Old 08-11-2006, 09:42 AM   #1
HamFist
Member#: 2112
2000 Impreza 2.5RS
BRP
Default valve-to-piston + valve-valve clearance specs?
What are these specs on a 2000 SOHC 10:1 compression N/A motor?
HamFist is offline   Reply With Quote
Old 08-12-2006, 08:12 PM   #2
MSR
Member#: 20842
05 Spec C Type RA
Rule of thumb is .090" on Ex and .110" inlet.
MSR is offline   Reply With Quote
Old 08-12-2006, 08:31 PM   #3
HamFist
Member#: 2112
2000 Impreza 2.5RS
BRP
Is that what it specs out to on the stock 10:1 2.5L engine? Thanks for the rule of thumb, but I'm curious what it might actually measure out to .
Old 08-12-2006, 08:49 PM   #4
MSR
Member#: 20842
05 Spec C Type RA
No idea, way more than that, the rule is what you can build a high comp dome piston too, with high overlap cams, std ej has stuff all overlap, so would have a heap of room, but if a belt were to break would hit.
Old 08-12-2006, 09:38 PM   #5
HamFist
Member#: 2112
2000 Impreza 2.5RS
BRP
I'm not as worried about a belt breaking as I am about one skipping a tooth from revving too fast. I've heard of that happening but I've never seen it around here. How often do the belts actually break anyway?
Old 08-13-2006, 03:06 AM   #6
MSR
Member#: 20842
05 Spec C Type RA
They can jump when the tensioner is at the end of it's travel, either from machining black heads, or worn.
Old 08-13-2006, 03:11 AM   #7
HamFist
Member#: 2112
2000 Impreza 2.5RS
BRP
My heads will likely be milled .005 just to surface them. Will that cause any problems with the tensioner?
Old 08-13-2006, 03:16 AM   #8
MSR
Member#: 20842
05 Spec C Type RA
No, it's when you take a .5mm off each head you can run into issues.
I have run turbo engines with only .060" on exhausts and never had them touch.
Old 08-13-2006, 03:41 AM   #9
HamFist
Member#: 2112
2000 Impreza 2.5RS
BRP
Thanks for the input .
BTW, what should I pay for new valves? I heard of some company selling them for about $250 for new stainless steel valves, but I don't now who it was. I don't remember if it was Crower or someone else (???).
Old 08-13-2006, 05:04 AM   #10
MSR
Member#: 20842
05 Spec C Type RA
Have to shop around and try and get 1mm larger ones.
Rod to piston pin clearance? Bad Noodle Built Motor Discussion 6 04-20-2010 01:00 PM
Engine build - clearance/spec opinions generalee69 Built Motor Discussion 4 10-02-2008 12:45 PM
Pistons for STI hybrid motor? -and- How to acheive correct bearing clearances?? radrider Built Motor Discussion 13 04-28-2008 03:48 PM
JDM V5 STI Valve Clearance specs.... Help? DFL2.5RS Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 5 04-14-2007 12:34 AM
valve-to-piston clearance?(ej20g+v7block) xtian Built Motor Discussion 5 12-12-2006 01:11 AM
