Welcome to the North American Subaru Impreza Owners Club Friday December 2, 2016
Old 08-09-2006, 02:53 PM   #1
mvitic
Member#: 32858
2002 WRX WAGON
Default STG2: Flashing CEL but no CEL code
Hi Guys,
This morning on the way to work I had the CEL flashing after some spirited driving. After I eased off to a more commuter style pace the CEL stoped flashing and went away. When I arrived to work I checked for CEL codes and the Accessport reported that there were none, what gives, were these CELs the ones that the STAGE 2 clears?
BTW, I have a STAGE 2 with PDE uppipe, PDE downpipe and a full turbo back exhaust from BPM.
Thanks,
Michael
Ottawa Canada
mvitic is offline   Reply With Quote
Old 08-10-2006, 10:43 PM   #2
TMessick
Member#: 882
2004 WRX Wagon
very blue
Flashing MIL usually means that the ECU thinks it's detecting misfire. Specifically, it thinks it's seeing enough misfire to damage the catalyst. There have been several cases on scoobys where the combination of a lightweight flywheel and lightweight/underdrive pulley has caused a false misfire MIL. (basically, the ECU monitors the crankshaft signal to detect misfire. Lighter reciprocating mass will cause more variation in the crank signature for a "good" system, but the ECU can falsely detect this as misfire.) I'm not sure which codes the AP explicitly turns off (check the map notes for the map you're running) -- looking at the notes for the stage1/2 maps, I don't see the misfire codes disabled (P0300-P0304)....
TMessick is offline   Reply With Quote
Flashing CEL but no code 07wrx4life Factory 2.5L Turbo Powertrain (EJ Series Factory 2.5L Turbo) 2 05-12-2010 10:01 PM
flashing cruise light but NO CEL? happasaiyan Factory 2.5L Turbo Powertrain (EJ Series Factory 2.5L Turbo) 71 02-01-2008 05:05 PM
CEL but no code found? phunkdup Engine Management & Tuning 7 09-16-2006 12:43 AM
Stock 2005 Baja Turbo - CEL But No Codes - Any Ideas NJ Baja Baja Forum 7 09-03-2005 12:45 PM
Help: CEL, but no trouble codes j y Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 4 08-26-2005 05:45 PM
