Welcome to the North American Subaru Impreza Owners Club Sunday July 31, 2016
Go Back   NASIOC > NASIOC Subaru Models > Outback Forum
Old 08-10-2006, 01:45 PM   #1
mitchelt
Member#: 122631
Default 1999 Subaru Outback...tune up....transmission?
Hi,
I have a 1999 Subaru Outback with 80k miles.
First Problem:
Sometimes when I'm at a stop light with or without the air conditioning running the engine rpm's will drop a bit and the enging seems like it is going to stall for a second then it comes back up and it is fine. This also happens when I initially step on the gas from a stop, the rpm's will drop slightly, the engine will seem like it is going to stall and then it's fine.
I always use the middle grade fuel and keep up with the oil changes.
Second Problem:
I work from home so a few days may pass between the times I drive my Subaru. When this happens the car starts fine, but when I put it in reverse to exit the garage the car does not respond very well to me pressing the gas. What I mean by that is that I press the gas, I hear the engine getting louder but I do not roll back as fast as the car should be moving. This only happens for the first 5-10 feet then it's like the car wakes up and everything is ok.
Any help would be greatly appreciated.
Thanks!
mitchelt is offline   Reply With Quote
Old 08-14-2006, 08:06 AM   #2
alexandre_o2
Member#: 77839
1997 Legacy Outback
Green/Gray
For the second problem, I had very similar issues until I changed my transmission fluid. Did you check the level and color of the fluid? You may be due for a change... (cost me about $70 at the dealer)
The first problem, I'm not too sure but it may be your spark plugs that need replacing. However, I suggest you have that checked at the dealer - I recently changed the plugs on my Outback but the access is very restrictive on the H engine and it took me hours just to "feel around" to get the old ones out and the new ones in! Worth paying the extra bucks to save yourself the hassle.
Hope this helps
alexandre_o2 is offline   Reply With Quote
Advice on maintenance and upgrades for a 1999 Subaru Outback A_Pickle Outback Forum 1 04-25-2010 11:38 AM
1999 Subaru Outback Limited Wagon - FS Cheap! ChrisSK NESIC Private Classifieds 10 05-06-2008 04:15 PM
1999 Subaru Outback Limited Wagon - FS Cheap! ChrisSK Private Vehicle 'For Sale' Classifieds 1 05-04-2008 09:40 AM
1999 Subaru outback sport trunk problem only1agam Service & Maintenance 5 10-18-2005 06:45 PM
1999 Subaru Outback Legacy AWD Wagon whitetoast Private Vehicle 'For Sale' Classifieds 1 09-02-2005 08:43 PM
