Old 10-25-2001, 12:32 PM   #1
adeck
Member#: 6840
2001 2.5RS
Blue Ridge Pearl
Default Nitrous wet kit compression?
With any nitrous wet kit, say running a 55 shot how much would it affect your cylinder compression ratio?
adeck is offline   Reply With Quote
Old 10-25-2001, 01:02 PM   #2
Chuck_Beef
Member#: 9903
2001 Impreza RS RIP
The compression ratio stays the same...maybe your wondering how much more oxygen it's getting?
Chuck_Beef is offline   Reply With Quote
Old 10-25-2001, 01:20 PM   #3
adeck
Member#: 6840
2001 2.5RS
Blue Ridge Pearl
I just thought that since your adding so much more air into your motor that it might raise compression, kinda like a turbo forces air in thefore creates a higher compression. The nitrous kits add more air therefor wouldn't they raise compression a tad?
Old 10-25-2001, 01:51 PM   #4
HndaTch627
Member#: 6551
'01 GC8 Dinged STM
'09 Concours 14 ABS Black
nitrous will affect you overall combustion pressure...as far as affect compression ratio it does not(until you detonate). You still run 10.0:1 compression w/ nitrous it's just now there's more air and fuel being punished by the piston.
Jeremy
Old 10-25-2001, 02:22 PM   #5
Eric SS
Sooby Guru
Member#: 1914
2000 2.5RS w/ EJ22T
swap and N20. gone. : (
Compression ratio is something that is mechanically built into the engine. it cannot be changed by adding nitrous or boost.
Eric
Eric SS is offline   Reply With Quote
Old 10-25-2001, 02:23 PM   #6
HndaTch627
Member#: 6551
'01 GC8 Dinged STM
imprezinator it can with a little detonation...if ya get my drift
Old 10-25-2001, 02:36 PM   #7
Eric SS
Sooby Guru
Member#: 1914
2000 2.5RS w/ EJ22T
lol.. I found that out the hard way! I now have much less compression in one of my cylinders than the others. I call this my specially designed dished piston.
Eric
Old 10-25-2001, 02:41 PM   #8
HndaTch627
Member#: 6551
'01 GC8 Dinged STM
LOL!!!
Old 10-25-2001, 03:59 PM   #9
adeck
Member#: 6840
2001 2.5RS
Blue Ridge Pearl
What I meant to say is how will nitrous affect the cylinder pressure?
Old 10-25-2001, 09:44 PM   #10
Eric SS
Sooby Guru
Member#: 1914
2000 2.5RS w/ EJ22T
It causes a lot more cylinder pressure because of the much bigger explosion. Not sure what ratio there is for finding out how much more cylinder pressure though
Eric
Old 10-26-2001, 03:56 AM   #11
XT6Wagon
Member#: 524
04 STi
Is your car Fuel injected? Well if it is, either use a **DRY** kit, or multi port kit, with a minimum of one per runner, each placed close to or after the injector. This is because the intake manifold WILL NOT flow fuel properly. So N20+ no fuel = boom.
XT6Wagon is offline   Reply With Quote
Old 10-26-2001, 07:55 AM   #12
adeck
Member#: 6840
2001 2.5RS
Blue Ridge Pearl
XT6Wagon, that is what I was thinking. I am looking at the ZEX kit, and I was wondering what the stock cylinder pressure is and how much a 55shot of N2O would raise it?
Old 10-26-2001, 12:06 PM   #13
Chuck_Beef
Member#: 9903
2001 Impreza RS RIP
Post
This is probably pretty inaccurate, but since it is a 55hp shot, take
(165+55)/165 = 1.33
so your engine is probably getting about 33% more oxygen with a 55 shot, which would cause a 33% bigger explosion
Old 10-26-2001, 04:34 PM   #14
Iowannaski
Member#: 8268
00 GM67
BRP me ASAP
Um, if you are wondering how much higher the pressure will be at the top of the compression stroke with nitrous, it seems the answer would be lower. The pre-ignition pressure should be lower, assuming the amount of fuel and the oxygen/fuel ratio are kept constant. Because N20 is more oxygen rich than air, less gas will be present in the combustion chamber if the oxygen/fuel ratio is held constant.
Of course, this won't really answer your question because if you are planning on making significantly more power than stock you will also need more fuel in the combustion chamber. Gasoline, of course, does not compress at all, being a liquid as it is. This, in turn, decreases the amount of space available for gas under full compression, and would increase the preignition pressure.
Now, given all that, you should be more worried about melting your engine than increasing pre-ignition combustion chamber pressure.
Iowannaski is offline   Reply With Quote
Old 10-26-2001, 09:54 PM   #15
Eric SS
Sooby Guru
Member#: 1914
2000 2.5RS w/ EJ22T
Wet systems are fine also... Been using em' for years without a problem, even on my scooby. I wasnt; running nitrous when the engine blew
Eric
Old 10-27-2001, 02:33 AM   #16
HndaTch627
Member#: 6551
'01 GC8 Dinged STM
i don't think i'd runa wet kit with the way our intake is designed, too much of a chance of puddling for my liking.
Jeremy
Old 10-27-2001, 03:09 AM   #17
Eric SS
Sooby Guru
Member#: 1914
2000 2.5RS w/ EJ22T
I could go on and on about why I prefer a wet system over any dry system But I won't.. It sounds stupid but I am very tired of posting the same thing over and over after someone has a question like this Not trying to be an ass. To me, trying to convert someone that is a wet or dry user is like trying to convert an athiest or religous person.. It's not gonna happen. That being said, I actually took the time to search for previous threads of mine and came up with this one. it explains a little on the difference
http://i-club.com/forums/showthread....stem+injectors
Eric
Old 10-27-2001, 03:12 AM   #18
HndaTch627
Member#: 6551
'01 GC8 Dinged STM
oh no....i'm not arguing that, i think a wet system is the way to go, but i am a fogger guy....Hehe...when i build em wet i go big HP. MUHAHA!!! had a 250 bigshot on a truck i had....that was fuggin wicked. Well till i blew it up.
Jeremy
Old 10-27-2001, 03:20 AM   #19
Eric SS
Sooby Guru
Member#: 1914
2000 2.5RS w/ EJ22T
lol.. Of course, If I could, I would fog the scooby! It actually has a good runner setup for a fogger!
Eric
Old 10-27-2001, 03:40 AM   #20
HndaTch627
Member#: 6551
'01 GC8 Dinged STM
yeah...it'd be awesome to put a fogger kit on a scooby.
Maybe i should build a nitrous powered scooby for someone.
Jeremy
Old 10-27-2001, 03:58 AM   #21
Eric SS
Sooby Guru
Member#: 1914
2000 2.5RS w/ EJ22T
Try it. I bet with the right internals (i.e. forged everything, B&B) you could safely do a 200hp fogger kit
Eric
Old 10-27-2001, 04:08 AM   #22
HndaTch627
Member#: 6551
'01 GC8 Dinged STM
i am considering it now....dammit why did this have to go thru my head.
BAH!!!!!!!!!!!!!!!!!!
Jeremy
Old 10-27-2001, 04:21 AM   #23
Eric SS
Sooby Guru
Member#: 1914
2000 2.5RS w/ EJ22T
I will be a notrous junkie till the day I die!
Eric
New ZEX nitrous wet kit lazybastard Private 'For Sale' Classifieds 7 08-28-2003 12:22 PM
F/S Zex Nitrous WET KIT !! wrxturtle North West Impreza Club Forum -- NWIC 15 06-24-2003 01:01 AM
nitrous wet kit install question.. wrxturtle Motorsports 2 02-25-2003 07:18 PM
Nitrous wet kit install question.... wrxturtle North West Impreza Club Forum -- NWIC 2 02-24-2003 01:59 AM
nitrous wet kit install question.. wrxturtle Normally Aspirated Powertrain 2 02-22-2003 10:50 PM
