us help you go fast!
Typically, the market is largest for the 97+ scoobs which means pre-97 guys are usually outta luck unless you update to a WRX linkage setup. there are a coupld of things that you can do -
1) post up a pic of your current shifter lever, and we'll see if the 96 leg is the same as the 97 impreza (don't laugh the 05 LGT linkage was a year ahead of the 06 impreza linkage)
2) there's a post in the legacy specific area with part numbers of what you need to replace all the older stuff if it doesn't match up to the 97 impreza goodies.
FS : Kart Boy shift knob SlouWRX Drivetrain 9 07-17-2010 10:36 AM
Sloppy 2nd to 3rd shift (STi SS kit) txl146 Transmission (AT/MT) & Driveline 3 11-27-2006 11:10 AM
Sloppy shifting due to the greased ball? flyboymike Transmission (AT/MT) & Driveline 1 08-18-2005 01:23 PM
sloppy shifting Overcranked23 Newbies & FAQs 7 01-04-2004 09:07 AM
sloppy shifts with AC on kenchan Transmission (AT/MT) & Driveline 5 07-03-2002 07:09 PM
