Old 08-10-2006, 04:34 PM   #1
b73
Member#: 62384
98 Legacy
green
Default Cylinder 3 and 4 misfire
Hey guys:
I'm looking for some help with my wife's 2000 forester. 127k miles, tbelt changed at 107k miles
About a month ago, the cel threw 1,2,3,4 misfire. Checked the plugs, ngk oem, the plugs wires were fine with the resistance test. So i checked the coil pack, it checked bad so i replaced it with a new oem from dealer. I thought the problem was gone, then two weeks later, the car wouldnt start, it turned over and finally after a few cycles of cranking it started but threw 3 and 4 misfire. Changed the plugs and problem went away for a few weeks. After moving here to SLC, the car starts doing this again. Only after it sits overnight does it run rough on intial start up. after a minute or so it clears up and runs fine.
I then decided yesterday to change the o2 sensor, car seems to run fine about 50 miles, then this morning after sitting all night, i get the same 3 and 4 misfire upon startup, then after about a minute, the engine clears up and runs fine for the rest of the day.
Ive been at other boards and some have suggested replacing the crankshaft or knock sensor. I really dont want to throw any more money until i have a more definite reason .
any help/thoughts would be appreciated
b73 is offline   Reply With Quote
Cylinder 3 and 4 Misfire Brupp Normally Aspirated Powertrain 41 06-29-2014 11:49 AM
cylinder 3 and 4 still misfire joshua olean Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 18 01-24-2008 07:24 AM
Cylinder 3 & 4 misfire Help why? car_cursed Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 17 04-04-2006 08:47 PM
P0303-P0304 Cylinder 3 & 4 misfire detected =( Hunt3r Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 6 10-09-2005 02:57 PM
Cylinder 3 and 4 Misfire P0303 P0304 kcismo Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 2 05-23-2005 08:41 PM
