Old 08-10-2006, 04:15 PM   #1
06BLUEREX
Member#: 120000
Default First time at the track, horrible times. But not the last time going.
well i hit the track a couple of days ago to see what my times were, sadly this is my first time there so i was so nervous and sweating my ass off. i have never launched my car full out. i would either bog or spin the rpms to redline and not go anywhere. most of it, i was nervous more than anything.and it was about 100 degrees outside down here in Texas,well here my times i am here to seek advice thanks
first run i reved to about 4500 and bogged
R/T .088
60' 2.318
330 6.196
1/8 9.272
MPH 82.11
1000 11.910
1/4 14.122
MPH 102.36
RUN TWO i slipped the clutch way to long and smelt like burning clutch so i called it a night.
r/t .456
60' 2.058
330 6.035
1/8 9.130
mph 62.07
1000 11.736
1/4 13.948
MPH 102.46
i need to practice more, i think with better launching i should be able to do better?
mods are
fp18g
ebay tmic
tbe
walbro fp
colder plugs
perrin ebcs
mustang dynotuned at 254whp and 285wtq at MZM.
06BLUEREX is offline   Reply With Quote
Old 08-10-2006, 04:21 PM   #2
wizzman
Member#: 84405
2007 V8 4Runner
1994 flaming red Miata
That is extremely low power for your setup. Why do all that and not upgrade your injectors? Full bolt on stock turbos aren't far behind that kinda of power. I would think you would be well over 300 whp. With that kind of power you aren't going to get much better than mid to low 13s even with good driving.
wizzman is offline   Reply With Quote
Old 08-10-2006, 07:39 PM   #3
josh04
Member#: 89288
2002 Rex
You need at least pinks for injectors. And yeah that is really low but It's because of the stock injectors.
josh04 is offline   Reply With Quote
Old 08-10-2006, 07:50 PM   #4
The Head
Member#: 98143
04 Cayenne TT
05 SL65, 03 GSXR1000
I'll be out there tomorrow just to see how much the heat has slowed me down. You just need some practice.
The Head is offline   Reply With Quote
Old 08-10-2006, 07:54 PM   #5
ducmaan748
Member#: 86518
2004 WRX STi
Stage 2
yup..
ducmaan748 is offline   Reply With Quote
Old 08-10-2006, 08:23 PM   #6
subarulz!
Member#: 99061
16 WRX
CWP
I thought 06 injectors flow as much or better than pinks. I've read it here more than once.
subarulz! is offline   Reply With Quote
Old 08-10-2006, 09:24 PM   #7
benw
Member#: 103320
1998 swapped
Forester L
stock 06 injectors were flowtested to be ~560cc just like pinks
benw is offline   Reply With Quote
Old 08-10-2006, 10:03 PM   #8
treystoys
Member#: 97436
05 Legacy GT
white
I think he just needs some practice driving...yeah, the numbers aren't the best, even on a low reading dyno, but for reference, my car made only 6 more whp than his, and 50 less wtq than him on a low reading dyno dynamics dyno, and I still managed to run a 12.7 @ 105.3 in 95+heat and humidity...mine will go low 12s in the winter...and this is with a 16g on a 2.0
practice your launch and shift at redline for your best runs, and I bet you'll see 12s in any kind of weather.
I do agree with one thing the guys above said, larger injectors should be on your to do list...I am running helix 660s on mine (ported evo3 16g and AVO tmic)
Good luck...
Trey
treystoys is offline   Reply With Quote
Old 08-10-2006, 10:55 PM   #9
RS drifter
Member#: 7891
2005 wrx STI
Aspen MF white!
yup.. just need a little practice... and feed that turbo! but hey if you want to get rid of the 18G and upgrade to a 35R just let me know
RS drifter is offline   Reply With Quote
Old 08-10-2006, 11:39 PM   #10
06BLUEREX
Member#: 120000
would water/alky injection lower the injector idc?
Old 08-11-2006, 12:10 AM   #11
CoolRex
Member#: 85813
2002 E46 M3
2006 RC51
Yep it will. However on a 18g it is recommended to use at the least 720cc inj
CoolRex is offline   Reply With Quote
Old 08-11-2006, 08:48 AM   #12
LiquidForce
Member#: 12811
2002 2.5l Wrx
517whp/516wtq (Stage pi)
I run a 20g on pe650's and meth and never see duty cycles above 75%.
If you use meth with the 18g you will have plenty of room with the stock injectors.
LiquidForce is offline   Reply With Quote
Old 08-11-2006, 08:51 AM   #13
b4437
Member#: 23162
2006 300c,forester x
silver steel
Still nuff a dem a fail to see
b4437 is offline   Reply With Quote
Old 08-11-2006, 08:55 AM   #14
salisburyv
Member#: 41863
2015 STI
Crystal Black Silica
this is a 2.5l engine boys.
salisburyv is offline   Reply With Quote
Old 08-11-2006, 09:00 AM   #15
WRXtr26
Member#: 112104
2004 Baja Turbo 4eat
what EM are you running??
WRXtr26 is offline   Reply With Quote
Old 08-11-2006, 09:34 AM   #16
gabedude
Member#: 10108
07 STI
60Trim spun rod bearing
You are only trapping 102? Did you miss shift? Granny shift? An 18G TR is a 12 sec car @110+ easily. Are you sure you have the right map loaded? Seriously, if you can't get more than 102 out of your car, something must be wrong. Even a friend of mine back in winter of 2002 (who is the worst driver I have ever seen) ran a [email protected] on his mildly modified wrx and it was putting down a little more hp than mine. I ran [email protected] that night. My point is, even if you are a horrible driver, your traps are way too low for an 18g 2.5L. The MZM dyno reads very low (your hp and tq numbers look ok for that dyno), so I would venture to guess that something is wrong with your car. You should be trapping alot higher, even with your bad launches.
gabedude is offline   Reply With Quote
Old 08-11-2006, 08:19 PM   #17
evilimpdrvr
Member#: 94169
2005 wrx
I have an 05 wrx w/ uppie and catback. My best in that car is [email protected] w/ 1.8 60' times. I would think you be low 13's to high 12's w/ that. I launch at around 5200 rpm. It's hard to explain but the best thing you can do is bring your knee straight up towards the wheel when launching. You'll have to find that happy medium between slipping and dumping but it's there. Just bring it up smoothly and quickly and you should launch like a bat. Like I said hard to explain unless I can show you. but practice will help.
evilimpdrvr is offline   Reply With Quote
Old 08-11-2006, 09:00 PM   #18
Sypher
Member#: 106366
2006 WRX
that car should be in the low 12's with a 110mph trap itleast with an 18G, you need to get retuned because those numbers are low I dont care if its on a Mustang Dyno or not times represent your power level/driving skill. The driving was horrible but still your trap should be WAY WAY WAY higher. you do not need new injectors, you need a new tune. Your car is not running right. I constantly see 2.0liter boys wtih 18G's hit low low low 12's and hell soemtimes 11's, I see VF 2.0liters run 12.6's all day, and yet I see stock 06 wrx's/stage 2 run low low 13's but turbo upgraded 06's run mid 13's? Somethings not right. If you know anyone local go run a stock STI from a Roll see how many cars you pull on em (If any).
Sypher is offline   Reply With Quote
Old 08-11-2006, 09:21 PM   #19
06BLUEREX
Member#: 120000
i've pulled on a stage 2 sti with with a aps fmic, aps cai, walbro fuel pump, ecutek, perrin ebcs, turbo back exhaust dynoed tuned at 305whp and 310wtq after i got it tuned by 3-4 cars.
Old 08-12-2006, 10:25 AM   #20
CoolRex
Member#: 85813
2002 E46 M3
2006 RC51
That goes to tell ya it the driver. No offense but dragging has a lot of variables. Launch has to be perfect, shifts have to be perfect and the setup has to be good.
Old 08-12-2006, 12:06 PM   #21
06BLUEREX
Member#: 120000
exactly, i rarley go to track, nor do i launch my car that much on the street. it'll take some good practice to get good low 1/4 times.
what alot of people fail to understand is that it takess alot variables to get good times, my dyno might be low but a stock sti on that dyno puts 200ish whp and a 20g sti put 280ish on the same mustang dyno.
the track wasnt really prepped well, and it was over 100degrees out there, my 102mph trap was pretty decent that day compared to ls1's that could not even get past my 102 or even close to 100mph. not every track/dyno/setup will be the same, theres just to many variables that causes different results. just because you are use to seeing the numbers/higher numbers doesnt mean it will be the same for others reason , you have to consider the elevation/conditions people just dont take that into thought. people right off the bat start to bash and get on the bandwagan, i've seen to many of these threads and same people comment about this and that but they dont seem to think about where there at and etc.
i am not hurt by what people have said on this thread but see it as comments and people opinions i just wish people would think about the other surrounding coditions, i know the car pulls hard on the street because its taken down alot of quick cars that i couldnt when i had my vf39 setup.
for those who gave me tips i appreciate it and will continue to practice on my launches and will be visiting the track my 2nd time soon.
Old 08-12-2006, 12:42 PM   #22
Jaylyons1
Member#: 113884
2013 BRZ
My first run at the track was 13.9. Im completely stock. Then I figured out, launching on green is bad, lol. 2nd time I went I got 13.60 thats my best so far, Only been the two times. Im trying to get under 13.6. Whats your guys's best times for stock STi?
Jaylyons1 is offline   Reply With Quote
Old 08-14-2006, 12:15 PM   #23
Turn in Concepts
Member#: 93646
Many Track Records
Let us help you go fast!
When you launch has no impact on the time you run.
Old 08-14-2006, 12:20 PM   #24
LOLSTi
Member#: 51452
2004 Subaru WRX STi
1992 Mazda Miata
Launching on green will net you the same time as launching on yellow or red.
Damnit Tony!
LOLSTi is offline   Reply With Quote
Old 08-14-2006, 01:09 PM   #25
Jaylyons1
Member#: 113884
2013 BRZ
wooha, a lil bit better this time!
Still runnin stock though.
1st time at Muffler City HORRIBLE service coqui2004miguel Alaskan Impreza Club Forum -- AKIC 49 11-10-2009 08:13 PM
1st time at the track with my 05.... not good blueRexFlyBy05 Motorsports 9 05-25-2007 07:22 AM
UTEC controling fuel but not boost or timing cky211 Engine Management & Tuning 12 08-29-2005 04:51 AM
Anyone like the Kaminari front lip but not the one they have? KnightWRX Texas Impreza Club Forum -- TXIC 6 02-20-2004 08:51 AM
First time at a track this June....need suggestions? ScreaminFast Motorsports 52 04-21-2003 10:20 PM
